Best 720p/1080i Projector - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 12-26-2007, 06:20 AM - Thread Starter
martyhk0's Avatar
I have been out of the loop for a while and its time for a new projector. The 10809's are still too rpicey for me. So, currently, whats the best 720p projectors for the price?
I think when I checked last, I was looking at the hd1000, hd70 and hc1500
UPDATE: I am using this in a dark room with No ambient light. Also, my distance of lens to screen is about 17 feet and the screen is 16:9, 8 feet wide. If I go to a cofee table instead of celing mount the distance becomes more like 13 feet with a few feet to play with.
martyhk0 is offline
post #2 of 8 Old 12-26-2007, 06:38 AM
tbase1's Avatar
Quoted: 47 Post(s)
Liked: 70
go with the hc1500 if you don't suffer from RBE.
tony4k
tbase1 is offline
post #3 of 8 Old 12-26-2007, 07:47 AM - Thread Starter
martyhk0's Avatar
what is rbe?
martyhk0 is offline
post #4 of 8 Old 12-26-2007, 07:54 AM
jterrell's Avatar
Originally Posted by martyhk0 View Post
what is rbe?
rainbow effect.
it's rare, but can effect those with dlp potentially.
sp-7210, 110" DIY BO screen, 60 GB PS3, Dish HD Receiver, yamaha 6060-htr, htpc, polk r50's, polk csr, polk r150x4, cerwin vega 12" sub. I try and do my part for the economy.
jterrell is offline
post #5 of 8 Old 12-26-2007, 07:56 AM
mjg100's Avatar
what is rbe?
Rainbow's. Some (very few) people see rainbows when viewing DLP.
mjg100 is offline
post #6 of 8 Old 12-26-2007, 07:57 AM
jterrell's Avatar
btw, check out this thread...
http://www.avsforum.com/avs-vb/showthread.php?t=960823
Lots of great options at that price point.
So many that many who choose less then the best option are extremely happy and will argue for their choice.
I suspect after a bit of research and using a calculator to insure fit/screen size it will be difficult to not be happy with the final result.
happy hunting.
jterrell is offline
post #7 of 8 Old 12-26-2007, 08:29 AM
gwlaw99's Avatar
Here are my suggestions. If it fits your room and you don't mind the higher bulb cost the Infocus 7210 is a steal.
http://thetechhunter.blogspot.com/20...rojectors.html
gwlaw99 is offline
post #8 of 8 Old 12-26-2007, 11:01 AM - Thread Starter
martyhk0's Avatar
martyhk0 is offline
