Adjusting color intensity using RGB gain/offset - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 12-30-2007, 08:34 AM - Thread Starter
johnmn's Avatar
I have an Optoma HD7100 (and it works!). But I just got a Toshiba A3 HD DVD player, and the color is too saturated. Unfortunately, the projector grays out the Color and Tint controls when you use the DVI input (stupid!!). But there is a white balance control where I can adjust rgb gain and offset. I realize that to do this right I would need a meter, but I would like to try, just to bring the color intensity down. Factory settings are 0 for each function, so there's no risk of permanently messing up anything.
I've actually improved things a bit, I think. New settings (using 6500 temp):
R gain -7
G gain -6
B gain -5
R offset -3
G offset 5
B offset 8
But I think I could do better if I understood the concept. What normally would be the proportions of these changes for bringing down color intensity/saturation? Again, I realize that this is imprecise, but I don't think the unit was perfectly calibrated anyway. And I have a pretty good eye (and it's only my own eyes that I need to please).
Any guesstimates would be much, much appreciated! (I've checked similar threads, but they just tell the writer to get a calibration. I'd really like some tips on at least trying.)
--John
johnmn is offline
post #2 of 6 Old 12-30-2007, 01:17 PM
Quoted: 40 Post(s)
Tweaking the RGB's purpose is not color tweaking whereas is to calibrate gray scale.
I have the same pj and with gray scale done.
There is a bit of red and green color saturation in stock 7100 but that cannot be fixed by RGB.
It can be solved by an external processor that actually can do HD decoding with primery and secondary calibration option.
It is all about quality. That is the picture.
JVC DLA-RS20, NEC XG-1352LC 8" CRT, 106" wide StudioTek 130 screen
CaspianM is offline
post #3 of 6 Old 12-30-2007, 01:33 PM
krasmuzik's Avatar
RGB controls change the balance of RGB that makes white - thus shifting it to one color more than the others.
If you shift RGB controls the same amount - this is identical to changing the brightness/contrast controls - which impacts the entire level of the picture.
A color control changes the level of decoded color w.r.t to the level of white - in essence it is overlayed on B&W picture. The ideal color control if pulled down completely in fact gives you a B&W picture.
So you cannot do what you want to do how you are doing it.
Try using an analog input and see if it has the video controls you need. Does no good to use the digital input if it cannot be properly calibrated. To adjust video color levels - you only need a blue filter and test DVD. If instead you are meaning the color gamut is oversaturated - that can only be fixed with the latest greatest video processors or software (see the sticky on HTPC color calibration). Turning down the video color control below what it should be will psychovisually reduce the strong color - that is the best you can do with what you have.
krasmuzik is offline
post #4 of 6 Old 12-30-2007, 01:40 PM - Thread Starter
johnmn's Avatar
Yup, I thought this was the case. I'm returning the HD DVD player--clearly any device I attach to the DVI input needs to have its own Color control. Drat!
But thanks!!
johnmn is offline
post #5 of 6 Old 12-30-2007, 01:49 PM
Quoted: 40 Post(s)
HD7100 is pretty accurate out of box. I don't know what your talking about.
CaspianM is offline
post #6 of 6 Old 12-30-2007, 04:47 PM
Quoted: 40 Post(s)
Overall color with hd dvd A1 &2 looks great w/o any tweak and it is NOT too off the way you sound. Run it with gamma 2.2 with color temp at 7000 or native.
Read some pro reviews and you will realize that even gray scale is indeed very close.
CaspianM is offline
