Wireless keyboard mouse combo for Linux? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 04-05-2009, 08:15 PM - Thread Starter
shponglefan's Avatar
Can anyone recommend a decent wireless keyboard/mouse that works well with Linux?
shponglefan is offline
post #2 of 7 Old 04-05-2009, 09:47 PM
northbear's Avatar
northbear is offline
post #3 of 7 Old 04-06-2009, 01:58 AM
mythmaster's Avatar
I love my Gyration (http://www.newegg.com/Product/Produc...82E16823172015), but some buttons on the remote aren't functional yet (most importantly, pageup / pagedn). Everything else works OOB without ANY configuration whatsoever (mouse, arrows, select, play/pause/stop/skip/ff/rew, numpad, info, back, volume, mute).
P.S. Don't always believe newegg reviewers -- I've had mine well over a year, and it's as good as new (both kb & remote/mouse), and I use them 100% of the time.
mythmaster is offline
post #4 of 7 Old 04-06-2009, 01:38 PM
newlinux's Avatar
Quoted: 27 Post(s)
For RF:
http://www.geeks.com/details.asp?Inv...RF-3&cpc=RECOM
Is relatively inexpensive. I have 2. Works well for me if you don't want to have a separate mouse.
I also have an http://www.newegg.com/Product/Produc...82E16823166079, which works well but is more expensive (and also has an integrated mouse - well, trackball).
For IR I have 2 Solidtek ack 571s (integrated mouse as well)
newlinux is offline
post #5 of 7 Old 04-06-2009, 02:46 PM
Jay_S's Avatar
I have 2 ADESSO WKB-3000UB's (the 2nd link from newlinux above), and LOVE them. But they are not the cheapest. Newegg and Buy.com trade off on who has this on sale. I bought them at different times, and the keyboards are slightly different. The older one has an L-shaped "enter" key, while the newer one doesn't.
Jay_S is offline
post #6 of 7 Old 04-06-2009, 03:24 PM
newlinux's Avatar
Quoted: 27 Post(s)
Yes it is very nice. I like it a lot... got one for a friend who wanted to hook her laptop up to her TV and control it from afar. I used it enough that I had to get one. They feel good and natural, has good range... It's in the room I need a wireless keyboard in the most...
newlinux is offline
post #7 of 7 Old 05-04-2009, 11:59 PM
iambigman's Avatar
Hi everybody, Please recommend some brand for HTPC. Thank you in advance.
iambigman is offline
Reply HTPC - Linux Chat
