mplayer-vdpau users - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-15-2009, 11:27 PM - Thread Starter
mythmaster's Avatar
This is nothing spectacular. Few people are using mplayer-vdpau from the command line, but I thought that I'd share my config with you anyway just for reference because it makes life easier.
~/.mplayer/config
Code:
# VDPAU
vo=vdpau
vc=ffmpeg12vdpau,ffh264vdpau,ffvc1vdpau,ffwmv3vdpau,
# Passthrough
ao=alsa
ac=hwac3,hwdts,
# 16:9
aspect=16:9
zoom=yes
# Fullscreen
fs=yes
mythmaster is offline
post #2 of 3 Old 05-16-2009, 06:24 AM
quantumstate's Avatar
Very similar to mine, but thanks for adding the audio. Although doesn't that lock you in? What other kinds of audio are likely common? DTS? MP3?
I don't understand why this doesn't work in /etc/mplayer/mplayer.conf .
quantumstate is offline
post #3 of 3 Old 05-16-2009, 06:46 AM - Thread Starter
mythmaster's Avatar
The comma at the end of vc and ac tells mplayer to keep looking for a suitable codec if it needs one that isn't listed. So, if you try to play a divx file with mp3, the above config will still work.
Yeah, I dunno about mplayer.conf -- apparently something has changed.
Reply HTPC - Linux Chat
