Linux Motherboard Recommendations - AVS Forum | Home Theater Discussions And Reviews
post #1 of 90 Old 08-03-2009, 12:31 PM - Thread Starter
tux99's Avatar
The motherboard is the most important component of a HTPC, especially when choosing a motherboard with built-in graphics chip and audio, therefore choosing the right one is crucial to avoid disappointment.
The following article was written to help anyone not so experienced with HTPCs and Linux to choose a well suited motherboard for their HTPC. It also includes a complete example HTPC build:
http://www.linuxtech.net/features/be...herboards.html
I hope it might be of some use to someone!
If you have a HTPC with any of the listed mobos it would be great if you could post your experience with it and Linux here in this thread.
Any comments are welcome!
My Linux news / reviews / tips+tricks / downloads web site: http://www.linuxtech.net/
tux99 is offline
post #2 of 90 Old 08-04-2009, 08:59 AM
ocZZZZ's Avatar
I have the Zotac GF9300-D-E ITX and it's working great in mythbuntu.
ocZZZZ is offline
post #3 of 90 Old 08-04-2009, 12:10 PM
zim2dive's Avatar
I realize I'm pretty low on the Linux HTPC experience scale, but after my experience with an 8200 mobo, and reading about the heat issues with 9300/9400's (moreso on the osx86 forums), at least in the uATX space, its not clear to me that an IGP mobo offers any thermal (ie. cooling, and thus case size) advantages. (for mini-ITX, it does appear one can use IGP to gain significant size advantage)
Generally speaking I think one can then (easily) buy a non-IGP (or ignore-it IGP) mobo + (more powerful) PCI GPU at less cost than the 9300/9400 mobos.
Dunno.. this could be one of those religious (ie. Intel vs. AMD) issues, in which case ignore me
zim2dive is offline
post #4 of 90 Old 08-04-2009, 12:29 PM
wnewell's Avatar
If you're using an ATX case, the ECS GF8200A at under $80 works great for me. And while the 8200 chipset gets very hot on all these boards, it has a chipset fan header and a 60mm fan can easily be added to it. Running at 1800rpm brought the temp down to 40C from about 70C. That was with 7 tuners in it. Personally, I think separate video cards for a media sever is a waste of a PCIe slot. I've got a dual tuner card in the 16x video slot and singles in the 2 1x slots.
For another frontend only box I'm using the Zotac 8200 board (under $60). I wanted an ECS GF8200SM-M3 but couldn't find any for sale here in the US.
wnewell is offline
post #5 of 90 Old 08-04-2009, 01:13 PM
jimwhite's Avatar
I'm running a 9400... WHAT heat issues?
Jim White
St. Petersburg, FL
jimwhite is offline
post #6 of 90 Old 08-04-2009, 01:18 PM
Rgb
Rgb's Avatar
Quoted: 32 Post(s)
Rgb is offline
post #7 of 90 Old 08-04-2009, 01:30 PM - Thread Starter
tux99's Avatar
I have the impression that those people that you see complaining about heat issues on forums, either have chosen very badly ventilated cases or are using some badly designed aftermarket cpu HSF (or maybe have overclocked the FSB).
When mobo manufacturers design mobos they test ventilation of the IGP or north-bridge with the AMD or Intel boxed fans. Some of the aftermarket cpu HSFs are better at cooling the cpu quietly, but they direct the airflow differently than the Intel/AMD boxed fan and therefore the IGP or north-bridge heatsink doesn't get enough ventilation anymore.
If the 9400 was too hot to be placed on a mATX mobo, how can it be placed in an tiny Acer Revo plastic case then? (the ION is basically a 9400).
70C is actually not that much for a NVidia GPU, when I look a the Nvidia thermal monitor for my passively cooled NVS290 (8400GS equivalent) on my desktop PC here, it's always around 55-60C and the temperature graph is still in the green zone. The slowdown threshold is set by Nvidia at 115C!
tux99 is offline
post #8 of 90 Old 08-04-2009, 01:39 PM - Thread Starter
tux99's Avatar
Originally Posted by Rgb View Post
The best HTPC motherboard- easy.
It's always the one you *don't* have
Very true!
But the target group of the article is primarily people who are considering building their first HTPC, not experts like you all here.
tux99 is offline
post #9 of 90 Old 08-04-2009, 11:02 PM
wnewell's Avatar
It was running 70C+ without using any video assist. I don't know how hot it gets running video assist, but I know it would get a lot hotter. I had a 60X25mm fan anyway and running it at 1800rpm is virtually silent. I like things as cool as reasonably possible. And this is my server on 24/7. I haven't put a fan on my other 8200 system yet as it's only on about 6 hours a day. I haven't even checked its chipset temp yet but will when I start running video assist on it.
wnewell is offline
post #10 of 90 Old 08-14-2009, 10:14 PM - Thread Starter
tux99's Avatar
I have now finally been able to replace the oldish 65nm "Athlon X2 5400+" with the new and much better 45nm "Athlon II X2 240" in the Example HTPC Build, as Asus has finally released a new BIOS for the M3N78-EM that supports the X2 240.
I had intended to recommend the Athlon II X2 240 from the beginning, but as Asus didn't support it yet with its BIOS, I wasn't able to until now.
tux99 is offline
post #11 of 90 Old 09-14-2009, 12:01 AM - Thread Starter
tux99's Avatar
Due to several feedback emails I received, asking for a recommendation of a IR remote for a Linux HTPC I have now also added one to the example build in the "Best Linux HTPC Motherboards" article.
tux99 is offline
post #12 of 90 Old 09-14-2009, 05:55 AM
quantumstate's Avatar
Not true. My Asus P5N7A-VM's 9300 burned like fire, even when not decoding video, until I put on it a Thermalright HR05-IFX with thermally-controlled fan. But no one listens, so I've given up trying to tell ppl. Their IGP will just burn up.
quantumstate is offline
post #13 of 90 Old 09-14-2009, 06:07 AM
mythmaster's Avatar
I listen to you, qs, I just don't buy Intel.
mythmaster is offline
post #14 of 90 Old 09-14-2009, 07:25 AM
zim2dive's Avatar
You may not.. but your best mobo article is recommending that other ppl do...
zim2dive is offline
post #15 of 90 Old 09-14-2009, 09:09 AM - Thread Starter
tux99's Avatar
Just because the northbridge feels burning hot to the touch that doesn't mean it's running out of spec. Chips have quite different average and maximum temperature specifications and most Nvidia GPUs are designed to run at high temperatures, their cut-off is around 115C!
Even some cpus are like that, remember the Pentium-M, it had a normal operating temperature of 70-75C and a cut-off around 100C.
I'm not saying that a better heatsink is useless, but it's certainly not required.
Also by replacing the factory-fitted northbridge heatsink you risk invalidating the motherboard warranty.
tux99 is offline
post #16 of 90 Old 10-24-2009, 08:02 AM
northbear's Avatar
Poking around newegg this morning and I happened to see this motherboard
DFI LP JR GF9400-T2RS
Here is a link comparing it to the ASUS P5N7A-VM
very similar board but several things that I like better
Geforce 9400 vs 9300
2 ps2 ports (for keyboard and mouse)
3 PCIE slots vs 2
Looks like a better chipset cooling with a heatpipe to additional fins close to where the exaust on most cases would be.
**edit** one more item I just noticed in the manual is that you can set the temperature the CPU fan turns on and the temp it hits max speed. This would be useful for minimizing CPU fan noise.
As far as negatives, I do not have experience with this brand (not as well know to me as ASUS) and it cost $20 more.
Any thoughts or experience with this board?
northbear is offline
post #17 of 90 Old 10-24-2009, 08:40 AM - Thread Starter
tux99's Avatar
Yes it appears to be a very nice board, but I didn't include it in the article as it was even more expensive than the excellent and very popular Gigabyte GA-E7AUM-DS2H (which now sadly has been discontinued).
tux99 is offline
post #18 of 90 Old 10-24-2009, 02:33 PM
northbear's Avatar
Reading the reviews on newegg and Tweaktown (not seen this site until today) it seem fairly average. Tweaktown reviews the Nvidia GeForce 9300 chipset using the ASUS P5N7A-VM and rates it much better.
I'll probably just keep with my plan on buying the ASUS unless there is some crazy sale on the DFI board.
post #19 of 90 Old 10-24-2009, 04:18 PM
Servicetech571's Avatar
+1 for the 8300 M3N78-EM. Works out of the box for ubuntu.
Servicetech571 is offline
post #20 of 90 Old 10-24-2009, 05:55 PM - Thread Starter
tux99's Avatar
I'm not very convinced by the level of expertise of that reviewer, some comments he makes seems to indicate to me, that all he can do is install windows and run some off the shelf windows benchmarks on it, so I don't think that review means much.
OTOH I have no experience with that board so I can't really judge it either, but if it was 30 dollars cheaper I would take it into serious consideration.
Exactly my thoughts.
tux99 is offline
post #21 of 90 Old 10-24-2009, 08:10 PM
Northbear be advised that I've run the ASUS P5N7A-VM for 5 months, and it does run beautifully, although you should put an aftermarket heatsink on the IGP like I did. (HR05-IFX)
HOWEVER twice since I've run it, I've had two events of catastrophic filesystem destruction on my SATA drives. The first time I blamed it on my use of BTRFS, but a couple days ago it destroyed my JFS on RAID10 array. I am quite sure now that it's either a hardware problem or BIOS bug, and am giving serious consideration to the Gigabyte board with 9400 (and hopefully AMD).
post #22 of 90 Old 10-24-2009, 08:22 PM - Thread Starter
tux99's Avatar
That doesn't sound good although I doubt it's a BIOS bug, as Linux doesn't make use of the BIOS during operations.
I would be interested in more details about what exactly happened, but it might be best to start a new thread for that.
tux99 is offline
post #23 of 90 Old 10-24-2009, 08:40 PM
(dammit, I can't make my psychedelic signature to work... I guess images aren't allowed, pfff)
What happened was I turned on the projector this week to find my HTPC frozen, and the drive light on solid. Nothing I did could unfreeze it, so I reset. Poof, it couldn't mount the array for /home (with 1.7TB of videos): bad superblock.
After much tearing of hair and gnashing of teeth I found that jfsutils had somehow been deinstalled. When I reinstalled it I again had access to the array. Fortunately no damage. I hadn't done anything remotely related to maintenance lately, so it's an infuriating mystery. Maybe I could have fixed BTRFS similarly, but I was too freaked out.
This is why I am moving toward a storage server for the garage, although this has shown me that RAID10 may not be the answer. I was shocked to find my filesystem unavailable, against everything I'd understood to be true about RAID10. I am alarmed, and looking for other options.
post #24 of 90 Old 10-25-2009, 05:14 AM - Thread Starter
tux99's Avatar
So I assume you run a fsck.jfs which fixed it?
The frozen state your PC got into could have been cause by anything, power spike, PSU problem, RAM problem, cpu problem, mobo problem, anything really, the fact that the filesystem needed repair in such a situation is not uncommon but no inidcation that the issue was related specifically to the mobo.
(Although that doesn't exclude that your mobo might be defective, but is certainly no indication of a general flaw of the P5N7A-VM)
Also I guess JFS proved it's reliability by not losing you any data.
Yes, having at least 2 separate copies of all important data is always a good idea, a raid only protects you from disk hardware failure.
tux99 is offline
post #25 of 90 Old 10-25-2009, 07:02 AM
Response over here, as it has more to do with my SAN.
post #26 of 90 Old 10-25-2009, 03:12 PM
Mac The Knife's Avatar
Liked: 24
The frozen state your PC got into could have been cause by anything, power spike, PSU problem, RAM problem, cpu problem, mobo problem, anything really, ...
Yeah could be anything, but I would definitely be running a long brutal RAM test if I encountered an event like that. RAM just seems to be the problem more often than the others followed by power supplies (at least that's been my experience).
And if the RAM test Passed I'd be running Prime95 for several hours to give the CPU a good workout.
I wish I had a way to test power supplies, but without the right equipment there's not any good ways to test them.
Mac The Knife is offline
post #27 of 90 Old 10-25-2009, 05:05 PM
Hm, I have more confidence in my RAM than anything else. Top-of-the-line Micron chips (Crucial). I guess it's worth checking when I have a block of time not recording. But these failures have happened months apart, so not much hope.
post #28 of 90 Old 10-25-2009, 05:16 PM
Liked: 24
^^^ Well, depending on your perspective and on the exact type of failure a "RAM" failure might actually be the motherboard's fault. For instance, if you're having timing issues, is it the RAM or the MB?
But, you'll probably never know for certain so it's much more likely you'll buy new memory sticks and try to find a set that work reliably rather than buying a new MB.
Anyway, as you said, it's really easy to run memory tests which is why it's the first thing I always try after a failure like that.
post #29 of 90 Old 10-26-2009, 12:43 AM
wnewell's Avatar
Just a note about ram. I had a box that screwed up ever time mythcomflagg ran. Running memtest passed the ram every time. I had just installed this ram no more than a month before so I started checking the bios. Voltage was at 1.8v. After finding the specs on the ram, it was rated for 1.9v. Increasing the voltage to 1.85v cured the problem. So I can tell you for a fact that memtest doesn't stress the system enough, so if your system is failing under stress, then memtest may not to find ram problems if that's the problem.
wnewell is offline
post #30 of 90 Old 10-28-2009, 07:23 PM
agent.5's Avatar
IGP GeForce 9300 and 9400 are identical. The only difference is the factory default speed. You can overclock a 9300 to a 9400 clock speed on the Asus mobo if you want. But there is no reason to do so, as 9300/9400 are not powerful enough to do Advanced 2X deinterlacing on MythTv and both can fly through Temporal 2X deinterlacing.
I use ASUS P5N7A-VM with this CPU heatsink. No additional, aftermarket IGP heatsink is required. It is pretty huge and cool the IGP chipset as well. Temperature of the IGP is 54 degree.
http://www.scythe-usa.com/product/cp...00-detail.html
agent.5 is offline
Reply HTPC - Linux Chat
