My XBMC HTPC Build - AVS Forum | Home Theater Discussions And Reviews
Old 08-05-2009, 08:08 AM - Thread Starter
Matt DeVillier's Avatar
have recently put together a few XBMC setups for customers, and wanted to share in case others were looking for a solid, works "out of the box" setup.
Micro-ATX HTPC case
Gigabyte E7AUM-DS2H mobo
Celeron E1500
2GB DDR2-800 ram
Patriot Xporter 8GB USB flash
Lite-On DVDROM
MCE-compatible remote
I also swapped the case and CPU fans for some silent ones, and installed the remote IR sensor internally.
This setup, while not the cheapest you can get, will give you flawless 1080p playback from all sources, even those not currently accelerated by VDPAU. Works "out of the box" with XBMC Live perfectly*.
* may require a one-line tweak to xorg.conf for 1080p/60 on some setups, and an update to Alsa for HDMI audio
Matt DeVillier is offline
Old 08-05-2009, 11:02 AM
tux99's Avatar
You chose the same mobo I'm recommending in my article so I certainly agree with that , but I'm concerned about the cpu: are you saying the Celeron E1500 is powerful enough for flash based HD streams displayed at 1080p?
I'd be very surprised about that!
My Linux news / reviews / tips+tricks / downloads web site: http://www.linuxtech.net/
tux99 is offline
Old 08-05-2009, 12:26 PM - Thread Starter
I've actually been using that mobo in my personal box for a year now
I haven't tried 1080p flash streams, since the box is setup as a dedicated XBMC machine and XBMC doesn't support flash. I know based on other testing it should be sufficient for 720p flash in most cases
Old 08-05-2009, 01:10 PM
Rgb
Rgb's Avatar
Quoted: 32 Post(s)
Micro-ATX HTPC case
Celeron E1500
2GB DDR2-800 ram
Lite-On DVDROM
I assume you are using the 8GB flash drive for the OS? No hard disk?
An alternative low cost mATX case for only $40 shipped-
http://3btech.net/ch70misuslmi.html
While it doesn't include a PSU and is larger, it allows full size cards and a full size standard ATX PSU, if that's important to you.
I always use low cost <$20 PSU's and have never had a problem, just be sure to use a 120mm fan for silence. Plenty to choose from-
http://3btech.net/ch550wadufan.html
http://www.geeks.com/details.asp?inv...550E12&cat=PWR
http://www.geeks.com/details.asp?inv...ACK-12&cat=PWR
http://www.geeks.com/details.asp?inv...680XBK&cat=PWR
Never tried Blue Star, but Chiefmax and Logisys have been fine for me. Just step away from A-Power
Rgb is offline
Old 08-05-2009, 02:51 PM
wnewell's Avatar
I just replaced my case in the bedroom with this one and I love it. It's actually 15.5" deep, but it fits perfect on my dresser. I got it off ebay with free shipping. And while the PSU worked fine and was pretty quiet, I did replace it with a larger one, so you might want to buy the one without the PSU for $29.95. If you need a short case, this is the one to get IMO.
http://www.newegg.com/Product/Produc...82E16811164127
wnewell is offline
Old 08-05-2009, 03:31 PM - Thread Starter
those are some good alternatives for sure. My main criteria was that the case look like it belongs in an A/V rack, which limited my options somewhat. Also, the case I used actually looks a lot better in person than the pictures on Newegg would indicate.
