VDPAU not working? xbmc sucks? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 35 Old 01-21-2010, 10:29 AM - Thread Starter
Tijs_Verwest's Avatar
My htpc consists on: pentium dual core e5300 2.60 ghz, 2 gb ddr2 800 mhz ram, zotac geforce 9300 d-e which comes with an integrated 9300 geforce of course, im running ubuntu 9.10 and im pissed as hell that my hd videos play like sh*t ! specially x264 videos! poor framerate, freezing, skipping, the audio skips , fastens =/ ...
I installed the 190.53 drivers of the video card from the nvidia site, downloaded vlc player, smplayer, and xbmc , which has the WORST results of all them !!! and makes it worse because i love the interface on xbmc and its the player i want to use mainly!
I turned on the vdpau on smplayer and xbmc but it seems it doesnt work cuz i keep getting the same pathetic results , am i doing something wrong?
Any advise ? Dont tell me is the e5300 which runs short of power, cuz i chose it over the atom because it was supossed to be way more powerful
Tijs_Verwest is offline
post #2 of 35 Old 01-21-2010, 11:30 AM
k_ross's Avatar
It doesn't sound like it's using VDPAU for some reason. After you installed the driver from the nvidia site, did you enable the driver in your /etc/X11/xorg.conf file?
And no, XBMC does not suck.
k_ross is offline
post #3 of 35 Old 01-21-2010, 11:51 AM
Kingnubian's Avatar
Quoted: 14 Post(s)
Sounds like an incorrectly installed driver.
P.S. XBMC is amazing!
GOD Is Good
Kingnubian is offline
post #4 of 35 Old 01-21-2010, 12:25 PM
tux99's Avatar
Try Mandriva 2010.0 (see the pinned thread), the Nvidia driver is included with it so you will be up and running in no time, no need to install the driver manually afterwards.
My Linux news / reviews / tips+tricks / downloads web site: http://www.linuxtech.net/
tux99 is offline
post #5 of 35 Old 01-21-2010, 02:29 PM
agent.5's Avatar
you can't just turn on smplayer, you need to use a version of mplayer that is compiled with vdpau support.
agent.5 is offline
post #6 of 35 Old 01-21-2010, 04:08 PM
shane2943's Avatar
To add to what everyone above me said, I would recommend installing the nVidia driver from the NVidia repository instead of using the installer from NVidia.com. I'm on my blackberry so I can't link to the repository. Perhaps someone can place a link in this thread?
What version of XBMC are you running? I'm running 9.11 and absolutely LOVE it. There's nothing it won't play. Movies, music, networked music, internet radio, networked movies, etc. It is a very mature and well written media suite IMO.
shane2943 is offline
post #7 of 35 Old 01-22-2010, 10:20 AM - Thread Starter
I purged the system from nvidia settings, i used:
sudo aptitude remove --purge NVIDIA-Linux-x86-190.53-pkg1.run
Then i installed the drivers via the repository but im still getting the same results, crapy playback of hd videos =(
post #8 of 35 Old 01-22-2010, 10:43 AM - Thread Starter
No i did not, i'm trying right now but what do i need to change? Here's a cap of the htpc with my monitor plugged in ( i dont have internet near the tv) , its just for reference, my tv's resolution is 1920x1080 and my monitor 1680x1050 , i dont get the values on "monitor section" HorizSync 28.0 - 33.0 VertRefresh 43.0 - 72.0 ? shouldnt it be just 60?
That would be my last option, if i do it i'll feel like im giving up
post #9 of 35 Old 01-22-2010, 01:21 PM
k_ross's Avatar
Using aptitude is not the correct way to install or uninstall the driver that you downloaded from the nvidia website. To install it, you need to make it executable, then run it, as so:
chmod +x NVIDIA-Linux-x86-190.53-pkg1.run
sudo ./NVIDIA-Linux-x86-190.53-pkg1.run
At the end of the installation process, it will ask you if you want it to create an xorg.conf file for you. Answer yes.
At this point, it should be properly installed, and MythTV should work properly. If it doesn't, please post the following:
/etc/X11/xorg.conf
/var/log/Xorg.0.log
And then run mythfrontend -v playback --logfile ~/mythfrontend.log
and post the resulting logfile.
k_ross is offline
post #10 of 35 Old 01-22-2010, 01:31 PM - Thread Starter
/etc/X11/xorg.conf
/var/log/Xorg.0.log
OK im gonna try that way , so whats the correct way to unistall then? btw i want to use xbmc not myth tv ,
post #11 of 35 Old 01-22-2010, 01:38 PM
Jsquid's Avatar
Or you could install from the nvidia PPA as linked to/discussed here:
http://www.avsforum.com/avs-vb/showt...9#post17511799
Much easier. . . .
Jsquid is offline
post #12 of 35 Old 01-22-2010, 01:41 PM
zim2dive's Avatar
Much easier. . . .
AND you can get the vdpau versions of mplayer/smplayer at the same place.
zim2dive is offline
post #13 of 35 Old 01-22-2010, 03:59 PM
waterhead's Avatar
Quoted: 17 Post(s)
I just installed the SVN version of XBMC, so that I could use my newly installed CrystalHD card (which it supports). I was quickly disappointed to find that deinterlacing is broken in the Linux version of XBMC! Without deinterlacing, you will find it very difficult to play DVD movies or recorded HDTV.
This truely SUCKS!
I don't know what the other posters find so good about XBMC, but I can't even watch my MythTV recordings with it, so it is useless to me. The deinterlacing problem was first reported back in Sept 2008, so it must not be very important to them. Looking pretty is important to them, and they spend a lot of development on that.
MythTV, and it's GUI gets a lot of knocks for not being very pretty. But it can deinterlace most mpeg files, and that is what is important!
waterhead is offline
post #14 of 35 Old 01-22-2010, 04:15 PM
quantumstate's Avatar
This truly SUCKS!
Dude.
+1
What could they be thinking...
So when you say 'MythTV recordings' do you mean H.264-AVC program stream, or transport stream, or mpeg2 of some sort, or what? IOW what is your source?
quantumstate is offline
post #15 of 35 Old 01-22-2010, 04:21 PM
waterhead's Avatar
Quoted: 17 Post(s)
Originally Posted by quantumstate View Post
Dude.
+1
Ah.. what? I was too busy looking pretty to pay attention to anything important!
So when you say 'MythTV recordings' do you mean H.264-AVC program stream, or transport stream, or what? IOW what is your source?
Just the USA HDTV OTA broadcasts, which are a form of mpeg recording.
post #16 of 35 Old 01-22-2010, 04:30 PM
It's been a while for me (and I've been drinking), but I believe OTA is mpeg2. (ATSC transport stream) If XBMC can't handle that, I'll be a monkey's uncle. (and they are fscking lame)
post #17 of 35 Old 01-22-2010, 04:46 PM
waterhead's Avatar
Quoted: 17 Post(s)
Ha Ha! I've been drinking too!
My job requires me to be On-Call for a week, every eight weeks. Being On-Call means no alcohol. As soon as I got home I was no longer On-Call, it was shot-and-beer time for me!
post #18 of 35 Old 01-22-2010, 05:04 PM
waterhead's Avatar
Quoted: 17 Post(s)
I earlier sent an email to the CrystalHD/XBMC Linux developers, and I just got a response that deinteracing support is coming, VERY SOON! I am too drunk to provide any more meaningful info on this.
This is hardware deinterlacing, using the CrystalHD card, and not the general deinterlacing, that XBMC lacks.
post #19 of 35 Old 01-22-2010, 05:13 PM
I am too drunk
Well, it is such a pleasure to deal with someone who knows the difference between to, too, and two. A relief.
Sometimes I despair for the public educational system...
post #20 of 35 Old 01-22-2010, 05:16 PM
waterhead's Avatar
Quoted: 17 Post(s)
Ha Ha Ha Ha Ha!
post #21 of 35 Old 01-22-2010, 05:24 PM
totalownership's Avatar
Quoted: 188 Post(s)
Liked: 271
Sew sad. I two no what you meen.
AT HAMMOND ROBOTICS WE'RE BRINGING THE FUTURE ... HOME
PROTOCOL 3: PROTECT THE PILOT
totalownership is offline
post #22 of 35 Old 01-22-2010, 05:28 PM
Yes brother.
post #23 of 35 Old 01-22-2010, 06:00 PM
waterhead's Avatar
Quoted: 17 Post(s)
Hay [sic] let's not get too far off topic here.
post #24 of 35 Old 01-22-2010, 06:40 PM
waterhead's Avatar
Quoted: 17 Post(s)
All this referencing to past practices has lead me to play my The Best Of Mountain CD.
I am a lost puppy now. Nantucket Sleighride is now playing, so I am now lost.
post #25 of 35 Old 01-22-2010, 06:59 PM - Thread Starter
well first things first, how do i erase the nvidia drivers the RIGHT way?
post #26 of 35 Old 01-22-2010, 07:41 PM
Good heavens, you must be nearly as old as I am.
(Which is awfully old...)
post #27 of 35 Old 01-22-2010, 08:03 PM
k_ross's Avatar
My understanding is there's no way to truly uninstall it, because the nvidia installer overwrites system libraries, and doesn't put them back on uninstall. But if you want to anyway, the command is:
sudo ./NVIDIA-Linux-x86-190.53-pkg1.run --uninstall
k_ross is offline
post #28 of 35 Old 01-22-2010, 08:20 PM - Thread Starter
Ok, ill take yor word then, by the way i tried following your steps "chmod +x NVIDIA-Linux-x86-190.53-pkg1.run
But after i enter chmod +x NVIDIA-Linux-x86-190.53-pkg1.run it says it cannot be accessed , the directory does not exists =/
post #29 of 35 Old 01-23-2010, 01:46 AM
k_ross's Avatar
I guess the obvious question, does the file exist in the current directory when you're running the command?
k_ross is offline
post #30 of 35 Old 01-23-2010, 10:08 AM
tji
tji's Avatar
I have been trying various options for playback of my DVD library. XBMC looks like a good option, but it crashes for me when I try to play any videos.
I have had better luck with Boxee. It works reliably. The main problem I have with Boxee is the lack of deinterlacing.
System: Acer Aspire Revo (Atom+Ion single core)
OS: MythBuntu 9.10
Working Apps (with VDPAU): MythTV Frontend works great (except for DVD playback), Boxee works well (except for deinterlacing)
tji is offline
Reply HTPC - Linux Chat
