Making .mkv's from DVD's and BD's on Linux - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 05-11-2010, 10:11 AM - Thread Starter
tux99's Avatar
Originally Posted by mythmaster View Post
If it can rip a blu-ray straight into MKV then I will ditch my copy of AnyDVD and never look back.
You can definitely do that with the Linux version of MakeMKV, I don't know if DVDFab 7 does that too, haven't tried 7 yet.
My Linux news / reviews / tips+tricks / downloads web site: http://www.linuxtech.net/
tux99 is offline
post #2 of 16 Old 05-11-2010, 05:15 PM
mythmaster's Avatar
Yeah, I don't want it to be transcoded either. I just want the raw main movie and audio tracks put into a MKV. It would be pretty awesome if they could throw in the chapters info from the playlist file, too.
It's easy enough to do all of this manually, but a one-click solution would make my day.
mythmaster is offline
post #3 of 16 Old 05-11-2010, 05:49 PM - Thread Starter
tux99's Avatar
So have you tried MakeMKV yet? That's exactly what it does, including chapters.
http://www.makemkv.com/forum2/viewtopic.php?f=3&t=224
tux99 is offline
post #4 of 16 Old 05-11-2010, 06:09 PM
mythmaster's Avatar
Yes, that's what I meant by "easy enough to do all of this manually". It takes another software (can't remember the name right now) to open the bluray .pls file so you can see the chapters.
I did all of this on my NOTLD MKV uploads to archive.org. I also included the MKV chapters text file in case you want to make your own. http://www.archive.org/details/Night...ing.Dead_1080p
post #5 of 16 Old 05-11-2010, 06:19 PM
mythmaster's Avatar
P.S. The last I checked -- the MKV container didn't support the m2ts format. Hopefully, that has changed or will change.
post #6 of 16 Old 05-11-2010, 06:53 PM
Rgb
Rgb's Avatar
Quoted: 32 Post(s)
Yes but to mobile means transcoded, I doubt mythmaster wants it transcoded, I certainly don't, I simply want it re-muxed to MKV like MakeMKV does.
Whats' the typical size of a BluRay movie remuxed into an .mkv container with one or two (main audio + one commentary for example) audio tracks without transcoding?
DOes MakeMKV allow splitting the file into smaller chunks, like 25GB, 8GB or 4.3GB parts as it writes the .mkv?
Rgb is offline
post #7 of 16 Old 05-11-2010, 07:11 PM
mythmaster's Avatar
I'm not sure why you would want to split it except for storage concerns; but, yes, a blu-ray rip can go up to 50GB, but this isn't typical. The ones that I have done have been less or half of that. My NOTLD rip is only 16GB.
post #8 of 16 Old 05-11-2010, 08:25 PM - Thread Starter
tux99's Avatar
I think you are confusing MakeMKV with MKVmerge.
MakeMKV does the ripping and re-muxing into MKV (including any audio, video and subtitle tracks you select) completely automatically in one step.
No need for any additional external software.
MKVmerge on the other hand does neither the ripping nor the chapter file, it only muxes whatever raw video audio and chapter files you already have into a MKV.
tux99 is offline
post #9 of 16 Old 05-11-2010, 08:27 PM - Thread Starter
tux99's Avatar
M2TS is a container format just like MKV, so I'm not sure what exactly you were trying to say?
did you maybe mean that MKVmerge doesn't support the M2TS format as source? That might well be (can't remember) but MakeMKV is the tool for this, not MKVmerge.
tux99 is offline
post #10 of 16 Old 05-11-2010, 08:31 PM - Thread Starter
tux99's Avatar
Around 20GB could be less or more, depends on the length of the movie and the bitrate of the original.
Don't know, never tried that, why? Do you want back up your MKVs to DVD-R/BD-R?
What's the point in that, buying a 2TB hard disk as back-up is much cheaper per GB.
tux99 is offline
post #11 of 16 Old 05-11-2010, 08:33 PM
mythmaster's Avatar
I'm saying that you can't mux a M2TS video file into a MKV container. Maybe this has changed, though. I hope that it has.
post #12 of 16 Old 05-11-2010, 08:34 PM - Thread Starter
tux99's Avatar
Ok, see my edit above. MKVmerge is not Makemkv.
tux99 is offline
post #13 of 16 Old 05-11-2010, 10:07 PM
mythmaster's Avatar
So, are you saying that Makemkv supports adding M2TS video files to an MKV container? I will fly to England and hug you if it does! :P
post #14 of 16 Old 05-11-2010, 10:29 PM - Thread Starter
tux99's Avatar
No Makemkv rips and converts a BD disk directly into a MKV (with audio and subtitle tracks of your choice and chapter info), no need to have an intermediate M2TS file.
And I'm nowhere near England!
tux99 is offline
post #15 of 16 Old 05-11-2010, 11:01 PM
mythmaster's Avatar
LOL, OK thanks, I'll give it a try. You have avoided an *international hug* THIS TIME.
But, you really should warn your wife and children that I may come a-hugging in the future. I'm just sayin'. I really do hug people as much as I possibly can. Expect that.
post #16 of 16 Old 05-12-2010, 06:14 PM
Rgb
Rgb's Avatar
Quoted: 32 Post(s)
Place to discuss making .mkv's from DVD's and BD's, either remuxing and/or transcoding/reencoding.
PLease keep discussion howto in nature- secific tools and methods appreciated!
Rgb is offline
Reply HTPC - Linux Chat
