Hi - I'm new here! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 06-17-2010, 02:52 PM - Thread Starter
irod728's Avatar
Hi everyone.
I've been reading this forum the last few weeks and picked up lots of useful information. This place is a great resource. It got me excited enough that I decided to make the plunge. We had some older Dell Optiplex desktops just gathering dust at work. My boss was kind enough to let me take one home when I asked. The specs are:
Intel Pentium D @ 3.8 ghz with hyperthreading Socket 755
40 Gig hard disk
1 gig of Ram
The video is Intel's integrated GMA 950with a whopping 8 mb of memory.
I bought a $6 miniplug to RCA adapter and plugged it in to my receiver's Aux input from the PC's integrated sound card.
The ram was upgraded to 2 GB and the disk to a terabyte. I loaded the latest Ubuntu 10.04 and I'm able to view all file formats, dvds. 1080p MKV files drop frames badly. They are mostly un-viewable.
So now I have been bitten by the upgrade and build bug. I would like a mini-itx solution. I am undecided if I should go with a Intel Atom and Nvidia Ion2 board or use my current CPU, RAM and get this board from Zotac.
It is Newegg item=N82E16813500041. I don't have enough posts to place a URL yet.
What are your recommendations?
BTW - Thank you RGB for your tutorials. They convinced me to use Ubuntu over Windows 7. I liked it so much I changed my main home machine to Ubuntu as well from Win7. It has come a long way since V5, which was the last version I had used. I can't remember why I went back to Windows.
irod728 is offline
post #2 of 7 Old 06-17-2010, 03:17 PM
darkphoenix22's Avatar
Get a graphics card that supports VDPAU.
http://en.wikipedia.org/wiki/Nvidia_..._.28HD.29_GPUs
Other than that you should be fine. That ION mobo is a good choice as its graphics chip supports VDPAU.
darkphoenix22 is offline
post #3 of 7 Old 06-17-2010, 04:12 PM
tux99's Avatar
Yeah, if the Dell has a PCIe x16 slot then the cheapest solution would be a Nvidia 210 graphics card.
Else that Zotac mobo would do too, but you might want to underclock that cpu if you use the Zotac mobo, as a 3.8GHz Pentium D will be hard to keep cool in a small ITX case (what's the TDP, 130W?)...
My Linux news / reviews / tips+tricks / downloads web site: http://www.linuxtech.net/
tux99 is offline
post #4 of 7 Old 06-17-2010, 05:04 PM
mythmaster's Avatar
Welcome aboard!
I wouldn't try to do anything with that Optiplex other than putting it in a closet somewhere and using it as a fileserver and possibly mythbackend. I've worked on tons of those, and they have a proprietary motherboard and case. Plus, those Pentium D's run crazy hot and loud.
The IONs are awesome, but the only drawback is that the Atom CPU's (even the dual-core ones) aren't quite beefy enough to handle Flash video in Linux.
mythmaster is offline
post #5 of 7 Old 06-17-2010, 06:21 PM
mythmaster's Avatar
I forgot to mention that the Pentium D mobos are mounted to the wrong side of the case, too. So you wouldn't be able to replace it anyway -- even if it didn't have the proprietary front panel connector.
post #6 of 7 Old 06-21-2010, 01:04 PM
Rgb
Rgb's Avatar
Quoted: 32 Post(s)
Originally Posted by irod728 View Post
Hi everyone.
You're welcome
Posts like that motivate me to continue contributing
re: recommendations-
If you want to minimize cost, you could silence the CPU cooler in the Optilex with an aftermarker cooler, though I don't know what would fit in the proprietary Optiplex case. I am partial to Arctic Cooling products.
It you want to go mini-ITX, I would get a miniITX AM2+/AM3 motherboard and put a low cost AMD 2.8+ GHz X2 CPU in there.
Just search Newegg for miniITX, socket AM2+/AM3 boards. Be sure it has a full PCIe slot and room for an Nivdia 210 card, passively cooled and with low profile brackets included if you want a low profile case.
Rgb is offline
post #7 of 7 Old 06-21-2010, 02:48 PM - Thread Starter
irod728's Avatar
Hi RGB!
You must have been reading my mind. I noticed that going with a new AMD CPU and mobo combination was only going to be slightly more expensive than using the existing Intel CPU. So I just ordered a
- Gigabyte micro ATX motherboard.
- AMD 3 Ghz dual core CPU at 65 watts
- Asus Geforce 210 1 GB low pro file card. It's fanless!
- hec media center case with 300w power supply.
The whole thing came out to less than $240 from New Egg.
I'll be reusing the RAM and new hard drive.
I can't wait to put this together! Now I have to start looking for a new HDMI receiver. I got my eye on a Denon AVR-1910.
irod728 is offline
Reply HTPC - Linux Chat
