Getting Video Output if HTPC is Restarted without TV On - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-28-2010, 01:21 PM - Thread Starter
drkdiggler's Avatar
Hi all, in a move to minimize my waste (and to have another reason to tinker with my HTPC ), I am moving my HTPC to utilize standby. The main issue that has prevented me from making the move is that my display settings work perfectly as long as the HTPC is booted while the TV is on. If I boot with the TV off, the HTPC does not send a signal over HDMI.
I am currently running an Acer Aspire Revo 1600 with XBMC 9.11 installed. I currently run at 1080p using the following xorg.conf:
Code:
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig:  version 1.0  (buildmeister@builder75)  Tue Dec  8 21:04:28 PST 2009
Section "ServerLayout"
    Identifier     "Layout0"
    Screen      0  "Screen0"
    InputDevice    "Keyboard0" "CoreKeyboard"
    InputDevice    "Mouse0" "CorePointer"
EndSection
Section "Files"
EndSection
Section "InputDevice"
    # generated from default
    Identifier     "Mouse0"
    Driver         "mouse"
    Option         "Protocol" "auto"
    Option         "Device" "/dev/psaux"
    Option         "Emulate3Buttons" "no"
    Option         "ZAxisMapping" "4 5"
EndSection
    Identifier     "Keyboard0"
    Driver         "kbd"
EndSection
Section "Monitor"
    Identifier     "Monitor0"
    VendorName     "Unknown"
    ModelName      "Unknown"
    HorizSync       14.0 - 70.0
    VertRefresh     24.0 - 62.0
    Modeline    "1920x1080@60p"    148.500 1920 2008 2056 2200 1080 1084 1089 1125 +hsync +vsync
    Modeline    "1920x1080@24p"     74.230 1920 2560 2604 2752 1080 1084 1089 1125 +hsync +vsync
EndSection
Section "Device"
    Identifier     "Device0"
    Driver         "nvidia"
    VendorName     "NVIDIA Corporation"
    Option "DynamicTwinView" "False"
    Option "TripleBuffer" "True"
EndSection
Section "Screen"
    Identifier     "Screen0"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
    Option         "NoLogo" "True"
    Option         "TwinView" "False"
    Option         "AddARGBGLXVisuals" "True"
    Option         "UseEDIDFreqs" "False"
    Option         "ExactModeTimingsDVI" "True"
    Option         "ModeValidation" "NoEdidModes, NoMaxPClkCheck, NoEdidMaxPClkCheck, AllowNon60HzDFPModes"
    SubSection     "Display"
        Depth       24
        Modes       "1920x1080@60p" "1920x1080@24p"
    EndSubSection
EndSection
Section "Extensions"
    Option "Composite" "Disable"
EndSection
So, I'd really appreciate any input into getting the display to work properly, even when the HTPC isn't booted with the TV on.
drkdiggler is offline
post #2 of 5 Old 06-28-2010, 02:41 PM
Lost Dog's Avatar
Quoted: 28 Post(s)
You could try dumping the EDID using the nvidia control panel then calling that file in your xorg.conf. Here is the line I use:
Code:
    Option         "ConnectedMonitor" "DFP-0"
    Option         "CustomEDID" "DFP-0:/etc/X11/55SV670u.edid"
This is in the "screen" section.
Lost Dog is offline
post #3 of 5 Old 06-28-2010, 03:13 PM
almostinsane's Avatar
Quoted: 47 Post(s)
Liked: 42
Well you can always throw money at the problem. A Gefen HDMI or DVI Detective will solve this. I have one installed between my HTPC and Receiver. It does exactly what you want it to do.
almostinsane is offline
post #4 of 5 Old 06-28-2010, 04:25 PM
BullwinkleMoose's Avatar
You could always TRY following the instructions in this post - for some reason it seems to cure a lot of ills:
http://forum.xbmc.org/showthread.php?t=70068
Also see this post - you'll have to scroll about three-fifths of the way down the page to get to where they start talking about video, but there's a few extra setting there that may or may not be important:
http://michigantelephone.wordpress.c...r-aspire-revo/
I only mention these because they are what I used when setting up my Revo and I do not have the problem you are experiencing, although I know others do. I think it has a lot to do with what you put in xorg.conf - if you get that exactly right then you won't have the problem, but getting it right can be VERY tricky. One thing I note is that you may have some things in the "Screen" section that ought to be in the "Monitor" section, and vise versa. So if you use the information in those links, it should give you a correct xorg.conf to work with, and that may solve your problem.
BullwinkleMoose is offline
post #5 of 5 Old 06-29-2010, 11:05 PM - Thread Starter
drkdiggler's Avatar
Lost Dog:
I ended up going with your suggestion and it worked perfectly! Getting nvidia-settings to run in XBMC Live was a bit of a pain, but after I got the EDID file everything was a cakewalk. Thank you everyone.
Reply HTPC - Linux Chat
