Installing Nvidia drivers in Ubuntu - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 05-17-2011, 01:16 PM - Thread Starter
AcuraCL's Avatar
Wow. What a nightmare. Trying to get NVIDIA drivers installed in Ubuntu 10.04. Is there a good comprehensive set of instructions anywhere on how to do this ... one that does not assume that you know how to stop x-windows? Or even log in as root. Seriously. I can't even tell if its possible to log in as root. Half the Google results say you can't.
I want to make this work, but why in god's name can't this be a wee bit easier?
AcuraCL is offline
post #2 of 8 Old 05-17-2011, 01:28 PM
Jsquid's Avatar
Have you tried installing the NVIDIA drivers from the "hardware drivers" panel in the 'administration' drop down menu?
Jsquid is offline
post #3 of 8 Old 05-17-2011, 01:32 PM - Thread Starter
AcuraCL's Avatar
Yes, it says there are no proprietary drivers available.
AcuraCL is offline
post #4 of 8 Old 05-17-2011, 01:41 PM
Jsquid's Avatar
what GPU are you using? I have an older GeForce 8200 GPU and it found the drivers just fine.
Jsquid is offline
post #5 of 8 Old 05-17-2011, 02:00 PM - Thread Starter
AcuraCL's Avatar
Galaxy Gt430
AcuraCL is offline
post #6 of 8 Old 05-17-2011, 02:20 PM
Jsquid's Avatar
I should have pointed you here first. Try the howto in the first post of this thread:
http://www.avsforum.com/avs-vb/showt...talling+nvidia
You can probably skip all the VDPAU stuff.
Good luck.
Jsquid is offline
post #7 of 8 Old 05-17-2011, 02:56 PM - Thread Starter
AcuraCL's Avatar
Thanks a lot Jsquid ... I'll give those instructions a try.
AcuraCL is offline
post #8 of 8 Old 05-17-2011, 03:16 PM
Jsquid's Avatar
You're welcome. The other thing you could try (and this might be easier) is adding the NVIDIA PPA and then installing the proprietary drivers from there.
See:
http://www.avsforum.com/avs-vb/showt...a#post17699651
I am not sure if the PPA is still up to date.
Jsquid is offline
Reply HTPC - Linux Chat
