Does anybody know what is going on with ffmpeg and hd audio bitstreaming? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 32 Old 07-01-2011, 04:19 AM
waterhead's Avatar
Quoted: 17 Post(s)
Last night I installed ffmpeg from a GIT pull (SVN is no longer used). I still don't see anything in ffplay that suggests bitstreaming audio.
Code:
$ ffplay -bsfs
ffplay version N-31097-ga099183, Copyright (c) 2003-2011 the FFmpeg developers
  built on Jun 30 2011 18:44:27 with gcc 4.4.3
  configuration: --enable-bzlib --enable-libdc1394 --enable-libdirac --enable-libfaac
--enable-libgsm --enable-libmp3lame --enable-libopenjpeg --enable-libschroedinger
--enable-libspeex --enable-libtheora --enable-libvorbis --enable-libx264 --enable-libxvid
--enable-zlib --enable-gpl --enable-nonfree --enable-version3
  libavutil    51. 11. 0 / 51. 11. 0
  libavcodec   53.  7. 0 / 53.  7. 0
  libavformat  53.  4. 0 / 53.  4. 0
  libavdevice  53.  2. 0 / 53.  2. 0
  libavfilter   2. 24. 0 /  2. 24. 0
  libswscale    2.  0. 0 /  2.  0. 0
  libpostproc  51.  2. 0 / 51.  2. 0
Bitstream filters:
text2movsub
remove_extra
noise
mov2textsub
mp3decomp
mp3comp
mjpegadump
mjpeg2jpeg
imxdump
h264_mp4toannexb
dump_extra
chomp
aac_adtstoasc
waterhead is offline
post #32 of 32 Old 07-01-2011, 04:43 PM
waterhead's Avatar
Quoted: 17 Post(s)
I don't know about ffmpeg, but it looks like you can do audio bistreaming via aplay.
http://phoronix.com/forums/showthrea...nux#post158212
http://www.nvnews.net/vbulletin/show....php?p=2353082
http://thread.gmane.org/gmane.comp.v...g.devel/121073
It looks like you need a 2.6.36 kernel, or to patch the one you have.
For ffmpeg, you may have to patch that:
http://www.phoronix.com/scan.php?pag...item&px=ODgyOA
I may have found something HERE:
Hi all!
Here is a patchset implementing TrueHD, DTS-HD, and E-AC3 support in our
IEC 61937 muxer, allowing HDMI passthrough of those formats. The E-AC3
and TrueHD ones are partially based on the earlier work of Carl Eugen
Hoyos and myself, while I only just got DTS-HD working.
I don't see that muxer listed as a configure option in my latest ffmpeg source:
Code:
~/ffmpeg$ ./configure --list-muxers
a64                     ipod                    pcm_s16be
ac3                     ivf                     pcm_s16le
adts                    libnut                  pcm_s24be
aiff                    m4v                     pcm_s24le
amr                     matroska                pcm_s32be
asf                     matroska_audio          pcm_s32le
asf_stream              md5                     pcm_s8
ass                     microdvd                pcm_u16be
au                      mjpeg                   pcm_u16le
avi                     mlp                     pcm_u24be
avm2                    mmf                     pcm_u24le
caf                     mov                     pcm_u32be
cavsvideo               mp2                     pcm_u32le
crc                     mp3                     pcm_u8
daud                    mp4                     psp
dirac                   mpeg1system             rawvideo
dnxhd                   mpeg1vcd                rm
dts                     mpeg1video              roq
dv                      mpeg2dvd                rso
eac3                    mpeg2svcd               rtp
ffm                     mpeg2video              rtsp
ffmetadata              mpeg2vob                sap
filmstrip               mpegts                  sox
flac                    mpjpeg                  spdif
flv                     mxf                     srt
framecrc                mxf_d10                 swf
framemd5                null                    tg2
g722                    nut                     tgp
gif                     ogg                     truehd
gxf                     pcm_alaw                vc1t
h261                    pcm_f32be               voc
h263                    pcm_f32le               wav
h264                    pcm_f64be               webm
image2                  pcm_f64le               yuv4mpegpipe
image2pipe              pcm_mulaw
Maybe it still needs to be patched first.
Reply HTPC - Linux Chat
