Budget Mythtv build - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-24-2011, 06:40 PM - Thread Starter
gehre's Avatar
Would any one care to comment on this htpc build. I want to use it to serve OTA TV over a simple network using mythtv. So the build does include a full size TV Tuner card. I also want to reuse a hard drive from another build. I chose a low-power cpu to save on energy costs. Here is the link: Attachment 226123 (word attachment)
Thanks for your input!
build-1.doc 17.5k . file
gehre is offline
post #2 of 3 Old 10-25-2011, 08:59 AM
sysadmin's Avatar
Quoted: 25 Post(s)
As someone mentioned in another thread, the only concern would be the current state of the Intel video drivers, so you'd want to look into that.
sysadmin is offline
post #3 of 3 Old 10-25-2011, 04:05 PM - Thread Starter
gehre's Avatar
Sysadmin,
Makes sense b/c linux can be hard to match drivers with hardware.
This link from the MythTV Wiki has a page with a discussion on Intel drivers. The specs of the Intel board/processor say that it's using the Intel GMA 3150.
This link: http://www.mythtv.org/wiki/Intel_Integrated_Graphics Discusses compatibility of Intel GMA, but not the 3150 series specifically.
I'll repost if I find other confirming info.
Gehre
gehre is offline
Reply HTPC - Linux Chat
