HDMI audio config for mythbuntu 11.10? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 33 Old 12-11-2011, 09:38 AM - Thread Starter
devoz's Avatar
Well after trouble with two Grubs...in installing Mythbuntu 11.10
I have it running ..at least the desktop anyway
Now I am trying to get audio working again via the
Nvidia HDMI sound.
So unlike Mint this has no sound area for configuration(unless I have missed it??)
How can I configure it to use alsa..and find the right Nvidia outlet?
Here are two terminal outputs...
first is... aplay -L
null
Discard all samples (playback) or generate zero samples (capture)
default:CARD=Intel
HDA Intel, AD198x Analog
Default Audio Device
front:CARD=Intel,DEV=0
Front speakers
surround40:CARD=Intel,DEV=0
4.0 Surround output to Front and Rear speakers
surround41:CARD=Intel,DEV=0
4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=Intel,DEV=0
5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=Intel,DEV=0
5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=Intel,DEV=0
7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
iec958:CARD=Intel,DEV=0
HDA Intel, AD198x Digital
IEC958 (S/PDIF) Digital Audio Output
dmix:CARD=Intel,DEV=0
Direct sample mixing device
dmix:CARD=Intel,DEV=1
dsnoop:CARD=Intel,DEV=0
Direct sample snooping device
dsnoop:CARD=Intel,DEV=1
hw:CARD=Intel,DEV=0
Direct hardware device without any conversions
hw:CARD=Intel,DEV=1
plughw:CARD=Intel,DEV=0
Hardware device with all software conversions
plughw:CARD=Intel,DEV=1
hdmi:CARD=NVidia,DEV=0
HDA NVidia, HDMI 0
HDMI Audio Output
hdmi:CARD=NVidia,DEV=1
HDA NVidia, HDMI 0
HDMI Audio Output
hdmi:CARD=NVidia,DEV=2
HDA NVidia, HDMI 0
HDMI Audio Output
hdmi:CARD=NVidia,DEV=3
HDA NVidia, HDMI 0
HDMI Audio Output
dmix:CARD=NVidia,DEV=3
HDA NVidia, HDMI 0
dmix:CARD=NVidia,DEV=7
HDA NVidia, HDMI 0
dmix:CARD=NVidia,DEV=8
HDA NVidia, HDMI 0
dmix:CARD=NVidia,DEV=9
HDA NVidia, HDMI 0
dsnoop:CARD=NVidia,DEV=3
HDA NVidia, HDMI 0
dsnoop:CARD=NVidia,DEV=7
HDA NVidia, HDMI 0
dsnoop:CARD=NVidia,DEV=8
HDA NVidia, HDMI 0
dsnoop:CARD=NVidia,DEV=9
HDA NVidia, HDMI 0
hw:CARD=NVidia,DEV=3
HDA NVidia, HDMI 0
hw:CARD=NVidia,DEV=7
HDA NVidia, HDMI 0
hw:CARD=NVidia,DEV=8
HDA NVidia, HDMI 0
hw:CARD=NVidia,DEV=9
HDA NVidia, HDMI 0
plughw:CARD=NVidia,DEV=3
HDA NVidia, HDMI 0
plughw:CARD=NVidia,DEV=7
HDA NVidia, HDMI 0
plughw:CARD=NVidia,DEV=8
HDA NVidia, HDMI 0
plughw:CARD=NVidia,DEV=9
HDA NVidia, HDMI 0
devoz is offline
post #2 of 33 Old 12-11-2011, 09:41 AM - Thread Starter
devoz's Avatar
next here is aplay -l
looks same as under Mint obviously...
**** List of PLAYBACK Hardware Devices ****
card 0: Intel [HDA Intel], device 0: AD198x Analog [AD198x Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: Intel [HDA Intel], device 1: AD198x Digital [AD198x Digital]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 7: HDMI 0 [HDMI 0]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 8: HDMI 0 [HDMI 0]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 9: HDMI 0 [HDMI 0]
Subdevices: 1/1
devoz is offline
post #3 of 33 Old 12-11-2011, 09:42 AM - Thread Starter
devoz's Avatar
and using ...cat /proc/asound/devices
it looks same as under mint
1: : sequencer
2: [ 0- 1]: digital audio playback
3: [ 0- 1]: digital audio capture
4: [ 0- 0]: digital audio playback
5: [ 0- 0]: digital audio capture
6: [ 0- 0]: hardware dependent
7: [ 0] : control
8: [ 1- 9]: digital audio playback
9: [ 1- 8]: digital audio playback
10: [ 1- 7]: digital audio playback
11: [ 1- 3]: digital audio playback
12: [ 1- 3]: hardware dependent
13: [ 1- 2]: hardware dependent
14: [ 1- 1]: hardware dependent
15: [ 1- 0]: hardware dependent
16: [ 1] : control
33: : timer
devoz is offline
post #4 of 33 Old 12-11-2011, 09:43 AM - Thread Starter
devoz's Avatar
so where do I configure sound under Mythbuntu?
or can it only be done in Myth set-up?
devoz is offline
post #5 of 33 Old 12-11-2011, 10:04 AM
Lost Dog's Avatar
Quoted: 28 Post(s)
Do you see the option to scan for audio devices under mythfrontend setup? Can you select HDMI audio there? It may show many different options so it may take some trial and error....
Lost Dog is online now
post #6 of 33 Old 12-11-2011, 12:28 PM
waterhead's Avatar
Quoted: 17 Post(s)
Do you have sound outside of MythTV? What Desktop environment are you using?
In Gnome, you can access sound settings from the menu:
System-->Preferences-->Sound
It can also be accessed by clicking the "Speaker" icon in the task bar, and selecting "Sound Preferences".
Or by typing this into the terminal:
gnome-volume-control
But, I think Mythbuntu uses a different Desktop environment, so I doubt if any of these will work.
waterhead is offline
post #7 of 33 Old 12-11-2011, 12:53 PM
waterhead's Avatar
Quoted: 17 Post(s)
Subdevices: 1/1
Subdevices: 1/1
Subdevices: 1/1
Subdevices: 1/1
Subdevices: 1/1
Subdevices: 1/1
Ok, you have four HDMI outputs. Which one are you using?
To test the outputs, use the speaker-test command. Here are the devices to test:
card1,device3
card1,device7
card1,device8
card1,device9
Test them with this command. White noise will be generated during the test, and use the -c option to tell it how many channels:
Code:
speaker-test -c2 -Dplughw:1,3
speaker-test -c2 -Dplughw:1,7
speaker-test -c2 -Dplughw:1,8
speaker-test -c2 -Dplughw:1,9
When you find the one that works, you can enter that into the MythTV audio setup page. You may need to use the term "ALSA" preceeding it:
Code:
ALSA plughw:1,3
post #8 of 33 Old 12-11-2011, 04:04 PM
kenyee's Avatar
And FYI, Myth 0.25 finds all the alsa outputs better than it did for me w/ 0.24 (the default w/ the current Mythbuntu).
I posted about it a bit lower in setting up Sandy Bridge.
kenyee is offline
post #9 of 33 Old 12-11-2011, 07:31 PM - Thread Starter
devoz's Avatar
I installed SMplayer...as from what I have read its the best...
most flexible player(ie many options..including codecs)
...so after playing with the graphic of alsamixer(ie F6)
under terminal
and selecting Nvidia HD audio...
and then selecting device 7...ie as in this one below
from within both VLC and then SMplayer...I was able to get 5.1
multi-channel PCM(via my GT220)..to my Onkyo AV receiver.
But there is no sound when using desktop..just in these players
devoz is offline
post #10 of 33 Old 12-11-2011, 07:41 PM - Thread Starter
devoz's Avatar
card1,device3
card1,device7
card1,device8
card1,device9
Code:
Code:
ALSA plughw:1,3
Yep that was what I did in previous installation under Mint 12...didnt seem to work in the ubuntu desktop part of Mythbuntu.
That was the good part of Mint ..
under sound it had a gui for speaker test..much more user friendly!!
and it worked..once I had the sound going via NVIDIA device.
I must say I was busy in MthTV backend and front end last night
trying to get TV working ..sort of working now..but at moment
not near looking like Mediaportal(under win 7)
...and I didnt see any audio set-up there
I will take another look in my next three hour session
with this software
devoz is offline
post #11 of 33 Old 12-11-2011, 08:06 PM - Thread Starter
devoz's Avatar
Yep from what I can see MythTV
is where you change all these things...
there appears to be no sound area under System
in the ubuntu desktop..of Mythbuntu
Still... using alsamixer in terminal(I think this is what did it)
and changing sound settings in SMplayer...
I was able to watch Terminator Salvation..
in glorious 5.1 surround sound last night..
..and although the picture did freeze a few times during playback
..the picture looked as good as my Window 7 set-up.
devoz is offline
post #12 of 33 Old 12-11-2011, 09:11 PM
waterhead's Avatar
Quoted: 17 Post(s)
Does Mythbuntu use Pulse audio? If so, you should install the Pulse Audio Volume Control.
Code:
sudo apt-get install pavucontrol
Run it, and on the last tab click on the Internal Audio Profile dropdown list. You should find the audio options that you are looking for.
post #13 of 33 Old 12-12-2011, 10:41 AM - Thread Starter
devoz's Avatar
Code:
From what I have read with the latest version
of ALSA...which Mythbuntu 11.10 has...and that is version 1.0.24
it appears to handle outputting audio via HDMI better.
It is one reason why I have not installed Linux before...because
ease of set-up of HDMI audio seemed either problematic..or not well explained. Unfortunately in many Linux forums you see the horror stories of set-up
and not the successful ones..ie how to actually get something working.
Also while commandline is powerful..it takes a while to get enough confidence and knowledge to have any idea what one is doing...and not simply stuff up..any initial installation.
Being a Linux newbie..there are enough unknown things without
having to blindly search about for audio set-up answers.
I am slowly coming to understand some of the Linux stuff..
like this modular business..in this case for audio under
ALSA. Also what the output in terminal actually mean!
Pulse from what I have seen is more about control...
I dont need control..I need players like VLC and SM player..
and MythTV to output sound via the HDMI to my AV receiver
Pulse maybe already installed..I havent checked
anyway I still havent worked out how to look at .conf files yet!
So as I said I have sound via VLC and SMplayer...and its Multi channel PCM
...which is what my NVIDIA GT220 supports.
I am still recovering from the useless way the Mythbuntu install disc managed to install a Grub somehow on my storage disc drive...
even though I chose my OS drive(all to do with sda and sdb)
So now I have it back (my OS) by actually swapping Sata connectors...
to change the sda and sdb...and get past this two grubs
and actually get into setting up MythTV..
rather than be stuck on stupid OS issues!!
If I sound upset..yes
cause I aint interested in the intricacies of Linux..
I am trying to get a stable working PVR on my HTPC
At least now I have installed Linux and MythTV..(apart from Live Disc tinkering my only Linux experience)
so its a matter of over the next few weeks
seeing if I can get to grips with MythTV set-up and
get it working right...especially with my Hauppauge RC6 remote-control
The main reason I look and write at this forum
is because I hope to learn(and hopefully contribute)
how to set-up my Home Theatre PC with Linux and MythTV...
and actually use it for TV/Movies/Music!
After all this is the... Linux area... of... Home Theatre Computers
The guides here(Thanks Rgb) and answers have certainly helped in
giving me confidence to actually leave the safe confines of Windows 7
..and delve into Linux/buntu and its MythTV addon.
devoz is offline
post #14 of 33 Old 12-12-2011, 01:30 PM
waterhead's Avatar
Quoted: 17 Post(s)
Pulse audio is a sound server, and is the default sound handler in most major Linux distributions. If you want Desktop sound, you are going to have to configure it. You are making thing much more difficult by trying to work around it.
As for the sound quality of Pulse, I never heard anything about it being worse than Alsa. Digital is all bits, so it must be the same. Alsa is still there running the sound. You will see the Alsa modules are loaded.
post #15 of 33 Old 12-13-2011, 02:22 AM - Thread Starter
devoz's Avatar
Trying to do some reading ..to understand more how linux deals with sound
and more specifically ..MythTV deals with sound
I came across this Wiki page...
http://www.mythtv.org/wiki/Configuring_Digital_Sound
it seems to suggest that MythTV doesnt support Pulse audio?
I understand what you are saying about..if you want sound on your Desktop
then you need something like Pulse...
devoz is offline
post #16 of 33 Old 12-13-2011, 03:08 AM - Thread Starter
devoz's Avatar
How does one look at the
/etc/asound.conf
area?
ie I assume I use a command in terminal..?
devoz is offline
post #17 of 33 Old 12-13-2011, 07:00 AM
Lost Dog's Avatar
Quoted: 28 Post(s)
I believe it does support pulse but it's highly recommended to not use it. I found that MythTV worked on my system with Pulse removed and only using ALSA.
post #18 of 33 Old 12-13-2011, 08:30 AM
djb61230's Avatar
Liked: 24
/etc/asound.conf
area?
Most configuration files in /etc can just be edited with a text editor. There are a couple editors installed on your machine. I use vim (or vi) but it is probably not the best choice at this point if you have never used it. Another is nano which will be closer to what you are most likely used to using.
Most files in /etc a "normal" user can only read - meaning you cannot edit and save your changes. On Ubuntu you can get root (superuser or admin) permission by using the sudo command. It will ask you for YOUR password, and allow you permission if you type it correctly. So
sudo nano /etc/asound.conf
would let you edit and save any changes to that file.
djb61230 is online now
post #19 of 33 Old 12-13-2011, 09:09 AM
zim2dive's Avatar
I can't promise anything magical, but I went thru the HDMI audio process a while ago (on earlier versions of Alsa).. may (or may not) be anything you can learn from: http://www.avsforum.com/avs-vb/showthread.php?t=1225332
FWIW, getting the speakertest to work, for me was always step 1... then convincing every app to send audio to the correct output.
zim2dive is offline
post #20 of 33 Old 12-13-2011, 04:37 PM
waterhead's Avatar
Quoted: 17 Post(s)
That may have been true (for some) a while ago. But I have not had any recent trouble with Pulse audio.
For MythTV, I set up the audio option using this selection:
ALSA:hdmi
Outside of MythTV, I used the Ubuntu Gnome Sound Preferences GUI to select the HDMI as my audio choice in both the Hardware and Output sections. I have audio over HDMI in both MythTV and the Desktop.
post #21 of 33 Old 12-14-2011, 04:14 AM - Thread Starter
devoz's Avatar
Given my level of Linux knowledge ..no way I will be altering
anything without asking questions..
I merely wanted to find a way of looking at this file..
to see what is in there..probably all standard
but wanted to make sure..and try to widen my knowledge.
devoz is offline
post #22 of 33 Old 12-14-2011, 04:23 AM - Thread Starter
devoz's Avatar
ALSA:hdmi
Is this Ubuntu Gnome Sound Preference Gui..standard with Ubuntu
that is installed under MythTV..??
or did you install it as add-on thru the Synaptic repositories manager?
I am not going to mess too much with the sound further
(as it is working with both VLC and SMplayer)
until I have a few long sessions trying to get Myth TV
working..at least as far as Live TV..
and that will be this weekend..
In particular I need to get my Hauppaoge RC6 remote working in
Myth TV..otherwise it is a wasted effort.
I need some ease of couch control..other than via keyboard.
So next priority is to delve in to LIRC..
I assume this is what is needed to get an RC6(like my Hauppauge) remote working
with MythTV??
devoz is offline
post #23 of 33 Old 12-14-2011, 04:45 AM - Thread Starter
devoz's Avatar
Mythbuntu has ALSA version 1.0.24..which seems to be version that makes it easier to set-up
for HDMI audio...I went into alsamixer and used F6 to set the device to 1
which is the Nvidia device..
as against Intel HD..which was device 0..
so lot of that post I recognise..thanks
That was one nice part of Mint 12 ..was the sound configuration area Gui
..which included a speaker test Gui...a little more user friendly
for us used to soft-padded Windows 7 surroundings..
devoz is offline
post #24 of 33 Old 12-14-2011, 07:33 AM
Lost Dog's Avatar
Quoted: 28 Post(s)
[quote=devoz;21345587
with MythTV??[/QUOTE]
I really applaud you for going at this and diving in... For basic use linux is simple to install and use but for more advanced things like what you're doing it can be difficult. Good job keeping at it.
Sometimes LIRC can be a total pain. I'm not aware of any good frontend to get it working. Time to dive in to text files and edit some .conf documents! Let us know when you are going at it and we'll get you through it.
I've not tried this but it looks useful:
http://lircconfig.commandir.com/
post #25 of 33 Old 12-14-2011, 08:59 AM - Thread Starter
devoz's Avatar
tried looking at that link... and it seems dead(sorry just slow..got it now)
Yes well ..my main issue is how to look at these .conf documents?
I want to look at the asound.conf.. one to see what it looks like now
..everyone has told me how you edit them with command lines
I can find them with a file manager..thats Gui based
but how does one look at them?
Is this program above allow you to display the contents?
I noticed djb61230 mentioned ..nano...?
I assume I need to go to Synaptic manager and search for that ..and then install?
devoz is offline
post #26 of 33 Old 12-14-2011, 09:21 AM - Thread Starter
devoz's Avatar
So my remote is a Hauppuage RC6 type...model no TSHA-IR01
and looks like this one shown in
mediaportal area for remotes...http://wiki.team-mediaportal.com/4_H...tes/MCE_Remote
and this is a picture..
http://wiki.team-mediaportal.com/@ap...jumppoints.jpg
I think its a 45 button remote..and comes with a usb receiver
(and works nicely without any configuration in Windows media center!)
...thanks Lost Dog
at least that link you mentioned
has lots of lirf.conf files from users with
different remotes(including many Hauppauge varieties)
So the idea is to work out which does work...
devoz is offline
post #27 of 33 Old 12-14-2011, 09:55 AM
zim2dive's Avatar
They are (usually) just text files... find some editor you like and use that to view/edit. You'll need to get comfortable doing that.. I'd say its a pre-requisite for using linux.
Typical suffixes will be .conf, .rc.. and since I never use GUI file manager... do files starting with . show up in the GUI? (many config type files will start with . b/c some interfaces "hide" them from the user).
zim2dive is offline
post #28 of 33 Old 12-14-2011, 11:25 AM
waterhead's Avatar
Quoted: 17 Post(s)
You would most likely be more comfortable using the gedit app to edit text files. If not already installed, use this command to install it:
Code:
sudo apt-get install gedit
Enter your password when it asked for it. You will need to run it with root privileges, so use the gksudo command:
Code:
gksudo gedit
Again enter your password in the popup window.
Edit: You may need to use gksu instead of gksudo.
post #29 of 33 Old 12-14-2011, 03:55 PM
k_ross's Avatar
As far as sound, to make the HDMI the default for desktop sound (and Flash inside a web browser, etc.) just create a file called ".asoundrc" in your home folder (no special permissions needed), and put this into the file:
Code:
defaults.pcm.card 1
defaults.pcm.device 7
You can use gedit as the text editor.
-- Kevin
k_ross is offline
post #30 of 33 Old 12-14-2011, 06:41 PM
djb61230's Avatar
Liked: 24
That is great info Mr. Ross. I was editing /usr/share/alsa/alsa.conf instead. The local .asoundrc is a better way to do it.
Reply HTPC - Linux Chat
