My next HTPC will be Raspberry Pi - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 146 Old 02-11-2013, 05:20 PM
Dark_Slayer's Avatar
Quoted: 729 Post(s)
Liked: 452
Originally Posted by PobjoySpecial View Post
2) Reliance on WiFi
Can this be alleviated with an adapter? http://www.budgetgadgets.com/10100mbps-rj45-ethernet-network-adapter-dongle-zt106-p-7428.html
According to this random wiki, a usb 2.0 ethernet adapter works fine with the MK802 http://romanrm.ru/en/a10/mk802-server
However this blogger and some other Q/A sites have unverified questions in regards to Android's ethernet adapter compatibility http://rikomagicmk802.blogspot.com/
Future would seem to be next gen pivos xios http://www.pivosgroup.com/xios.html. They already have XBMC builds with H/W acceleration, but there user forums still contains several 1080p playback stuttering reports. There seems to be a movement to place blame on the SMB sharing protocol, but windows to windows SMB shares can already deliver shared blu rays smoothly. I don't really know what's different with android's SMB protocol, or how far h/w acceleration is from the rest of the NEON ARM SoCs. It could be that next gen Tegra, Exynos, etc will be powerful enough to deliver smooth playback on software decode??? If so current hardware might just be deemed SD compatible
Dark_Slayer is online now
post #92 of 146 Old 02-11-2013, 06:10 PM
PobjoySpecial's Avatar
PobjoySpecial is offline
post #93 of 146 Old 02-12-2013, 11:18 PM
Castaa's Avatar
Castaa is offline
post #94 of 146 Old 02-13-2013, 05:21 AM
kwisher's Avatar
I'd like to report that with the Raspbmc spin for the Pi I am 95% there for a media center frontend. The only thing I can't do is stream live TV from my HDHRPrime device. Live TV from my DVB tuners works and watching all recordings. There is a PVR addon in XBMC that will connect to your MythTV backend. I did have to purchase the MPG codecs for $3.75 also. It's almost there.
kwisher is offline
post #95 of 146 Old 02-13-2013, 05:44 AM
Dropkick Murphy's Avatar
Quoted: 72 Post(s)
Liked: 89
I just got a PI and recently started playing with it but I'm unclear on one thing. Can this thing stream from a NAS/Server, or is it attached storage only?
Dropkick Murphy is offline
post #96 of 146 Old 02-13-2013, 06:01 AM
djb61230's Avatar
Quoted: 24 Post(s)
Liked: 45
So are you using the PVR plugin? If so does commercial skipping work? Or in general, are there things that the XBMC/PVR interface lacks in respect to mythfrontend? I ask because whenever one changes from one program to another, sometimes there are compromises to be made. We tend to only hear about the positives and not the negatives. But perhaps there are no negatives in this case.
djb61230 is offline
post #97 of 146 Old 02-13-2013, 06:52 AM
ncarty97's Avatar
Quoted: 77 Post(s)
Liked: 43
I asked this before, but don't think I really got an answer:
How does Raspbmc handle something like a Blu-Ray rip that has TrueHD? I know it can't decode TrueHD. Can it pass it through though? And if not, does it just default to the next audio tract it can handle?
Also, while I know it does not support BD-J menues, if you have rippe a Blu-Ray to folder structure, will it just select the largest title to play? Or does it not work at all?
Carty Custom Builders, LLC
ncarty97 is offline
post #98 of 146 Old 02-13-2013, 08:29 AM
post #99 of 146 Old 02-14-2013, 05:05 AM
kwisher's Avatar
Yes, in fact in XBMC you don't even need to manually mount any network shares, you can just browse to them the first time and it adds it automatically. If you are using a vanilla Linux spin then shares can be mounted the usual way.
kwisher is offline
post #100 of 146 Old 02-14-2013, 05:08 AM
kwisher's Avatar
The standard PVR addon in XBMC connects to multiple backends, including MythTV. I am not sure about commercial skipping as I did not keep it in place long enough since I can't stream LiveTV from my HDHRPrime.
kwisher is offline
post #101 of 146 Old 02-14-2013, 08:43 AM
Quoted: 729 Post(s)
Liked: 452
Why couldn't you play livetv from the prime in Myth? It was one of the first backends to support it. Were you having problems with playback on the Pi, or all htpcs?
I use the prime as well, but I run the NPVR backend on windows 8 XBMC server-htpc. Live TV and recording scheduling have been working pretty well on OpenELEC 2.99.1 and 2.99.2. I've also got livetv playing on my Nexus 7 running the android stable release, but it doesn't handle 1080i for very long. It starts to buffer frequently after 10-12 seconds. There are experimental android builds to get graphics acceleration, but I've not had time to go test them out.
I don't know about Ethernet adapter support under Android, but most "Android" devices currently use a custom version of Linux to run XBMC. They support XBMC on the Android OS, but there is too much overhead for it to work well.
Coming from someone who's been using XBMC on the Android OS, I don't believe this is correct for "most" Android devices. I'm sure this is correct for a "few" android devices, but post-4.0 devices take less than 100MB to run the Android OS and services. It may not intelligently manage itself if you load it full of third party resource hogs, but if you keep tabs on what's running it can handle XBMC and plenty more with breathing room. I don't soft-handle my Nexus to make it run XBMC smoothly
Keep in mind that the fastest ARM processor is just approaching Intel Atom levels of performance.
In math calculation performance, but they kill Atoms at drawing polygons
The fastest ARM processor is a weak cpu with a gpu on steroids. Just need to wait a little longer on h/w acceleration. libstagefright looks promising
SMB has high overhead. I don't know if it's due to the protocol or its implementation on Linux
I don't know either, but to shed a little light on this. I picked up a $30 SSD back in August to replace my whs 2011 OS drive, but I instead of whs I wanted to try an ubuntu server since it could also run a myth backend. I went with a precise build and just added the ntfs drives to automount in the fstab and setup SMB sharing. I mounted the shares to my W7 htpc, but couldn't get blu ray rips to playback smoothly. Same story for openelec htpc. I installed W7 on the OS drive, repeated the process, and playback was smooth. I also tried out several file copies, and they would average about 30MB/s through Precise SMB sharing. W7 SMB share (same switch, cables, drives, just W7 as the OS instead of precise) would hit 80MB/s. I think it's the implementation, not the protocol
post #102 of 146 Old 02-14-2013, 09:06 AM
quantumstate's Avatar
Personally I can't understand using Samba rather than sshfs, but DS were you using CIFS or SMB? Ditch SMB (138, 139) as it is very old. All you need is port 445 on the server open for CIFS.
quantumstate is offline
post #103 of 146 Old 02-14-2013, 09:27 AM
Quoted: 729 Post(s)
Liked: 452
I think there are checkboxes during the server install for something like
  • SSH
  • Samba
  • LAMP
I chose from there, and ran "apt-get upgrade" "apt-get update" after installation. I never checked which versions. I'll probably try to troubleshoot different protocols next time around, thanks
post #104 of 146 Old 02-14-2013, 10:12 AM
You can check which ports are open on a server with # lsof -i -n -P
(I have this in /etc/profile as: alias listen='lsof -i -n -P |more')
Definitely want to close all ports in and out that you don't specifically need. (I use app config first, and then Shorewall)
For years I've mounted remote volumes with sshfs. I regularly get ridiculed for keeping extremely tight security on my own LAN, but now with the rise of AWS (and BTW all the IT jobs it will cost), I'm laughing all the way to the bank. IT security is almost a reflex.
PS - You want to use: apt-get dist-upgrade instead of just upgrade, as the former upgrades in addition dependencies and libs. This is necessary for a stable system.
post #105 of 146 Old 02-14-2013, 10:31 AM
post #106 of 146 Old 03-14-2013, 07:14 PM
lockdown571's Avatar
Quoted: 69 Post(s)
Liked: 95
Interesting!
Also, have any of you guys ordered a Raspberry Pi? It sounds like there's still a long wait. Also, the two websites that ship in the US listed on the Raspberry Pi website won't give you shipping and tax costs until after your order is processed. Sketchy! If these things were on Amazon I would have had one ages ago.
Edit: Nevermind, it is on amazon now!
lockdown571 is online now
post #107 of 146 Old 03-15-2013, 03:43 AM - Thread Starter
karrih's Avatar
Originally Posted by lockdown571 View Post
Interesting!
At least here I could just walk in shop and buy one right now.
karrih is offline
post #108 of 146 Old 04-19-2013, 05:59 AM
ncarty97's Avatar
Quoted: 77 Post(s)
Liked: 43
Microcenter now has them in stock, so I may go pick one up.
I've converted all my Blu-Ray and HD-DVD's to MKV, so no menu issues there anymore, however I'm curious how it handles regular DVD's. Any menu support? I know that XBMC has menu support (though it seems like the Frodo build is having issues with it).
ncarty97 is offline
post #109 of 146 Old 04-28-2013, 12:27 AM
Blu_One's Avatar
Liked: 62
I'm looking at purchasing a Raspberry Pi model B. I have absolutely no experience with computers or software, besides the basics -no programming experience at all. I wanted to make sure that I'm purchasing the right equipment for what I want to do, which is learn how to rip my BDs, put them on a USB drive and watch them on my HDTV with the Pi. I would connect the Pi to my onkyo 809 AVR, which then goes to a Darbee Darblet and then to the plasma display.
First I wanted to make sure that I can rip my BDs and put them on this WD 4TB 'My Book' hard drive, and connect it to the Pi?
http://www.amazon.com/Book-External-Drive-Storage-Backup/dp/B008S94HXG/ref=sr_1_1?s=pc&ie=UTF8&qid=1367130599&sr=1-1&keywords=my+book+essential+4tb
I also wanted to make sure the following equipment is all I need to purchase besides the hard drive:
-Raspberry Pi model B
- enclosure
- SD card (is bigger better? do I need software on this?)
- power supply
- USB cable (or USB to micro USB cable??)
- I have an HDMI cable already
I understand that I'll need to have an XBMC, such as RaspBMC or something similar... but my main concern is for someone like me that has no computer/software experience, will I have difficulty setting up the Pi and watching movies off the USB hard drive attached to it??
Many thanks for any assistance.
65" Panasonic ST60 | Onkyo 809 | Oppo 103 | Apple TV4 | Darbee Darblet | 5.2 system - 5x Arx A2 + 2x SVS SB12-NSD
Blu_One is offline
post #110 of 146 Old 04-28-2013, 06:20 PM
James A. McGahee's Avatar
Quoted: 44 Post(s)
Originally Posted by James A. McGahee View Post
I just updated to Frodo. I was previously unable to revive my Raspberry Pi but the update, or something, seems to have almost brought it back. It did about a 30 min. rebuild and is now stuck int a "Relax, XBMC will restart shortly. Press ESC key for a command line". Every few seconds that message goes black and then comes back over and over. I unplugged RB Pi and plugged it back in on to have the same message return. I have it cabled to my router but it does not seem to find it to connect to the internet. I also have a hard drive connected to it that houses all the discs I own. It does not seem to find that either.
HELP!
and
THANKS!!!
James A. McGahee is offline
post #111 of 146 Old 04-29-2013, 07:55 AM
Blu_One's Avatar
Liked: 62
Anyone ?? I'd really like to get the equipment this week for this.. Thx !
- enclosure
- power supply
Blu_One is offline
post #112 of 146 Old 04-29-2013, 11:32 AM
sigma957's Avatar
Quoted: 18 Post(s)
Liked: 34
- enclosure
- power supply
I have been experimenting with XBMC on a Raspberry Pi and I can answer a couple of your questions:
- The Raspberry Pi is intended for people with some technical knowledge - not necessarily programming experience, but you will have to be able to write sd card images, edit configuration files, and search online forums for instructions (the Pi does not come with any directions). That said, it's not hard to set up - but you will have to be prepared to do some learning. It takes a bit of effort to get smooth 1080p playback because it is such an under powered device. I had to overclock mine to get it to work satisfactorily, and there are still times when I find that the interface lags a bit too much for my liking.
- You can connect external USB drives to the Pi as long as they have their own power supply. The drive you reference above looks like it should work, but no one can say for certain without trying it.
- Unless you plan to store media files on the SD card, bigger is not better (8GB should be plenty) - however faster is better. If possible you want a class 10 card.
- You don't mention it in your list, but I assume you will want to network the device. For that you need either an ethernet cable (and somewhere to plug into you home network), or a usb wireless adapter. The wireless route can be tricky - check the forums for compatible devices.
- You also need to consider how you will control it. For initial setup it's handy to have a usb keyboard. After that you will want to use a remote control. There are Android and iPhone remote control apps, but they require you to be networked. If you have a modern TV connected to it through HDMI, you can probably control it with the TV remote using CEC.
BenQ W1070 | Denon AVR-X4200W | Sony XBR75X940D | LG OLED55E6P | Samsung PN51E7000 Plasma | HTPC
sigma957 is offline
post #113 of 146 Old 04-29-2013, 03:57 PM
Blu_One's Avatar
Liked: 62
Thanks very much for your response, I really appreciate you taking the time to write this up, the info you provided is very helpful for me. From what you've said, I'm on the fence right now.. I'm willing to learn and I think that by reading the boards and asking questions, I might be ok (?) I believe that there might also be some 'instructions' manual on the net. But when you start talking about overclocking, you totally lost me there lol.
I might hook it up to my network, I have a router in my AV stand with a free port so that wouldn't be a problem at all. However, that's not a priority for me.. All I really want to do is rip my BDs on my PC, put them all on the 4TB USB external hard drive, hook it up to the Pi and watch the BDs on my system.. I'm not familiar (yet) with ripping BDs, but obviously I know all the info is out there and I will look it up, but my main concern besides actually setting up the Pi and the interface is your comment about the difficulty in 1080p playback for the Pi. I will want to rip my BDs with the highest level of fidelity possible (not sure if you can rip at variable bit rate exactly like the BD plays back at, but if not I would want to use the highest mbps possible. I want the playback from the Pi to look at much as possible as if you were actually watching the BD in a blu-ray player. Since that's the main intention, will the Pi work for this or should I look at another alternative to hook up a USB drive to, if so any suggestions?
I might have to get a USB keyboard then for setup.. then I can use my iPhone/iPad or my Panasonic TV has CEC. But what I would really like is to use my harmony remote since that's the only one I use for all my components besides the PS3, would the Harmony One work with the Pi, if so any IR adapter or anything extra needed?
Thx !
Blu_One is offline
post #114 of 146 Old 04-30-2013, 11:44 AM
sigma957's Avatar
Quoted: 18 Post(s)
Liked: 34
Thx !
You've probably done a lot of reading already, but here is a good guide for setting up the R Pi. If it sounds too complicated, then you may want to re-consider. However, for the ~$50 it will cost to try, there's not that much to lose smile.gif.
http://www.gaducated.com/the-perfect-xbmc-setup-on-the-raspberry-pi/
Like I said above, you can connect a usb drive directly to the R Pi, but I think most people use some kind of NAS server instead and then connect to it over the network. A NAS costs quite a bit more, but it's expandable and you can use it with other media players.
I believe that XBMC works out of the box with certain usb IR receivers, but they cost about as much as the R Pi does in the first place, so most people use the options I mentioned above.
sigma957 is offline
post #115 of 146 Old 04-30-2013, 12:00 PM
ncarty97's Avatar
Quoted: 77 Post(s)
Liked: 43
Thanks for linking that guide!
I've asked this before, but never been able to find a good answer. What happens when you try to play a file with TrueHD? I know with DTS-MA, it can just play the 'core' part, but with TrueHD, does it just default to the next available audio track or do you get silince or a crash?
ncarty97 is offline
post #116 of 146 Old 04-30-2013, 01:17 PM
Blu_One's Avatar
Liked: 62
Thx very much for all your help, much appreciated.
Blu_One is offline
post #117 of 146 Old 05-02-2013, 01:21 AM
sigma957's Avatar
Quoted: 18 Post(s)
Liked: 34
XBMC is not able to extract the AC3 core from TrueHD tracks. Instead, it will decode it to PCM (which kills the cpu on a Raspberry Pi). If there is another audio track, I don't believe it will fall back to it unless that track is marked as "default".
sigma957 is offline
post #118 of 146 Old 05-12-2013, 04:28 PM
ncarty97's Avatar
Quoted: 77 Post(s)
Liked: 43
Quick question: With OpenELEC or RaspBMC do you need to buy the two codecs that the Raspberry Pi foundation sells online?
ncarty97 is offline
post #119 of 146 Old 05-12-2013, 07:56 PM
post #120 of 146 Old 05-13-2013, 07:05 AM
ncarty97's Avatar
Quoted: 77 Post(s)
Liked: 43
I used that guide and got mostly setup. Having a slight stuttering on a high bit rate MKV (about every 30 seconds to a minute it briefly pauses), so need to work that out, but overall, pretty nice! I saw one suggestion to change from SMB to NFS. I really have no idea how that works though. Do I have to do anything on the server side?
I set up three of the buttons like the guide said. I'm interested in setting up fourth colored button to change the audio tract so when I play something with TrueHD I can just easily switch it. Does anyone know what the command is for 'Next Audio Tract' (if there is one)?
Also, anyone else have an issue with the time? It says its 1970 and I can't figure out how to update it.
ncarty97 is offline
Reply HTPC - Linux Chat
