Hi - i have an older PC, 2.8 P4 w GeForce 6600. I can watch 720p no problem with the default configuration, however i'd like to watch 1080i/p content.
ive been trying to figure out ho to offload processing to the various cards in the system, and use the hyperthreading in the P4, but no luck yet.
Ive been trying this: mplayer dvb://channel -ao dsl -vo vdpau
and getting this: [vdpau] Error when calling vdp_device_create_x11: 1
ive insalled the xswat drivers for nvidia-current, and libvdpau1 is installed.
im still a bit of a linux beginner. Any help s appreciated.
So my next options are: buy new video card, or get the mpeg decoders on the ATI HDTV Wonder or the Haupaugge PVR 150 to work.. should i open a new thread?
Your 2.8 GHz P4 can decode MPEG-2 in software without breaking a sweat, so hardware MPEG-2 decoders won't help. You want an h.264 decoder. The only options in Linux I know of are VDPAU with nVidia cards (well supported), VA-API with some ATI/AMD and Intel chipsets (less well supported), the Broadcom CrystalHD decoder (less well supported), and of course, software.
would you think there is something wrong or just underpowered hardware?:
Some reports say my CPU is 2800 MHz, others 3.2 Ghz (ill try to find which say which)
video is slow and or choppy when trying to play 1900x1080 MPEG-2 TS from my capture card (ATI HDTV Wonder) in full screen mode
video is good when playing x.256 720p mkv files, or 1280x720 MPEG-2 TS from the capture card full screen, or playing the 1080 content in a window sized down
My GeForce 6600 does not support VDPAU apparently. i will look into the ATI (less supported) hardware accell. thanks.
A Pentium 4 2.8 is too slow too decode 1080i/p video in software, I know it because I had one myself. Performance wise it's comparable to an Atom cpu.
With regards to your video card, the link menyioned earlier clearly says that your 6600 is not VDPAU capable (see the '-' next to it, as opposed to a letter?), so VDPAU is out of the question unless you upgrade your video card.
Frankly I would simply upgrade the whole PC, these days a P4 is a dinosaur, even Atoms provide comparable performance for a fraction of the power draw of a P4.
I used to watch HDTV on my P4 with older nVidia cards, no problem. I had to use XvMC (X Video Motion Compensation), which the older cards supported. Unfortunately, MythTV .25 will no longer support XvMC:
I guess we need to differentiate between European DVB broadcast HDTV, which I believe is h264, and US ATSC HDTV broadcasts, which are mpeg2.
Related Threads
AVS Forum
34M posts
1.5M members
Since 1999
