Anyone using a SSD? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-29-2012, 08:30 AM - Thread Starter
Ericglo's Avatar
Quoted: 1705 Post(s)
Liked: 798
Is anyone here using a SSD with Linux? If so, what are the advantages and disadvantages?
Current projector - JVC RS25 and Marantz VP15S1
Future projector - pre-ordered new JVC from AVScience
Ericglo is offline
post #2 of 4 Old 05-29-2012, 10:48 AM
KevBel's Avatar
I ordered parts for my future HTPC this weekend and it will contain a SSD!
I plan on running either Arch Linux (Ubuntu if I'm unable to set up Arch to my liking)
I've been looking into how I should go about setting up the partitions and all on the SSD and it seems there are a few main things you need to look out for :
- TRIM
- Partition alignement
- noatime and discard flags
And the advantages are basically the same as for Windows
KevBel is offline
post #3 of 4 Old 05-29-2012, 11:42 AM
DAP
DAP's Avatar
I am using an SSD for my boot disk, OS, applications, & database.
My home directory is on a pair of raid 0 rotating media drives along with the MythTV recording directory.
The SSD makes booting linux and loading applications much faster. It also eliminates the disk contention that was screwing up recordings when myth was trying to do something with its database while recording TV.
I had some issues with the SSD in 11.10. It would boot so fast that some race conditions that did not show up with rotating media caused boot failures with an SSD. This seems to have been fixed in 12.04.
DAP is offline
post #4 of 4 Old 05-29-2012, 02:49 PM - Thread Starter
Ericglo's Avatar
Liked: 798
This sounds encouraging. I am tired of buying something and then finding out I need Windows to take advantage of some of the features.
Ericglo is offline
Reply HTPC - Linux Chat
