can't power off XBMCbuntu HTPC - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-06-2012, 08:54 AM - Thread Starter
barber76's Avatar
Huh... Yesterday assembled my 1st HTPC. Haven't had time to setup it, but installed XBMCBuntu just to check that hardware is Ok.
While XBMC itself worked Ok, one thing frustrated me immediately - I coudn't switch HTPC off. Whether I chose "shut down" option from XBMC, or even used power button on the case, HTPC just kept restarting instead of shutting down. I mean, PC kinda shuts down, but in couple seconds awakes and loads XBMC again.
Has anyone experienced/aware of this issue?
P.S. didn't use remote, only keyboard+mouse.
P.P.S. case Grandia 05B, XBMCbuntu 11.
barber76 is offline
post #2 of 3 Old 07-06-2012, 02:35 PM
rene18's Avatar
Have you checked all you BIOS settings regarding wake up, power on, power surge and anything related to power?
If it doesn't help then just find what suits for you: https://www.google.ee/search?q=automatic+restart+after+shutdown
rene18 is offline
post #3 of 3 Old 07-06-2012, 03:46 PM - Thread Starter
barber76's Avatar
Nope... I'll check BIOS settings today. Was quite disoriented at 1am... smile.gif
Thanks for the advice & link !
barber76 is offline
Reply HTPC - Linux Chat
