Will these components work Linux HTPC? - AVS Forum | Home Theater Discussions And Reviews
Old 07-19-2012, 01:44 AM - Thread Starter
wanner's Avatar
I've just ordered the parts for my HTPC and ended up with
Antec ISK 310-150 (this will not be affected by Linux ofc smile.gif)
ASRock A75M-ITX
AMD A6-3500
Samsung SSD 830 128GB
Western Digital Scorpio Blue WD10JPVT 8MB 1TB
I'm going to play music,movies and stream media from the web and would like to run Linux Mint or Ubuntu.
Will any of my choice of components cause problems with linux or am I good to go?
wanner is offline
Old 07-19-2012, 11:55 AM
waterhead's Avatar
Quoted: 17 Post(s)
Linux doesn't do well with some cutting edge hardware and/or AMD graphics. A Google search turned up a relevant thread, read through it and the links in it.
http://ubuntuforums.org/showthread.php?t=1916325
waterhead is offline
Old 07-19-2012, 04:25 PM
LexInVA's Avatar
Quoted: 518 Post(s)
Liked: 218
An Intel build would have been the better choice as their drivers and hardware are the best for HTPC if you want a solid setup. AMD's graphics simply don't cut it on Linux right now. I would cancel your order and make a new one if it hasn't shipped yet.
LexInVA is online now
Old 07-19-2012, 04:48 PM - Thread Starter
wanner's Avatar
They have shipped, but i think im able to return it and change to an Intel setup. However i thought that AMD was superior in the graphics department (when it comes to integrated graphics).
wanner is offline
Old 07-19-2012, 11:07 PM - Thread Starter
wanner's Avatar
wanner is offline
Old 07-20-2012, 07:59 AM
LexInVA's Avatar
Quoted: 518 Post(s)
Liked: 218
From a technical standpoint, you are correct. However, AMD graphics hardware on Linux is just not great. Most would tell you it's downright awful because AMD just can't get their act together and put out some solid drivers for their latest cards. Intel on the other hand, really wants you to buy and use their hardware on Linux so they have been committing serious resources to bringing their latest graphics hardware to your desktop and they do offer the best experience for an HTPC on Linux if you want something that doesn't cost an arm and a leg and also has a small footprint. Since your are just using the computer as an HTPC, Intel all the way is really your only option as using an Nvidia graphics card would be overkill for HTPC on Linux, though their cards work exceptionally well for HTPC due to their long history VDPAU support.
