TV Headend - Missing TV Adapter (HDHRPrime) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 08-01-2012, 12:54 PM - Thread Starter
stevedawg85's Avatar
Quoted: 24 Post(s)
Anyone have any experience w/ HTS-TVHeadend? My Specs:
  • Latest Ubuntu
  • HDHomerun Prime
  • XBMC
So I have MythTV frontend & backend working. But my goal is to get Live TV in XBMC (Mythbox is slow and laggy). So now I'm turning to TVHeadend. Under configuration, nothing shows up under TV adapters. I installed HDHR through Synaptic PKG Manager, can watch tv through the HDHR Gui & Myth, but why is it not listed under TVHeadend?
I did some research and I'm missing the DVB folder, what is this and how do I get my adapters listed into this "DVB" folder?
stevedawg85 is offline
post #2 of 8 Old 08-01-2012, 03:19 PM
waterhead's Avatar
Quoted: 17 Post(s)
It has been my experience that if MythTV has been configured to use a capture/tuner card, no other application can access it.
As for the missing /dvb folder. That is created when your system recognises a DVB card, and loads the driver modules. Since HDHomerun is different, I don't believe there are any modules for it.
waterhead is offline
post #3 of 8 Old 08-01-2012, 03:54 PM - Thread Starter
Quoted: 24 Post(s)
Based on your statement, I should remove MythTV and look again under TVHeadend... doesn't hurt to try. Hope it works.
post #4 of 8 Old 08-02-2012, 12:39 PM
tdavis's Avatar
last time I looked, the HDHomerun Prime is not supported by TVHeadend.
tdavis is offline
post #5 of 8 Old 08-05-2012, 09:39 AM
moltensilver's Avatar
You are going for the exact config that I plan on trying once I get my HDhomerun. To my knowledge, to use the HDHR or Prime with TVHeadend it must view the card as a dvb source. Here are some relevant links that will hopefully get you setup.
DVB HDhomerun Driver on Sourceforge.
http://sourceforge.net/apps/trac/dvbhdhomerun/
Linux DVB driver = success Long thread about using the DVB driver w the HDHR.
http://www.silicondust.com/forum/viewtopic.php?t=9153
Lastly, A vid of a guy using the PVR Branch of XBMC with TVHeadend. However, he appears to be using the Euro version of the HDHomerun.
http://www.youtube.com/watch?v=n2SId8l_HQg
Please update this thread with your progress. I really look forward to hearing about anything related to this setup (stability, channel change speeds, etc.)
Good luck.
moltensilver is offline
post #6 of 8 Old 08-06-2012, 03:15 PM - Thread Starter
Quoted: 24 Post(s)
after days and hours and formats and reformats and trying different distributions and headaches, i scrapped this entire plan. Just going to use Windows w/ XBMC and WMC integration. Not ideal, but will work for the time being.
post #7 of 8 Old 08-06-2012, 10:55 PM
quantumstate's Avatar
Shame on you.
(Why would anyone try anything but Debian?)
quantumstate is offline
post #8 of 8 Old 08-08-2012, 05:03 AM
Rgb
Rgb's Avatar
Quoted: 32 Post(s)
I had never heard of TVHeadend, link
https://www.lonelycoder.com/tvheadend/
Tvheadend is a TV streaming server for Linux supporting DVB-S, DVB-S2, DVB-C, DVB-T, ATSC, IPTV, and Analog video (V4L) as input sources.
It also comes with a powerful and easy to use web interface both used for configuration and day-to-day operations, such as searching the EPG and scheduling recordings.
Even so, the most notable feature of Tvheadend is how easy it is to set up: Install it, navigate to the web user interface, drill into the TV adapters tab, select your current location and Tvheadend will start scanning channels and present them to you in just a few minutes
For the full list of features see the documentation.
Rgb is offline
Reply HTPC - Linux Chat
