rebuilding mythbuntu system - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-16-2012, 07:57 PM - Thread Starter
kbrunsting's Avatar
So my mobo died earlier this summer ( I was able swap in another one for now but it has a loud chipset fan and runs a bit hot) and I was thinking maybe this was the opportunity to swap in new components. So I could pick up another motherboard/cpu/memory/video card for under $300 (keeping the existing harddrive/tuner cards/case/remote) and get a nice update to the system OR I could build something completely new.... and if I went with something new, is there a nice hd homerun + mini computer combo that works well with each other? I have a good sized silverstone case at the moment, so I could see the appeal of a smaller system. So does anyone have a recommendation for a mini-computer / homerun combo that works well with mythtv?
kbrunsting is offline
post #2 of 3 Old 08-22-2012, 02:01 PM
newlinux's Avatar
Quoted: 27 Post(s)
What all do you want it to do? Commercial flag, transcode recordings, etc? Will it also be a frontend? I have an older Zotac Mag (ion - HDND01) that I use as small HD frontend, I just ordered a a slightly newer one (ZBOX-ID80-U) that I will use as a HD frontend/slave backend - (I'm giving it 2GB of RAM and attach an external drive - you can buy the plus version that has 2GB of RAM and a slightly larger Hard drive for a bit more if you don't want to add it) I have other slave backends that can do the commercial processing, but these are powerful enough to do it and perform as an HD frontend if you are using VDPAU. I have an HD Homerun, and It integrates easily and well with any recent version of myth. I can't imagine using it with the Zotac would be a problem. The new ZBOX I'm getting will be connected to an HD-PVR.
The Zotac mag I currently have is powered by the older Atom 330, and it can decode mpeg-2 HD without VDPAU. I use it for other things too. It's been rock solid. All downtimes have been planned, and I've had an uptimes 428 and 125 days with it, and it's my primary frontend for the family (quiet, small - but runs a little hot to the touch - you can adjust fan settings in BIOS).
newlinux is offline
post #3 of 3 Old 08-23-2012, 08:49 PM - Thread Starter
kbrunsting's Avatar
Yep, I'd want to use it as a frontend and backend, with commercial flagging... just trying to figure out how much I want to spend. Swapping in new components would be just under $300 and buying a mini system + the hd homerun seems like it would be closer to $400.
Reply HTPC - Linux Chat
