Ubunto 16ghz Super computer using just 5 watts of Electricity, Plays 1080p - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 10-02-2012, 12:34 AM - Thread Starter
sellmejunk's Avatar
Can 5 watts of electric play 1080p films? There maybe a new Linux computer for you.
This is on a $99 dollar pledge gets you a 16 core simple Board simple computer with hdmi, sd cards slot etc running on ubunto.
sent a message to Adapteva about their so called super computer to find out if it can play 1080p with ubunto mentioning if i could plug my 1080p projector into it, they replied with this.:
We are working on finalizing the HDMI resolution spec, stay tuned.
Link for it is here http://www.kickstarter.com/projects/adapteva/parallella-a-supercomputer-for-everyone?ref=search
Would like to hear your thoughts on this as i have little experience with Linux.
oops made mistake in the Thread Title think its 16 core computer for $99 Epiphany-III 16-core 65nm Microprocessor
16 RISC CPU Cores
1 GHz Operating Frequency
specs are here
http://www.adapteva.com/products/silicon-devices/e16g301/
sellmejunk is offline
post #2 of 4 Old 10-08-2012, 12:47 PM
Rgb
Rgb's Avatar
Quoted: 32 Post(s)
Rgb is offline
post #3 of 4 Old 10-16-2012, 08:01 AM
Rgb
Rgb's Avatar
Quoted: 32 Post(s)
Rgb is offline
post #4 of 4 Old 10-16-2012, 10:40 AM
waterhead's Avatar
Quoted: 17 Post(s)
Originally Posted by Rgb View Post
It appears that Linux/Android HTPC's will be reduced to USB-stick size moving forward-
http://www.geeks.com/details.asp?invtid=ANDROID-TV-STIK
Currently, the biggest limitation to the miniaturisation of computers is the size of the ports. The size of the physical connection will have to be shrunk, especially the LAN port, as there are already smaller USB and HDMI ports available.
waterhead is offline
Reply HTPC - Linux Chat
