will i have subtitles/closedcaption with hdtv cards? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 11-25-2012, 12:32 PM - Thread Starter
gcbavs's Avatar
I will probably get a hauppage http://www.newegg.com/Product/Product.aspx?Item=N82E16815116044
and/or Ati HD 750 (http://www.newegg.com/Product/Product.aspx?Item=N82E16815306039
will I be able to get closedcaptions/subtitles via ATSC? and ClearQAM?
gcbavs is offline
post #2 of 6 Old 11-26-2012, 04:18 PM
CityK's Avatar
Its not supported and likely never will be.
I would suggest to expect to be disappointed. However, that said, its not an area that I follow, so I'm largely ignorant. I know that there has been work in this area from time to time, but as I said, I'd temper your expectations. I know Devin was doing CC work over the last year or so, though I think it was for analog sources. In any regard, he'd probably be able to let you know the current status. You can find him here: .http://www.kernellabs.com/blog/ ... or on the Linux Media Mailing List (http://www.linuxtv.org/lists.php .. which you might want to write to instead (thereby opening the question up to a wider audience instead of relying upon one individual's response)).
CityK is offline
post #3 of 6 Old 11-26-2012, 10:59 PM
jflatt's Avatar
They work well for a Hauppauge 1250 in MythTV
jflatt is offline
post #4 of 6 Old 11-28-2012, 12:48 PM - Thread Starter
gcbavs's Avatar
Thank guys!
edit: no way to add [solved] to the original message here?
gcbavs is offline
post #5 of 6 Old 11-28-2012, 12:58 PM
Rgb
Rgb's Avatar
Quoted: 32 Post(s)
Thank guys!
The thread starter can Edit the Thread and change the title/save.
Rgb is offline
post #6 of 6 Old 11-28-2012, 01:36 PM - Thread Starter
gcbavs's Avatar
i'm feeling dumb now... i click edit.. then full screen editor... and nothing about changing the title, only the body of the post.
gcbavs is offline
Reply HTPC - Linux Chat
