Rip DVDs / Blu-Rays Directly from XBMC? - AVS Forum | Home Theater Discussions And Reviews
Old 12-03-2012, 01:31 PM - Thread Starter
hungarianhc's Avatar
Hi there,
I've done some searching on this, and the best information I can find is the following: http://code.google.com/p/swiss-army-knife/
However, this code hasn't been updated in over a year. Is it still relevant? Is there a better way?
My use-case is that I'm going to have an XBMC box w/ a Blu-Ray drive, and I'd love to be able to rip the blu-rays / DVDs directly from the XBMC menu, rather than having to exit out of XBMC and use MakeMKV.
Thanks!!
hungarianhc is offline
Old 12-04-2012, 09:41 AM
Rgb
Rgb's Avatar
Quoted: 32 Post(s)
Due to ongoing DRM/copy protection on both DVDs and BluRays moving forward, you need to use third party tools that keep up to date with the latest protections, such as makeMKV or DVDFab
http://www.dvdfab.com/download.htm
DVDfab works like a native Linux app with Wine. Install Wine with one line copy/paste in terminal
Code:
sudo add-apt-repository ppa:ubuntu-wine/ppa && sudo apt-get update && sudo apt-get install wine1.5
then install DVDFab like any app in Win
Rgb is offline
Old 12-04-2012, 11:49 AM - Thread Starter
Thanks! What about just using MakeMKV and playing MKVs directly? I know I'd have to leave XBMC to rip the DVDs / Blu Rays, but I believe MakeMKV will play that MKV files without issue.
