XBMCbuntu + 1080P Blu-Ray Rips... minimum CPU required? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 35 Old 12-03-2012, 02:36 PM - Thread Starter
hungarianhc's Avatar
Hi All,
I know that the AMD Fusion CPUs can play 1080p content just fine in Windows, but how is their performance w/ XBMCbuntu? I'm going to build an htpc on one of AMD Fusion platforms, but before I do, I want to make sure it will be able to play 1080P blu ray rips first. Thanks!
hungarianhc is offline
post #2 of 35 Old 12-03-2012, 06:12 PM
Rgb
Rgb's Avatar
Quoted: 214 Post(s)
Liked: 223
Yes, Fusion CPUs (APU's) from the E350 and I assume through the A4-A6-A8 should be able to play 1080p hardware accelerated via the XBVA api-
https://en.wikipedia.org/wiki/X-Video_Bitstream_Acceleration
which is one method of acceleration under VAAPI
https://en.wikipedia.org/wiki/Video_Acceleration_API
Howto Install XBMC PVR Xvba for AMD Radeon/Fusion and Nvidia GPUs
http://forum.xbmc.org/showthread.php?tid=116996
HOW-TO use VAAPI HW Acceleration on AMD Zacate (Fusion) platform
http://forum.xbmc.org/showthread.php?tid=99154
More discussion with successful examples
http://forum.xbmc.org/showthread.php?tid=137233
For a Linux media HTPC, you should not use anything but quad core ~3Ghz to cover any video decoding not GPU accelerated, such as Flash HD or some video processing like deinterlacing or codecs not GPU accelerated (yet).
Use an AMD A6 or A8 or a non Fusion quad CPU with an Nvidia card like a GT520, or use a Fusion APU and disable the GPU and add the Nvidia if the VAAPI/XBVA stuff doesn't work for you.
FOr the same 95W of other quad cores, you could get a 6-core CPU
http://www.microcenter.com/product/375766/FX_6100_Black_Edition_33GHz_Six-Core_Socket_AM3_Boxed_Processor
and use the fanless Nvidia GT520 if you wanted.
But if the A6/A8's GPU works well for you, it's a nice low power option (CPU+GPU power draw) and low total heat in the case
Rgb is offline
post #3 of 35 Old 02-01-2013, 02:08 PM
Raptor2099's Avatar
How about something like this for OpenElec 3.0 RC1
AMD A6-5400K | APU --- $60
ASRock FM2A75M-ITX | MOBO --- $90
Crucial Ballistic 8GB DDR3 | RAM --- $40
LG 12X Blu-Ray Drive | ODD --- $55
SanDisk 120GB | SSD --- $90
ThermalTake Element Q | CASE --- $65
Total Cost: $414 from Microcenter
What do you guys think. I'm pretty sure this should be more than capable for a long time to come and OpenElec has pretty low requirements as it is.
I could also upgrade the CPU to the quad core model A10-5800K for $120 and the ram can go to 16GB for $75, which puts the total at $509.
Now that's the price coming from nothing, I already have the Optical drive, Ram, and SSD from old systems so for me I'm looking at $205 which makes it a little nicer lol.
Raptor2099 is offline
post #4 of 35 Old 02-01-2013, 06:53 PM
PobjoySpecial's Avatar
PobjoySpecial is offline
post #5 of 35 Old 02-02-2013, 12:37 AM
blackcat6's Avatar
Quoted: 319 Post(s)
Liked: 70
You do not even want to think about going AMD video on Linux. It will be a source of endless frustration. You should stick to Nvidia.
blackcat6 is offline
post #6 of 35 Old 02-04-2013, 02:38 PM
Raptor2099's Avatar
Here's a good question, will Raspberry Pi play 1080P mkvs streamed from my nas over gigabit lan ? And of course smoothly ?
post #7 of 35 Old 02-05-2013, 04:19 AM
post #8 of 35 Old 02-05-2013, 09:32 AM
ncarty97's Avatar
Quoted: 77 Post(s)
Liked: 43
One thing: unless you are gaming, you will never use 16GB of memory in an HTPC. You probably won't come close to 8GB.
Carty Custom Builders, LLC
ncarty97 is offline
post #9 of 35 Old 02-05-2013, 01:09 PM
Dark_Slayer's Avatar
Quoted: 729 Post(s)
Liked: 452
Since you're talking just case, cpu, motherboard cost you could try these instead
ECS H61-ITX Link $50
Intel G550 @ Microcenter $35
Case?
Case is preferential choice, you could save money going mATX
Or skip the ODD and go with a true mini-box and pico psu for $80 link
G550 can software decode anything you'd like in OpenElec and never bump 50%, and they're really cheap at microcenter
Dark_Slayer is offline
post #10 of 35 Old 02-09-2013, 07:28 AM
Ericglo's Avatar
Quoted: 2219 Post(s)
Liked: 1089
It has been hit or miss with me. Right now it is a miss.
Current projector - JVC RS25 and Marantz VP15S1
Future projector - pre-ordered new JVC from AVScience
Ericglo is offline
post #11 of 35 Old 02-09-2013, 10:33 AM
post #12 of 35 Old 02-13-2013, 08:59 AM
fastal's Avatar
Originally Posted by PobjoySpecial View Post
The major issues with various GPUs under Linux are listed below. Keep in mind that software decoding works with a powerful enough CPU.
AMD:
* No MPEG-2 hardware decoding
* No hardware de-interlacing support
* No HD Audio support
nVidia
* No problems
Intel
* Only bob hardware de-interlacing support
I'm putting together an HTPC and have been ordering parts based off of the recommendations of a friend. I've already got the motherboard so I'm sticking with AMD. In your opinion would a AMD A10-5800K Trinity 3.8GHz be powerful enough to do the software decoding? Also what exactly would be lacking with HD Audio support? I want to have at least 5.1 surround sound through my Onkyo reciever, at the current time none of our other tv's will have extra speakers.
fastal is offline
post #13 of 35 Old 02-13-2013, 09:19 AM
post #14 of 35 Old 02-13-2013, 10:05 AM
blackcat6's Avatar
Quoted: 319 Post(s)
Liked: 70
Because AMD drivers are pretty bad on Linux, you will be using the CPU and software for your decoding. It's a powerful enough processor to handling it, but it comes at the expense of power and heat. On the other hand, a low end Ion2 and atom processor using Nvidia's excellent Linux drivers can handle 1080p content all day long without even breathing hard. This is the difference between hardware and software based decoding. IMO, for a HTPC, where the primary concerns are heat, power usage and fan noise, you would be much better off with an Intel Ivy Bridge processor with the T suffix (very low power) and a GT 430 (or its newer equivalent). It will decode anything thrown it and leave you plenty of processing power for transcoding, commercial detection (if recording OTA), etc.
If you insist on sticking with AMD, then you really should olny consider a windows based operating system as something suitable for your needs.
post #15 of 35 Old 02-13-2013, 01:29 PM
Mac The Knife's Avatar
Liked: 24
I have a 960 PhenomII also clocked at 3.8GHz and it's fast enough to do all the decoding and deinterlacing for 1080i mpeg2 and lower resolutions as long it can use all four cores. On material which causes problems with multithreaded decoding it's still fast enough to do everything except the most CPU intensive deinterlacing like YADIF on 1080i files.
However, it's not quite fast enough to handle high bit rate 1080p mp4 files (such as full bit rate Bluray rips), But, if the bit rate is on the low side it's OK.
So I think the Trinity will be fine with the possible exception of full rate BluRay rips.
Mac The Knife is offline
post #16 of 35 Old 02-13-2013, 02:38 PM
quantumstate's Avatar
quantumstate is offline
post #17 of 35 Old 02-13-2013, 09:20 PM
Quoted: 729 Post(s)
Liked: 452
Originally Posted by quantumstate View Post
Well, hang on. Are we talking about AMD HSA/Fusion here? And MythTV? If so, Myth has had VAAPI support since 0.25, and HSA/Fusion is every bit as good as VDPaU, assuming the fglrx driver. And AMD at least -tries- to work with FOSS developers whereas nVidia does not.
And it would take research but I'll bet that XBMC has VAAPI too.
Things have changed, thankfully.
VAAPI is supported in xbmc, but I thought that's for Intel
Thought AMD needs XVBA support
post #18 of 35 Old 02-13-2013, 09:37 PM
post #19 of 35 Old 02-13-2013, 10:52 PM
post #20 of 35 Old 02-14-2013, 07:28 AM
post #21 of 35 Old 02-14-2013, 10:05 AM
post #22 of 35 Old 02-14-2013, 10:23 AM
post #23 of 35 Old 02-14-2013, 10:56 AM
post #24 of 35 Old 02-14-2013, 11:01 AM
post #25 of 35 Old 02-14-2013, 11:03 AM
post #26 of 35 Old 02-15-2013, 11:56 AM
blackcat6's Avatar
Quoted: 319 Post(s)
Liked: 70
. If so, Myth has had VAAPI support since 0.25, and...
Oh I know, but it doesn't change what I said. Go read the MythTV mail list. There endless reports of people who can't get it to work. The advice from the people who develop MythTV is to use Nvidia. That is all that I think most people need to know.
post #27 of 35 Old 02-15-2013, 01:10 PM
post #28 of 35 Old 02-15-2013, 03:55 PM
blackcat6's Avatar
Quoted: 319 Post(s)
Liked: 70
Have these been in the last two months or so? Because v13.1 is out and it's supposed to be a revolution.
Second, most people don't know that you have to do things in MythTV to make hardware accel work, in addition to the driver install, and I doubt they get that info on the listserv. Hell, maybe I'm the only one who knows...
Why should they have to? Install the Nvidia drivers and you are done, its very easy and Mythbuntu will pratically do it for you automatically. No research project, dealing with endless driver releases, reading forums, etc just to to get it to possibly work. You even admit this yourself. "And it would take research but I'll bet that XBMC has VAAPI too."
You make the claim
Except they are not. AMD has consistently given Linux the cold shoulder, and getting it to work on Linux can be painful, difficult, and outright impossible to do. In contrast Nvidia just works, and works well, and you don't have to be a computer scientist to have it do so. This is because Nvidia has been extremely good about giving Linux parity with Windows with its drivers. Being told "you just don't know how to do it right" is proof enough of this.
ANYONE spending good money on hardware deserves to know this difference and then they can judge whether they want to tackle it or not. I'm willing to bet that most people don't want to go there because all they want to do is watch TV.
post #29 of 35 Old 02-15-2013, 04:02 PM
post #30 of 35 Old 02-17-2013, 12:24 PM
Reply HTPC - Linux Chat
