HTPC Long distance - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 37 Old 02-11-2013, 04:18 PM
quantumstate's Avatar
quantumstate is offline
post #32 of 37 Old 02-11-2013, 06:42 PM - Thread Starter
Jason Holbrook's Avatar
And all these out of asking about if this long run configuration was doable? Wow
Jason Holbrook is offline
post #33 of 37 Old 02-12-2013, 03:27 PM
waterhead's Avatar
Quoted: 17 Post(s)
Sorry Jason.
You may now know why no one else in these forums responds to the "Q". Add me to that list.
waterhead is offline
post #34 of 37 Old 02-12-2013, 04:52 PM
post #35 of 37 Old 02-13-2013, 07:56 AM
newlinux's Avatar
Quoted: 27 Post(s)
Originally Posted by Jason Holbrook View Post
... As for IR remotes and receivers, that is where I am at a loss atm. I see alot of MCE remotes and receivers, but haven't found any definite hardware that is fully Linux compatible as of yet. Tho I see alot of write-ups saying they have it working but no specifics of model #'s.
I have 3 different versions of the MCE IR receivers and all work equally well. I just go to ebay or amazon and then run a check on the comments or googling the model number to see if it is compatible.
I have one of these:
http://www.ebay.com/itm/Brand-NEW-Original-Genuine-HP-USB-MCE-IR-Wireless-Receiver-Win7-Vista-US-fast-/270929871250?pt=US_Remote_Controls_Pointers&hash=item3f14adc192
http://www.amazon.com/gp/product/B00123UGWQ/ref=wms_ohs_product
(only using the IR receiver that comes with it)
And a few of these:
http://www.newegg.com/Product/Product.aspx?Item=N82E16880100851
All of the receivers were plug and play. You still have to configure the IR commands for your apps however. I use Harmony remotes emulating MCE remotes and snapstream remotes for all my setups.
Hope that helps.
All machines run (K)Ubuntu 12.04
newlinux is offline
post #36 of 37 Old 02-13-2013, 04:00 PM
djb61230's Avatar
Liked: 24
For fun I was going to try a mini keyboard like:
http://www.newegg.com/Product/Product.aspx?Item=N82E16823852001
Being "slightly bigger than a candy bar" puts it in the same size ballpark as a remote. That way you get a keyboard/mouse and don't have to mess around with lirc. One downside is that a real remote (I use TiVo peanut remotes) can also do volume, power etc. Even though I use lirc to also control the mouse, having a keyboard and a trackpad is easier to use in my opinion on sites like hbogo. Navigation is just easier with a real mouse. I have been using this:
http://www.newegg.com/Product/Product.aspx?Item=N82E16823126264
and it's worked well - just a lot bigger than a remote.
djb61230 is offline
post #37 of 37 Old 02-13-2013, 06:01 PM
newlinux's Avatar
Quoted: 27 Post(s)
That'll work. I have one of these:
http://www.amazon.com/gp/product/B008JGU3YA/ref=wms_ohs_product
A couple of these:
http://www.amazon.com/gp/product/B002H0BOBA/ref=oh_details_o00_s00_i01
and some other wireless keyboards in addition to my remotes for when typing is necessary. I still prefer my remotes though, especially because of they are learning remotes that control other equipment as well.
newlinux is offline
Reply HTPC - Linux Chat
