HTPC - Wake on Wireless LAN - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-31-2013, 11:32 AM - Thread Starter
asiron's Avatar
Hi
I have been playing around with Wake on Lan for quite some time. I would want to set up Wake on Wireless LAN for HTPC, the problem is that not many NICs support WoWLAN.
It would be great if there is a motherboard with integrated NIC that supports it, so I wouldnt have to waste a precious PCI slot in tiny mATX chassis. I know for a fact that there are problems with USB adapters so that really goes without a question. So I'd like to ask if anyone has a working Wake on Wireless LAN network card if so please share with me, what it is and how you got it to work.
Best Regards
Asiron.
asiron is offline
post #2 of 6 Old 02-05-2013, 04:23 PM - Thread Starter
asiron's Avatar
Bump. Has anyone done anything with WoWLan?
asiron is offline
post #3 of 6 Old 02-05-2013, 04:37 PM
waterhead's Avatar
Quoted: 17 Post(s)
Most who build a HTPC quickly learn that wireless connections are not good enough for streaming. You should do yourself a big favor and just plan on building a PC with a LAN connection..
waterhead is offline
post #4 of 6 Old 02-05-2013, 05:22 PM
quantumstate's Avatar
quantumstate is offline
post #5 of 6 Old 02-12-2013, 05:18 PM
EricN's Avatar
Quoted: 154 Post(s)
Liked: 240
I went down that road a few years back and gave up. There isn't much of a use case for it. If you want a wireless connection for a stationary device, it's usually because you can't get a wire to it because you are putting it out in the open. If it's out in the open, and accessible, there's less need for remote wakeup.
EricN is offline
post #6 of 6 Old 03-03-2013, 11:08 AM
ikkuranus's Avatar
Quoted: 86 Post(s)
Liked: 53
I know the op may not be watching this thread anymore but what you are looking for is a wireless bridge.
They are external devices that plug into your lan port and should stay powered up while the pc is off allowing you to use wol.
ikkuranus is offline
Reply HTPC - Linux Chat
