What can be done with xtreamer MK1 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 07-28-2013, 02:37 PM - Thread Starter
skkkkk's Avatar
I have an xtreamer MK1. Amazingly it can bitstream truehd and dts-ma and play full size blueray 1080p even with the slow 100mbps lan. I hate the GUI. I have tried flashing o!play as well and not really happy with that either. What else can be done with this box? Is there a gui more reminiscent of xbmc I can hack on somehow? Are there good resources for hacking this box? Help...
skkkkk is offline
post #2 of 2 Old 07-29-2013, 01:32 PM
Dark_Slayer's Avatar
Quoted: 722 Post(s)
Liked: 451
I'm not sure that you'd need to go through as much effort as you are thinking. I have not done this, but the way I would prefer to use an Android box is explained here
http://forum.xbmc.org/showthread.php?tid=156099
and accordingly (again I haven't used it myself) with Gotham your XBMC "programs" menu should have Android apps post #13
I thought advanced launcher would eventually be modified to take care of launching Android apps within XBMC, but I don't believe that has occurred to date
Dark_Slayer is offline
Reply HTPC - Linux Chat
