Mini-Box M350 mITX HTPC Build under $350 - OpenELEC XBMC - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 09-25-2013, 04:09 PM - Thread Starter
DylanFromCanada's Avatar
[Image: efilliate-P55700a.jpg]Well I'm under $350 (Cdn) and that was because I salvaged an SSD drive from my old PC. But I also really could have gone with 4GB of RAM instead of 8 and saved $25 and there were cheaper mITX motherboards so it wasn't really my goal to make the cheapest HTPC possible but rather a small, quite and powerful HTPC on a reasonable budget.
I'm replacing my old AMD HTPC that I've been using for quite a few years now. I decided to go with the smaller mini-ITX format and the Mini-Box M350 which measures at 192 x 210 x 62mm... about 1/3 the size of my current HTPC.
http://www.mini-box.com/M350-universal-m...-enclosure
My Part List
  • Mini-Box M350 Universal mITX Computer Case Black 1X2.5INT Works With Pico PSU - Black
  • PICOPSU-150-XT With 102W Power Kit Includes Pico PSU 150W DC-DC ATX PSU & AC-DC Power Brick
  • ASUS P8H77-I mITX LGA1155 H77 DDR3 1PCI-E16 SATA3 DVI HDMI D-Sub USB3.0 Motherboard
  • Intel Pentium G2120 Dual Core Processor LGA1155 3.1GHZ Ivy Bridge 3MB Retail Box
  • Corsair 2x4 GB 1333 Mhz PC3-10666 240-Pin DDR3 Memory Kit CMV4GX3M1A1333C9 (8GB Total)
  • OCZ Vertex 2 60GB SATA3 - salvaged from my old PC
While the M350 case was on backorder last week I attached all the components on my desk and installed openELEC (which was a very simple install) and started pre-configering XBMC.
Yesterday the M350 case arrived and I install all the motherboard/CPU/heatsink/fan with no issues but when it came time to install SSD hard drive I ran into some issues with it fitting using retail intel heatsink & fan.... I was eventually able to make it all fit with some modifications which I will be posting later with photos of the build on my website.
1st Impressions & Observations
  • Took me an hour to figure out why the M350 case wasn't powering up the motherboard when I was pushing the power button. I had the "Power SW" connectors attached to motherboard but there is a 2 pin jumper on on the inside near the power switch that needed to be connected. You would think by default it would have a jumper on it already... but it didn't thus the power switch was disabled.
  • Fast boot-up into XBMC, about 15 seconds and most of the time is from motherboard power cycle and bios just a few seconds from bios to XBMC. Much faster than my Windows 7 HTPC w/ XBMC
  • No hardware or display issues, recognized bluetooth keyboard with no issues
  • After 10-15 mins of running the temp was 113F / 45C
  • Watching a HD movie (.h264) was using about 10% CPU (on both cores)
  • Found and scanned my movie/tv collection on my media server with no issues
  • The internal USB 2.0 cable that goes from front USB port to motherboard wasn't long enough for my motherboard. Also the pins on the case are very close to where the PICO power supply plugs into motherboard. Might be some space issues
To Dos
  • Move IR receiver from old HTPC to new M350 HTPC. There is no IR window like my old case so I will need to drill a hole to allow IR receiver to be held inside the case.
  • Looking into the ability to setup IR receiver so it can power on HTPC with IR remote
  • Program Harmony ONE to work with new HTPC
  • Possibly make a smaller custom HDD bracket if heat is an issue. Current one blocks part of the CPU fan
  • Get internal USB extension cable (9 pin, I think) in order to use front USB ports (2 that are internal at the front of case meant for USB WiFi antenna or IR or bluetooth receiver.
  • Customize XBMC (addons, skins, etc)
  • Test audio once it's connected to my HDTV
  • Setup VPN connection for XBMC/OpenELEC
If anyone has some suggestions or comments for my to do list please pass them along. Photos of build and updates to follow...
-DylanFromCanada
hometechprojects.com
My HTPC: Mini-Box M350 w/ 150W PICOPSU • ASUS P8H77-I mITX • Intel G2120 Dual Core 3.1GHz Ivy Bridge • Corsair DDR3 1333 Value 2x4GB • OCZ Vertex II 60GB SSD • Logitech Wireless K400 Keyboard • Logitech Harmony One • OpenELEC/XBMC
DylanFromCanada is offline
post #2 of 11 Old 09-26-2013, 12:04 PM - Thread Starter
Motherboard & CPU
Motherboard, CPU & PicoPSU Power adapter
Motherboard interfaces
M350 case, USB cable was to short my motherboard
Motherboard, CPU, Heatsink/Fan & RAM installed into case
Front of case, tight fit with PicoPSU & pins for front USB ports
SSD drive won't fit with stock intel fan
Drilled new holes in HDD mount to make drive fit, but the fan blades were still hitting the SSD
Not pretty but I ended up using clear duct tape to fasten SSD to case
Boots into XBMC in about 15 seconds (half of that is motherboard power up & BIOS)
USB bluetooth receiver in front port. Won't be able to use here until I get extension cable from port to motherboard
Install complete, cover put back on
DVI to my monitor during test, Cat cable to my home network
Booted and running at 131 F
-DylanFromCanada
post #3 of 11 Old 09-29-2013, 01:36 AM
puzzledshrug's Avatar
Nice Build
But temperatures seem excessive.
? no fans other than cpu cooler.
? only SSD should not effect temps.
? case looks well ventilated so as you mentioned may be air flow issue.
? with no internal PSU there should be very little heat generated
? just need to work on lowering heat inside case all else is OK
puzzledshrug is offline
post #4 of 11 Old 09-30-2013, 11:42 AM - Thread Starter
Update
To Dos
Removed the Microsoft IR receiver from old HTPC but the circuit board is a little big to fit in the front section of the M350 case. Put the IR receiver back into it's external cover and have it setup outside of the HTPC for now. Remote works great, worst case I leave it as an external IR receiver.
I've done a bit of reading about a few soldering options.
Done for the most part as the Harmony One was already setup for my previous HTPC I just had to use an 3rd party XBMC app addon to link some of the buttons to XBMC commands.
CPU Core temp usually sits around 53 C / 127 F. Have another option of small case fan sucking air in from front right.
Ordered on ebay. Will move USB wireless keyboard receiver from back USB to inside case once I have extension cable.
Switched skin to Aeon Nox (graphically pleasing, very customizable & has mouse support)
Audio & video via HDMI to Sony Sound Bar to Philips LCD HDTV - no issues, everything works great
I decided to simplify and create a simple clean setup for my home theatre. So far I've removed my PS3, PVR cable box and large HTPC. Removed all unused cables, moved surge protector/power filter from shelve to back (out of sight), built a frame above TV to hold the HT-CT100 Sony sound bar (was previously hanging below TV, moved sub box from the side of TV stand to middle (after removing 2 shelves), placed new HTPC, IR receiver & Harmony One charging station to top shelve and finally hooked up Logitech bluetooth wireless speaker adapter at the back (out of sight).
Nice simple, clean layout.
HTPC ---hdmi---> Sony Sound Bar ---hdmi---> Philips LCD TV
Logitech Wireless Speaker Adapter ---RCA Stereo---> Sony Sound Bar
Philips LCD TV ---hdmi---> spare cord to hook up iPad/iPhone
Setup my PureVPN account (via PPTP) using the OpenELEC VPN config menu in XBMC. It connects and generates an IP address but it doesn't seem to be working when I try some region specific services. Will investigate further when I get a chance.
If anyone has some experience setting up VPN on OpenELEC/XBMC please let me know. I would like to setup but have the option of enabling or disabling VPN as needed.
-DylanFromCanada
post #5 of 11 Old 09-30-2013, 07:05 PM
MichaelZ's Avatar
Quoted: 52 Post(s)
What I do for powering on my htpc box is plug it into the on/off switch on the back of my receiver and then setup the bios in the htpc to "always on" after loss of power. So when I power up the receiver the htpc gets turned on automatically. Also, when turning off the receiver the htpc also gets shut-off so saves money on any soft-power on or unit sleeping. Of course I normally start shutting down the htpc before the receiver turn-off.cool.gif
MichaelZ is offline
post #6 of 11 Old 10-01-2013, 10:44 AM - Thread Starter
So to shutdown it's just cutting the power from the HTPC? Sounds like it could be potential for problems down the road software or even potentially hardware.
-DylanFromCanada
post #7 of 11 Old 10-02-2013, 10:40 AM
bac522's Avatar
Quoted: 177 Post(s)
Liked: 100
Yup...you'll eventually end up with a corrupt files system not to mention Linux needing to run file system checks upon startup when it sees an unexpected power loss...basically not a good idea, most OS's I know (including those on cell phones) are happiest with a controlled power shutdown.
bac522 is offline
post #8 of 11 Old 10-02-2013, 03:16 PM
Dark_Slayer's Avatar
Quoted: 655 Post(s)
Liked: 434
I didn't originally see shutdown on your to-do list, but I use Pulse-eight's HDMI-CEC adapter. Support is builtin to either OE or XBMC (Can't recall or both). I changed the shutdown function in settings to suspend rather than shutdown. I also use the bundled tv remote for controlling OE. It feels nice, and the power off button from the remote sleeps the HTPC. Unfortunately, I have to hit the power button on the box to turn everything back on.
I used to have a better setup with the CEC adapter and an old ehome WMC remote and usb receiver. The CEC adapter turned the TV off when the OE box was put to sleep, and turned the tv on when OE was resumed from sleep. The ehome remote power button actually slept/resume OE just fine. Then OE 3.2 took away the plug n play ability to use both receivers (considers the CEC adapter a receiver - which it can be and I'm using it as currently) simultaneously in the remote.conf (I think). I haven't gone back and downgraded yet, but a lot of others noticed WMC remote issues with the 3.2 upgrade. It was total bliss from 3.0 to 3.2
I guess it sounds like a pain, but there is nothing more worthwhile to me than the simplicity of a single power button (single remote). It was worth the $50 for me
Dark_Slayer is offline
post #9 of 11 Old 10-02-2013, 04:19 PM - Thread Starter
Originally Posted by Dark_Slayer View Post
I didn't originally see shutdown on your to-do list, but I use Pulse-eight's HDMI-CEC adapter. Support is builtin to either OE or XBMC (Can't recall or both). I changed the shutdown function in settings to suspend rather than shutdown. I also use the bundled tv remote for controlling OE. It feels nice, and the power off button from the remote sleeps the HTPC. Unfortunately, I have to hit the power button on the box to turn everything back on....
I didn't mention the shutdown procedure because I figured I could program my Logitech Harmony One to shutdown (or suspend) HTPC, turn off TV & sound system with one button. I just haven't got around to that yet.
I never really thought about suspending my HTPC rather than shutdown, I might be able to wake my HTPC with a button press from IR remote if the USB port is powered on suspend. My old HTPC was XBMC running on Windows 7 and everything it would suspend or sleep I would loose the IR receiver for my remote and have to do a reboot to get it back.
-DylanFromCanada
post #10 of 11 Old 10-25-2013, 01:40 PM - Thread Starter
UPDATE - To Dos
Still looking. For now I can get up and power on or use keyboard if XBMC is in suspend mode.
Done, but Harmony ONE has some lag that is annoying. Tried changing response times on remote with no luck.
Heat doesn't seem to be a major issue, although not ideal it's well within safe operating temps
Done and moved bluetooth keyboard receiver in front (internal) usb port.
I haven't been able to get this to work properly using the OpenELEC app in XBMC or the butchered together solution on OpenELEC forum. I might go the hardware route and get a 2nd router (running DD-WRT) and setup VPN that way. You can see my post about that in the networking forum. http://www.avsforum.com/t/1496497/install-2nd-router-running-dd-wrt-for-vpn
-DylanFromCanada
post #11 of 11 Old 10-26-2013, 10:37 AM
MichaelZ's Avatar
Quoted: 52 Post(s)
I want to point out that my remote shuts down the htpc then the projector (which takes a couple of seconds) then the receiver. It's programmed to do it in that order so my htpc is off before the receiver. I've been doing it this way for a long time and I have not had any corrupt disk problems - it is an ssd.
MichaelZ is offline
Reply HTPC - Linux Chat
