Xubuntu 13.04 blu-ray playback woes - AVS Forum | Home Theater Discussions And Reviews
Old 10-24-2013, 01:53 PM - Thread Starter
Remoteless's Avatar
Fresh install of 13.04 on celeron G1610 NO VIDEO CARD. Got blu-ray to play on VLC 2.0.8 twoflower sound is good, picture is terrible. Even dvd video has tearing during action scenes. I'm guessing the video driver is at fault. I'm a buntu rookie and need help. Please!
Remoteless is offline
Old 10-24-2013, 03:25 PM
waterhead's Avatar
Quoted: 17 Post(s)
You need to use a modern nVidia graphics card. And the nVidia driver. not the built-in nouveau driver.
waterhead is offline
Old 10-24-2013, 06:44 PM
Dark_Slayer's Avatar
Quoted: 655 Post(s)
Liked: 434
Not extremely familiar with VLC, but you need to disable HW acceleration for rendering. G1610 can software render blu ray all day long no tearing, but ivy bridge hd graphics are too weak.
If you were using XBMC, the settings needed should simply be deselecting the "Enable HW Acceleration (VAAPI)" radio button
and
Ensure the deinterlace settings are auto and a non-hw-accelerated scaling method is selected
Built my in-laws an openelec box with a g1610 / h61. No video playback problems whatsoever, cpu utilization can hit about 50-60% during 40GB mkv playback with hd audio decoding . . . small price to pay
Remoteless likes this.
Dark_Slayer is offline
Old 11-07-2013, 07:42 PM - Thread Starter
Remoteless's Avatar
Any recommendations for video card? What if i went to a core i3 or i5 would i still need the video card?
I don't understand the requirements would be different for mkv, if uncompressed.
Old 11-10-2013, 04:53 AM
blackcat6's Avatar
Quoted: 319 Post(s)
Liked: 70
It really doesn't take much. Even an Atom/Ion2 board will happily display 1080p content as long as you use the excellent VDPAU driver.
If you are looking for a card for a PC, then go with a GT 430 or one of it's newer equivalents. They can be found for less than $50.
(All digital video codecs are compressed.)
blackcat6 is offline
Old 11-11-2013, 02:58 PM
Quoted: 655 Post(s)
Liked: 434
There aren't different requirements, and you don't need a video card. You do need to use playback software that lets you software decode since the integrated graphics are not up to the task of decoding and rendering.
G1610 running XBMC in linux will playback everything you throw at it except 3D and VC1 1080i (i.e. 3D movies or some 2D BBC blu-rays) with the settings above
Old 12-10-2013, 02:22 PM - Thread Starter
Remoteless's Avatar
and
Finally had some time to play with this due to the double snow storms. That was it Dark_Slayer solved 99% of the problem. Still see line in the middle third of picture during action, fire and some times at scene changes. CPU is running between high 40's and high 60's during playback.
If your using VLC under Input & Codecs deselect "Use GPU accelerated decoding" hit save then close VLC (you must restart VLC for changes to stick) cool.gif
Old 12-10-2013, 02:43 PM
Quoted: 655 Post(s)
Liked: 434
Glad you got it working. I have VLC installed on my Mint 15 notebook, so I took a look at the preferences.
Try the following as well . . . Preferences -> Video -> (deselect) Accelerated video output (Overlay)
I'd also switch deinterlace over to auto or any interlaced content will appear to stutter as well.
