Help!! Radxa Rock single board computer - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-29-2014, 05:36 AM - Thread Starter
fal2okh's Avatar
hi
I read somewhere that raspberry pi can play smooth bluray then I thought Radxa is much more powerful
so i bought one to play my 20GB mkv files
GPU Mali400-mp4@533Mhz, OpenGL ES 2.0
CPU ARM Cortex-A9 quad core @ 1.6Ghz
Memory 2GB DDR3 @ 800Mhz
Storage 8GB Nand Flash, Micro-SD SDXC up to 128GB
it has android on it with xbmc but it cant play my videos(not even 2 GB .mkv files) so much lag and bad quality
whats the problem?can it be fixed or spec is not enough? should i return it?
help plz.
fal2okh is offline
post #2 of 6 Old 01-29-2014, 12:09 PM
sysadmin's Avatar
Quoted: 25 Post(s)
not sure where hw accel is for xbmc in android, but a cursory search shows that gpu has been supported for a year in experimental builds with a modified advancedsettings.xml
you would need to verify your build version includes this and you are using the proper video settings.
there will be more people in the xbmc forums that can help with this.
sysadmin is offline
post #3 of 6 Old 01-29-2014, 02:14 PM - Thread Starter
fal2okh's Avatar
its xbmc 12.3 "allow hardware somethin and somthin checked", it got better but still unwatchable.
im gonna give it away and get some xtreamer or somethin.
fal2okh is offline
post #4 of 6 Old 01-30-2014, 07:10 AM
bac522's Avatar
Quoted: 177 Post(s)
Liked: 100
You need to install the Gotham version of XBMC to get GPU decoding. Note that Gotham is alpha right now, but works fairly good on Android. I use it on my Minix G4 with good success.
http://wiki.xbmc.org/index.php?title=Development_builds
Forum
http://forum.xbmc.org/showthread.php?tid=168268
If you don't want to use XBMC, you can install MX-Player and use HW Decoding in it's settings.
bac522 is offline
post #5 of 6 Old 02-01-2014, 06:09 AM - Thread Starter
fal2okh's Avatar
thanks for your replies but I returned the crap board and im reading about HTPCs, any suggestions?
I want it to be cheap and quite with high picture quality.
fal2okh is offline
post #6 of 6 Old 03-04-2014, 02:22 PM
Knowone420's Avatar
Mod's edit - Rude post deleted.
Knowone420 is offline
Reply HTPC - Linux Chat
