*Need Advise Please* New HTPC build - Blown Ac Power Brick !? Help. - AVS Forum | Home Theater Discussions And Reviews
Old 03-28-2014, 06:37 AM - Thread Starter
Paul Best's Avatar
Hi, sorry if i have posted this in the wrong forum. I tried to find the right place to post this.
I have just recently built a HTPC with the following components.
Case - Streacom FC1 EVO
Motherboard - MSI A88XI AC MITX
PSU - 160w PicoPSU Bundle (with 150w Power Brick) < Link Below !
Cpu - A6-6400K 4.1GHz FM2 Dual-Core (64W)
CPU Coller - Noctua NH-L9a
Ram - 1x 4GB DDR3 1866 MT/s (PC3-14900) CL9 @1.5V Ballistix Tactical
HD 1 - WD 1TB Scorpio Blue (2.5")
HD 2 - Hitachi Travelstar 640gb  (2.5")
Case Fan - 1x Fractal Design 40mm
Installation of all the components went a breeze, i booted up with the bios set as factory defaults and installed windows 7 !
After windows installed i noticed the ram was running at 1333mhz so i changed it in the bios to run at 1866 (This is the only change i made in the Bios) I rebooted back into Windows and performed a windows update and 20 mins into the update i heard a loud pop, i checked the system and tryed to boot up only to find the system wouldn't power up !! i changed the fuse but it didn't make a difference the brick was dead !! :(
Its my first HTPC build using the PicuPsu & AC adapter and i'm hoping someone hear can shed some light on why the adapter would blow up ? there are no loose wires in the case and everything is connected up the way it should be. Does anyone have any ideas as to what happened or anything i can check to find out what happened? I really don't know what i've done wrong or what i should look at.'
The PSU i am using > www.kustompcs.co.uk/acatalog/info_1166b.html
Paul
Paul Best is offline
Old 03-28-2014, 11:19 AM
bac522's Avatar
Quoted: 178 Post(s)
Liked: 101
Fuses don't blow for the heck of it, when they blow it means you've got a short somewhere else, it should be considered a warning sign. A lot of PS now a days won't start up if they sense a bad cpu, incorrectly install CPU, CPU fan not hooked up, or incorrect connections from the PS. First thing you should do is unplug all connections except the MB and CPU PS connections, then see if the system boots. You can probably even remote the RAM too. Also default your BIOS back, usually this is a jumper setting on the motherboard.
Lastly, these forums in general are not really geared towards troubleshooting PC problems, but there are not a lot of eyeballs in the Linux HTPC forum, you might get faster reponses posting in the http://www.avsforum.com/f/26/home-theater-computers forum...although really you should be posting in a PC hardware forum, since your problem isn't really related to AVS at the moment.
bac522 is offline
Old 03-31-2014, 12:47 PM
Rgb
Rgb's Avatar
Quoted: 32 Post(s)
Rgb is offline
Old 04-04-2014, 06:20 AM
gator8's Avatar
When you let the smoke out of the PSU, they don't work anymore. There are no user serviceable part inside (unless you're a technician). Hopefully, it didn't take the MOBO with it. Do a good visual inspection of the MOBO. Sniff for burnt odors and look for chips with a blister in the top of the package.
gator8 is offline
Old 04-04-2014, 09:42 PM
StardogChampion's Avatar
Quoted: 93 Post(s)
Liked: 160
The 2.5mm x 5.5mm barrel jack harness used on the picoPSU is not meant to take more than 8A. That's why there's a 4-pin version of the harness (the part that connects to the AC adapter).
Here's what picoPSU support says on the subject:
"The DC barrel style jack supports up to 8A but if you can use a bigger AC/DC adapter if you don't exceed for too long the rated input. Usually, the bigger AC/DC adapters are delivered with a a 4-pin mini DIN connector for higher power. They can also be used with the PicoPSU-120 but with the P4 type connector. For example, see this AC/DC adapter which is delivered with the 4-pin mini DIN to P4 adapter: http://www.mini-box.com/12v-12-5A-AC-DC-Power-Adapter . Hope this information helps!"
I don't know if this was the issue. It was probably a bad AC brick. But, it's something to consider. 12.5A is over half again the rating of the jack.
StardogChampion is offline
