MythDVD -- Can't Import DVD - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-15-2007, 09:32 AM - Thread Starter
mbobak's Avatar
Ok,
I'm unable to import a DVD. I go to import DVD, it shows the info on the DVD, I hit '0' to start, it says "Nothing to do."
I found /var/lib/mythdvd/temp/mtd.log, and it has this error:
21:31:06: bad destination directory in job request: job dvd 5 1 -1 0 -1 /share/Movies/dvd/VAN_WILDER_UNRATED_D1
And, of course, /share/Movies/dvd doesn't exist.
Now, I suppose I could create it, but, I'd rather learn how to change it, so I can point to a different directory.
Can anyone tell me where to change this setting?
AdvThanksance,
-Mark
Mark J. Bobak
Oracle DBA
Belleville, MI
mbobak is offline
post #2 of 3 Old 02-16-2007, 09:11 AM
Troubleshooter's Avatar
I don't have an older .18 box with MythDVD any more so I don't know. I do know that the current plugin (mytharchive) does have a setup screen to put that path in under media options I believe. Alternatively, you can make a symlink from the directory you want to actually put the stuff to that path it's looking for. The data will still end up in the right place.
Troubleshooter is offline
post #3 of 3 Old 02-17-2007, 08:55 PM - Thread Starter
mbobak's Avatar
Well, I found it. I kept looking under DVD rip options, but, it's not there. It's under Utilities/Setup->Setup->Media Settings->Video Settings->General Settings
-Mark
Mark J. Bobak
Oracle DBA
Belleville, MI
mbobak is offline
Reply HTPC - Linux Chat
