HOWTO: Make a coax SPDIF output bracket - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 53 Old 09-27-2008, 03:56 AM
nic0912's Avatar
Originally Posted by Rgb View Post
Pin 1 is Power for optical SPDIF, Pin 2 is SPDIF Signal out, and Pin 3 is ground (Earth).
Just connect pins 2 and 3 to the RCA (cinch) connector with an old chopped down MPC audio connector or 2 pin digital out CDROM connector per the first post. The RCA center conductor gets soldered to the wire connected to Pin 2 and the RCA ground lug gets soldered to the wire conected to Pin 3 on your mobo.
@ RGB
I did built this coax connector to my mobo's spdif header out and it works fine with my digital audio receiver, however when i connect my HDTV to my PC thru DVI port video card for dual video out, my A/V receiver stops getting signal form this coax spdif and there is no sound anymore. It only comes back when i disconnect my HDTV. Do you have any idea how this works?, is it the ground or something? i just want my HDTV connected..
nic0912 is offline
post #32 of 53 Old 09-27-2008, 05:01 AM - Thread Starter
Rgb
Rgb's Avatar
Quoted: 214 Post(s)
Liked: 223
Originally Posted by nic0912 View Post
@ RGB
Sounds like a ground loop problem. Connect the analog out of your PC to the same receiver on one of its analog inputs and listen for hum from the speakers/headphones connected to the receiver to verify.
If you get ground loop hum, the quick solution is to use a 3 to 2 prong power cord adapter on all your components, or at least the component that is the source of the ground problem and/or the PC, though this link discourages the power cord adapter:
http://www.audioholics.com/tweaks/co...m-hum-and-buzz
Other links
http://www.epanorama.net/documents/groundloop/
http://www.epanorama.net/documents/g...m_solving.html
http://forum.ecoustics.com/bbs/messa...79/180767.html
http://www.channld.com/hum.html
http://priuschat.com/forums/audio-el...dio-shack.html
Rgb is offline
post #33 of 53 Old 09-27-2008, 06:25 PM
nic0912's Avatar
thanks, i'll check this out...
nic0912 is offline
post #34 of 53 Old 11-28-2008, 01:07 AM
rdunnill's Avatar
If the pins are SPDIF, ground and possibly 5V (for brackets with optical SPDIF connectors), then yes, you should be able to use it on any motherboard with the same corresponding signal pins, cutting off the incompatible motherboard connector and soldering a connector compatible with your motherboard SPDIF pins. Modify an MPC 4 pin connector per the original post and solder the correct wires to the corresponding wires you cut from the commercial bracket.
It's possible to rearrange the connector sockets by lifting up the plastic tangs with a pin.
I've converted an Asus connector to MSI, and a FrontX one to Foxconn this way.
Blu-ray: 50+
HD-DVD: 23
DVD: 600+ and lost count
rdunnill is offline
post #35 of 53 Old 01-21-2009, 06:37 AM - Thread Starter
Rgb
Rgb's Avatar
Quoted: 214 Post(s)
Liked: 223
Rgb is offline
post #36 of 53 Old 01-29-2009, 08:57 PM
Ronnie.J's Avatar
NIce how to guide. however I just dont get it. i have an rca coax cable. and a 4 pin header with two wires. one of the wires is a ground. so i solder the spdif to the inside of the coax. But where the hell do i solder the ground, please be specific.
Ronnie.J is offline
post #37 of 53 Old 01-30-2009, 04:28 AM - Thread Starter
Rgb
Rgb's Avatar
Quoted: 214 Post(s)
Liked: 223
Updated RCA jack picture with labels-
http://www.avsforum.com/avs-vb/attac...2&d=1233318465
If you're referring to an RCA panel jack, you're probably missing the ground lug, which is usually a loose part that pilots over the threaded portion of the RCA jack and is retained with a nut that screws onto the RCA jack from the back. You may need to buy another RCA jack. Some RCA jacks have integrated ground connection lugs that can't easily be separated from the jack assembly.
If you are referring to an RCA cable assembly and not a bare jack, then you solder the ground to the braided shielding per this cutaway, labeled "Double Metal Shielding":
http://www.avsforum.com/avs-vb/attac...5&d=1233323542
The idea is to pull back some of the braided shielding and twist it together on one side to form a "wire" to solder the ground to:
http://www.avsforum.com/avs-vb/attac...6&d=1233323542
http://www.avsforum.com/avs-vb/attac...0&d=1233339399
http://www.avsforum.com/avs-vb/attac...1&d=1233339399
The above picture shows an F connector on an RG6 style cable vs an RCA connector, but the idea is the same re: braided shielding. RG59/6 cables usually have solid center conductors, while RCA-ended cables usually have stranded center conductors.
Rgb is offline
post #38 of 53 Old 01-30-2009, 07:59 AM
Ronnie.J's Avatar
I want to make sure that if I am just using a coax connection I do not need to connect the 5v i just need to spdif out, and ground?
And if I am connecting the spdif out direct to an amp/receiver is their any risk to damaging the receiver if done correctly.
once more thanks to everyone in this thread, if it wasn't for this thread I would be lost...
Ronnie.J is offline
post #39 of 53 Old 01-30-2009, 08:03 AM - Thread Starter
Rgb
Rgb's Avatar
Quoted: 214 Post(s)
Liked: 223
Correct. DO NOT CONNECT THE 5V for a coax (RCA) SPDIF connection.
The 5V is to provide power for an optical SPDIF module.
http://www.sys-concept.com/toslink_receiver.htm
And if I am connecting the spdif out direct to an amp/receiver is their any risk to damaging the receiver if done correctly....
No risk if done correctly
You're welcome.
Rgb is offline
post #40 of 53 Old 02-10-2009, 08:58 PM
dreman32's Avatar
For anyone needing optical spdif here is a link to DIY.
http://www.mythtv.org/wiki/How_to_bu..._SPDIF_bracket
Great info overall. Thanks
dreman32 is offline
post #41 of 53 Old 02-11-2009, 06:58 AM - Thread Starter
Rgb
Rgb's Avatar
Quoted: 214 Post(s)
Liked: 223
Good catch.
Prolly easier/simpler/faster to just build the "free", simple coax SPDIF per this HOWTO, then convert to optical externally with
or take that external coax->optical converter apart (or leave it intact) and mount inside your case with mounting tape or velcro, adapting it to run off your internal PC power supply.
Rgb is offline
post #42 of 53 Old 02-14-2009, 04:10 PM
357mustang's Avatar
i am planning running a mini rgb cable plus a coax for spdif from my computer in a different room to my tv/receiver. is rg-59 large enough for spdif? the cable run will be around 75-100 feet
357mustang is offline
post #43 of 53 Old 02-14-2009, 06:13 PM - Thread Starter
Rgb
Rgb's Avatar
Quoted: 214 Post(s)
Liked: 223
Generally, RG-59 works for coax SPDIF use, but for the long length you need, you might want to use RG-6, possibly quad shielded RG-6.
If you already have the RG59, try it and see it you get audio dropouts.
If you haven't bought the cable yet, buy quad shielded RG-6 from monoprice.com.
Rgb is offline
post #44 of 53 Old 02-15-2010, 08:33 PM
jcgeny's Avatar
i made a cable using a cdrom audio one , with the help of this page http://shophobby.blogspot.com/2009/0...spdif-out.html
it is made to connect the internal spdif from an intel motherboard to the auzentech x-fi 2 pins spdif . the spdif signal is using the black cable , the yellow is the ground and the white is the 5v .
so i post a picture of it for someone to check if there is an error
this nice thread helped to solve the problem i talked about in this new one http://www.avsforum.com/avs-vb/showt...0#post18127560
jcgeny is offline
post #45 of 53 Old 03-20-2010, 04:49 AM - Thread Starter
Rgb
Rgb's Avatar
Quoted: 214 Post(s)
Liked: 223
Can't believe I hadn't added this earlier...
Enable SPDIF Output on your Soundcard in Ubuntu 8.04-9.04
(right click on Speaker icon in task bar systray, upper right)-> Open Volume Control
-> Preferences (near bottom right of dialog)
-> (check all options labeled "IEC 958", the electrical engineering term for SPDIF)
-> Close
-> Switches tab (appears after you enable the IEC958 options in Preferences)
-> Check all IEC958 (SPDIF) checkboxes
-> Close
Rgb is offline
post #46 of 53 Old 10-16-2010, 05:25 AM
[supercancel]'s Avatar
Hello!
Thanx for this great guide... helped me a lot.
There are few things i m not sure about so i thought id ask, thanx in advance for the reply.
First, optical vs. coax, is there any real difference... i ll be using 5m of cable. Which one suffers less signal loss?? Is it worth putting an extra effort and funds to make optical output???
Second, to what extent will the quality of used components (cable, chinch connector) reflect in the final sound quality??? Am i o.k. just buying the cheapest components???
Third, i ve been trying to find the voltage of my motherboards spdifout connector but i cant find it anywhere. IT has a 5V pin next to the spdifout, so should I assume that the spdifout is 0.5V???
Is there any chance that it is 5V and that my reciever or motherboard "burns out" if i connect just the grounding and the spdif???
And last, and dumbest, but i want to be sure.
I have spdif in and out pins on my motherboard.
One is labeled SPDIFI and the other just SPDIF.
So SPDIFI is spdif in, and the SPDIF is spdif out??
[supercancel] is offline
post #47 of 53 Old 10-20-2010, 12:25 PM - Thread Starter
Rgb
Rgb's Avatar
Quoted: 214 Post(s)
Liked: 223
Hello!
Thanks- welcome to the forum
The only practical benefit I'm aware of for optical SPDIF is the prevention of ground loops due to lack of electrical connection between the PC and receiver/processor (assuming no other connection between the two devices other than SPDIF). If you don't have a ground loop issue, then there is no performance benefit.
Yes, coax SPDIF cables can be much longer than optical SPDIF, assuming no active cable extenders are used. No issues with coax for 5m assuming a decent quality RG59/6 cable.
Coax SPDIF is lower cost because you can use any old RG-59 or RG-6 cable or old composite RCA video cable.
So, no, it's not worth doing optical over coax in your case, assuming no ground loop issue with your PC.
Assuming the build quality is sufficient (connectors won't come off easily or bad solder joints), just get low cost cables. Buy from monoprice.com and you're golden and cheap
The 5V is to power an optical SPDIF output port- power for the LED.
Generally, for recent vintage boards, you can assume the spdifout pin is a safe voltage for external equipment, but there are always exceptions. Just look in your motherboard manual (Google or board maker website for pdf) to verify, or use a voltmeter .
Again, in general, no worry for the spdifout pin, but you should verify with thte manual or some googling for your PC /mobo make/model.
That would be a safe assumption, given the hundreds of boards I've used/seen over the past two decades Again- consult the motherboard manual (google or OEM website search for mobo model number for pdf)
Rgb is offline
post #48 of 53 Old 10-24-2010, 04:50 AM
Thank you.
post #49 of 53 Old 12-02-2010, 06:06 PM
zoran0909's Avatar
I'd like to use a spdif over hdmi from my PC.
The graphics card (nVidia GTX 260) supports audio passthrough, but I sadly don't have an spdif header on the mobo (GB P-35-DS3R v1.0), but I have a rear coax sdpif-out.
Am I correct in thinking I could just use the guide in reverse and connect the coax to a 2 pin connector on the graphics card?
I still have to see if my DVI->HDMI adapter will pass the audio through it, but it should as the card has an audio PT feature and only dvi connectors. If not I'll try another DV->HDMI adapter.
zoran0909 is offline
post #50 of 53 Old 12-03-2010, 06:34 AM - Thread Starter
Rgb
Rgb's Avatar
Quoted: 214 Post(s)
Liked: 223
You should have no issue connecting the coax SPDIF out on the back of the motherboard to an SPDIF-in header on the video card. Just be certain to connect the SPDIF signal ad ground pins correctly.
I assume you will route the cable from the outside back inside the case. Just chip off any RCA audio or preferably composite video cable and attach the appropriate header connector per methods in this thread.
For a quick and dirty job, just twist the wires together then use black electrical tape around the twisted wires. Or solder the twisted wires then cover in electrical tape or shrink tube.
Rgb is offline
post #51 of 53 Old 12-06-2010, 07:31 AM
zoran0909's Avatar
Oh well, I did solder the cable. but no sound whatsoever reached the TV.
At this point I'm unsure if it's my DVI->HDMI dongles, or software setup.
I did whatever I could think of with software and the drivers.
Any idea how to check if the dongles are passing through the audio?
I would try to connect SPDIF coax directly to the TV, but the TV only has analog audio inputs (besides HDMI).
post #52 of 53 Old 01-25-2012, 06:08 PM - Thread Starter
Rgb
Rgb's Avatar
Quoted: 214 Post(s)
Liked: 223
better late than never ...
DVI cannot carry SPDIF signals, so if you are using a DVI-HDMI dongle anywhere in the chain, SPDIF is lost.
Rgb is offline
post #53 of 53 Old 01-14-2013, 11:07 AM
LokiNZ's Avatar
Just wanted to say a huge thank you for this guide!
LokiNZ is offline
Reply HTPC - Linux Chat
