Stripped Down CentOS Install guide - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-21-2008, 12:15 PM - Thread Starter
sticky's Avatar
We have posted up a very informative guide to installing CentOS. This is a great guide that should get you started in your next MythTV/Linux project.
http://www.missingremote.com/index.p...=2551&Itemid=1
sticky is offline
post #2 of 5 Old 02-21-2008, 04:08 PM
waterhead's Avatar
Quoted: 17 Post(s)
I set up MythTV on CentOS 5 last year. I was surprised to find that the CentOS kernel is not compiled with dvb support. I didn't check any further, but who knows what else is missing!
I ended up downloading the kernel source from kernel.org, and compiled a new kernel myself. I used a kernel config file from a Suse install, as they have everything compiled into it.
I also installed MythTV from (SVN) source, as I don't see it available from CentOS.
Your guide really isn't about MythTV at all. I hope you do a little more research on this subject!
waterhead is offline
post #3 of 5 Old 02-21-2008, 05:48 PM
BubbaSlash's Avatar
It is true that the stock CentOS kernel may be missing some of the kernel modules typically found in the Fedora kernels. However, CentOS offers a "CentOS-Plus" repository where feature complete kernels can be found. The ( dl.atrpms.net/el5-i386/atrpms/stable/ )ATRPMs repository is where you will find additional kernel modules and a complete set of MythTV packages. All of this permits anyone with a 5.x version of CentOS to build a complete MythTV system without the need to compile source code. ATRPMs also has a "bleeding" repository where they hold weekly MythTV SVN builds if you want to try out the latest features (or bugs).
BTW, the guide never claims to be about installing MythTV. It merely puts the building blocks in place such that a user CAN install MythTV (or any number of applications) if they so choose.
BubbaSlash is offline
post #4 of 5 Old 02-21-2008, 06:23 PM
waterhead's Avatar
Quoted: 17 Post(s)
I read it differently.
post #5 of 5 Old 02-25-2008, 07:49 AM - Thread Starter
sticky's Avatar
http://www.missingremote.com/index.p...=2563&Itemid=1
Our next guide is installing CentOS on a flash drive
sticky is offline
Reply HTPC - Linux Chat
