Theres an italian in the house! - Page 6 - AVS Forum | Home Theater Discussions And Reviews
post #151 of 522 Old 01-13-2009, 07:58 AM
Ash Sharma's Avatar
Quoted: 589 Post(s)
Liked: 495
IO Gear makes HDMI 1.3 splitters. ...
Not sure to go with or without the Radiance.
Ash Sharma is offline
post #152 of 522 Old 01-13-2009, 08:09 AM
twenty/twenty's Avatar
Boy it sure would be nice if Sim2 could offer an optional lower wattage bulb for this PJ.
That would increase it's market share to those who are screen width/room width challenged and avoid any potential negatives associated with special screen materials and add on filters.
I may just give up and go with an in theater RS20 rather than a PJ booth PJ. Not that there's anything wrong with that
twenty/twenty is offline
post #153 of 522 Old 01-13-2009, 08:15 AM
Home Theater Lover
Craig Peer's Avatar
Quoted: 4024 Post(s)
Liked: 4078
I wonder how many hours were on the bulb of the one I saw at CES? It wasn't a very big screen, and it sure didn't seem too bright to me. It was just right! My screens would start out around 38 foot lamberts !!
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is offline
post #154 of 522 Old 01-13-2009, 08:20 AM
sierraalphahotel's Avatar
Some customers in my local dealer reported issues with the "old" C3X 1080 set to the lowest lamp brightness, specifically a flickering picture.
I recall Sim saying it was a common issue with the lamp at the lowest power setting. Sim told me recently that this would not be a factor with the new lamp technology in the Lumis.
Any one ever experience this?
Sean
sierraalphahotel is offline
post #155 of 522 Old 01-13-2009, 08:29 AM
Potential non issue if they offer a lower wattage bulb option.
300 watts for the well endowed.
200 watts for the less fortunate.
post #156 of 522 Old 01-13-2009, 08:36 AM
coldmachine's Avatar
Sean
Its a lamp issue called arc jump or arc wander. Its nothing to do with the actual PJ per se.
Its caused by the arc striking in a different position and then jumping or wandering between the strike points. It can be minimized by running on high lamp for a while initially to establish a solid strike point.
Its not an issue with modulated lamps.
"Wow, do you think you are Adonis"...... "Baby, I'm not A-donis, I'm THE-donis"
coldmachine is offline
post #157 of 522 Old 01-13-2009, 08:48 AM
rydenfan's Avatar
What is the current MSRP for the HOST version?
rydenfan is offline
post #158 of 522 Old 01-13-2009, 09:21 AM
thebland's Avatar
Quoted: 1666 Post(s)
Liked: 1005
This HOST.
1. What could it possibly doing where it is 'NEEDED" for the PJ. Could somebody explain? It simply looks like a switcher.. (are one of the control ports on the Host connected to the projector - is this why it is 'needed')?
2. Does the Host act as a switcher or does it do video processing?
3. Does the projecter even have an internal HDMI port? A second DVI port?
Goodbye to a great audio and video genius and writer... JOHN GANNON. I enjoyed your friendship, wit and a nice long run we took around Indianapolis at CEDIA years back... and for buying my Runco 980 Ultra years back... you saved my ass! Rest in peace.
thebland is online now
post #159 of 522 Old 01-13-2009, 09:26 AM
Free's Avatar
Originally Posted by coldmachine View Post
Producing a non HOST version MAY not be that straight forward. Im not saying that is definitely the case, but its a possibility.Here's, potentially, why....
Part of the problem with the C3X1080 was performance limitations due to lack of space inside the box, partly due to the larger chips. This was as a result of the insistence of sticking with the C3X footprint. If the Lumis is physically making use of the increased space available, that may prevent a non host unit from being practical.
Does the Lumis not have the folded light path of the 1080? If it is taking advantage of the extra space, perhaps the optics are improved due to this, not to mention cooling, and noise improvements.
Phil
Free is offline
post #160 of 522 Old 01-13-2009, 09:45 AM
Home Theater Lover
Craig Peer's Avatar
Liked: 4078
I believe it does both.
If I recall correctly, the SIM guys at CES said it was taking advantage of the extra space. It is a very quiet projector.
post #161 of 522 Old 01-13-2009, 09:57 AM
Originally Posted by thebland View Post
This HOST.
Maybe you missed earlier post #146
The HOST isnt an add on unit, it actually part of the PJ. The PJ has been split into 2 parts. Most of the electronics have been removed and remoted from the optical unit.
The part that you are referring to as the "projector" is actually only half of the projector. It has most of its internals missing, as they are in the HOST unit.
The HOST unit connects to the PJ by a fiber cable, that can be upto 750 feet. I will be very glad of that facility as i will be running audio and video distribution throughout the house from an equipment room that is a fair distance from the Lumis' location.
post #162 of 522 Old 01-13-2009, 10:03 AM
JlgLaw's Avatar
Quoted: 83 Post(s)
Liked: 140
IIRC, this was discussed as one of the benefits of moving the internals to the HOST.
Jim
JlgLaw is offline
post #163 of 522 Old 01-13-2009, 02:15 PM
Mark Petersen's Avatar
Interesting, no wonder it's so compact.
Originally Posted by Alan Gouger View Post
A comment on contrast. We measured "over" 20k yesterday but my projector lies behind a wall firing through a port hole. Jason could not optimize his light meter properly to maximize the measurement. It is much higher.
I have the MicroSpec Spectroradiometer which I have to load the latest software I just have not had the time but this will give superior reading to Jason's method.
Wow! Finally something that delivers high on/off and ANSI. The complete package. No doubt the quality control will be very good so unit to unit variation isn't an issue. This sounds like a reference piece to design a HT around.
Mark Petersen is offline
post #164 of 522 Old 01-13-2009, 02:31 PM
thebland's Avatar
Liked: 1005
Got it and understand it. Thanks, CM.
post #165 of 522 Old 01-13-2009, 02:37 PM
No problem. The first time I saw a HOST unit I had a few WTF moments
One good thing is that it isn't new, so the whole HOST idea is fairly mature.
post #166 of 522 Old 01-13-2009, 04:18 PM
Steve Bruzonsky's Avatar
Quoted: 598 Post(s)
Liked: 188
I luv my C3X 1080 and won't be upgrading to the new Lumis - only due to cost considerations of course.
Folks who criticized the C3X 1080, that Sim2 should design the internals into a new case
with improved performance - apparently Sim2 listened and did this. WOW!#@@
You mean you don't remember me? Back 1999 - 2003, I started and moderated the AVS Tweaks forum and also the AVS Special Guests forum.
My home theater at:
http://www.avsforum.com/avs-vb/showthread.php?t=1158431
Steve Bruzonsky is offline
post #167 of 522 Old 01-13-2009, 04:31 PM
rsbeck's Avatar
Sean
I keep mine on lowest lamp, have over 300 hours on it and have never seen any flickering -- or any other issue.
rsbeck is offline
post #168 of 522 Old 01-13-2009, 04:40 PM
Free's Avatar
I had a few small episodes of bulb flicker on my 720, but not my 1080
Phil
Free is offline
post #169 of 522 Old 01-13-2009, 04:51 PM
Quoted: 598 Post(s)
Liked: 188
Me, too, usually 200 for 16:9 and 210 or 220 for 2:35. 8" wide for 16:9.
128" wide for 2:35. 1.3 gain Stewart Studiotek.
My home theater at:
post #170 of 522 Old 01-13-2009, 05:06 PM
Ian_Currie's Avatar
Quoted: 87 Post(s)
Liked: 27
Mine will flicker at 200 after a while - and if I recall correctly, running it higher for a while cures the problem. I currently run at 220 with no flickering whatsoever.
I love the smell of projector in the morning!
JVC-RS4500 4k projector (calibrated by Ken Whitcomb), 11 foot wide (132x54) 2.35:1 ST130
Panasonic DMP-UB900 & Plex Media Server
Classe SSP-800, Bryston amplification, Wilson Audio speakers (7.2) + Buttkickers.
Ian_Currie is offline
post #171 of 522 Old 01-13-2009, 05:18 PM
Art Sonneborn's Avatar
Quoted: 379 Post(s)
Liked: 503
I leave mine on torch all the time I like being able to read the paper when I'm watching movies.Also it saves battery power on my lighted remote.
Art
Art Sonneborn is offline
post #172 of 522 Old 01-13-2009, 05:56 PM
Ian_Currie's Avatar
Quoted: 87 Post(s)
Liked: 27
Originally Posted by art sonneborn View Post
i leave mine on torch all the time i like being able to read the paper when i'm watching movies.also it saves battery power on my lighted remote.
Art
lol
post #173 of 522 Old 01-13-2009, 08:03 PM
mmiles's Avatar
Quoted: 523 Post(s)
Liked: 244
Very nice picture and quiet. Why one would buy the next level up is beyond me. This rig is the real deal.
The video server outfit had the same demo as CEDIA no additional content. It was a semi flat chested hottie in a white pant suit singing, Mandy Moore??
I stumbled accros the PD room. When I inquired about Wolf being at the show one guy almost came (sorry a AVN moment) before he could tell me that division (of whomever they were part of) has been shut down for a month. They had a single chip on display for $30K as I recall. Colors looked flat and the blacks were off to my eye but they thought it was film like...
Mike Miles
mmiles is online now
post #174 of 522 Old 01-13-2009, 09:33 PM
Chris Dallas's Avatar
Location: Toronto, Ontario, Canada & Malibu California.
Quoted: 16 Post(s)
I also thought the Lumis was a great PJ at CES, Sim2 has a winner here. I spent about an hour there and they let me play with it, so I took the liberty of pausing it to take some screenshots for those that want to see them they are in the link provided amongst other PJ's. Also note the new Optoma which also delivers an outstanding picture.
http://www.flickr.com/photos/34271874@N05/
Cheers
Chris
Sony VPL-VW500ES, 16.25 Feet Wide 2.35:1 screen, Proud owner of 1 of 399 Enzo Ferrari's in the world, a gorgeous yellow Ferrari 599GTB, + a 1970 Road Runner see it here
Chris Dallas is offline
post #175 of 522 Old 01-14-2009, 04:06 AM
Lawguy's Avatar
It's great to be excited about DLP again.
I have a call in to a dealer to see one of these but he is not sure when he will get one in.
I reiterate Ohlson's request about on/off with Dynamic Black disabled. It is still recommended that this feature should not be engaged, correct?
Affable Nitwit
Lawguy is offline
post #176 of 522 Old 01-14-2009, 05:06 AM
Ian_Currie's Avatar
Quoted: 87 Post(s)
Liked: 27
I look forward to this as well.
I'm hoping we're not back down under 10k when disabled.
post #177 of 522 Old 01-14-2009, 05:37 AM
Ian, It may be, if the iris has had to be opened for the light output. The point may be moot anyway.
It appears with this combination of technologies, that the dynamic system is totally transparent.
I've never been a DI fan, but this is certainly not a normal DI implementation at all.
I should have more to post soon.
post #178 of 522 Old 01-14-2009, 05:47 AM
Can someone confirm Chris Dallas's CES observation on his flickr pic link, that the new Lumis was projecting on a 109" wide 2.35:1 screen?
I am assuming it was the same material Sim2 used at Cedia-Stewart Studiotec g3 1.3 gain non AT?
post #179 of 522 Old 01-14-2009, 06:01 AM
owl1's Avatar
Question: why would one want to disable dynamic black anyway?
owl1 is offline
post #180 of 522 Old 01-14-2009, 06:06 AM
Digital2004's Avatar
question to C3X 1080 owners: have you noticed digital/dlp noise in some scenes of Transformers hd dvd ?
in the dark blues especially.
what settings do you have ?
i'm in full lamp 250, iris open, birgthness 51 contrast 65 (which influences punch brigthness screen is 400cm scope wide), color 54, gamma trying user 2.2, color spectrum EBU, temp D75.
sce: onkyo hd dvd player 805.
Digital2004 is offline
