Theres an italian in the house! - Page 8 - AVS Forum | Home Theater Discussions And Reviews
post #211 of 522 Old 01-14-2009, 02:41 PM
Art Sonneborn's Avatar
Quoted: 238 Post(s)
Liked: 295
What gets me (in a good way) is how much great ANSI contrast and lots of light can fool ones eyes into seeing a hell of a nice image , except in very low APL. If the dynamic black can offset this single deficiency that I see in my HT 5000 it will be a big step up from other devices IMO.
Art
My HT
iRule rules my theater
Art Sonneborn is online now
post #212 of 522 Old 01-14-2009, 02:44 PM
Christy Warren's Avatar
Thanks to you guys doing these early measurements, I've decided to move up from a c3x1080p to a Lumis, and reviews. The split box configuration really works much better in my application, and I really want the higher CR.
Now to find someone to buy a brand new c3x 1080p (sealed in box with warrantee) from me. Anyone got suggestions for a good place to sell one? I don't see many items in the Classifieds here in our price range.
Christy Warren is offline
post #213 of 522 Old 01-14-2009, 02:46 PM
coldmachine's Avatar
Ive had the first viewing session and will start again soon with some challenging material. I will report later, but here's the first thoughts.
I'll save the flowery language BS for later, but this is certainly a very special machine. Alan isn't prone to exaggeration, and he didnt here either.
The image is incredible. The contrast is outstanding. The ANSI looks to be through the roof. No washout or hazing BS. I cant believe a unit this size is pushing out so much light.
This units MC is similar to my old HT5000. Zero over most of the panel, very minor at edge. Minimal CA. Sharp as a razor.
None of the new stuff comes at the expense of the very obvious 3 chip advantages. The color density and image solidity is there in spades. Image depth is great.
"Wow, do you think you are Adonis"...... "Baby, I'm not A-donis, I'm THE-donis"
coldmachine is offline
post #214 of 522 Old 01-14-2009, 03:02 PM
Scott Horton, techht.com
GetGray's Avatar
Quoted: 170 Post(s)
Liked: 146
Steve Bruzonsky:
Don't you want to get one of these and have me test it . I promise to make another comprehensive spreadsheet with all it's measurments just like your C3X1080.
GetGray is offline
post #215 of 522 Old 01-14-2009, 03:10 PM
Ohlson's Avatar
"Apparently Dynamic Black increases peak signal levels to compensate for the amount that the the iris will close."
What if the signal is 100 IRE?
In any case, w/o local dimming, I don't see how any iris or control system can avoid brightness compression in a dim scene that contains areas of high IRE.
That's not to say the implementation isn't transparent, as the only way to know that it's there may be a comparison with a pj that has a native CR as high as the dynamic CR.
I agree with noah here, DB can not peform black magic even if it is implemented by Sim2. If the dynamic range is expanded too many times the native contrast brightness compression will follow. The native contrast is interesting beacause it gives a little clue to how far the dynamic range can be pushed. This is not the same as the dynamics of the picture which will depend on many other factors such as light output and ANSI cr.
A Why is the DB done by Sim2 so good?
1 It is fast and perhaps the memory and algorithms allow for greater look ahead than previous implementations.
2 The light controlling mechanism is before the dmd so with will not harm good qualities such as
- ANSI contrast
- brightness uniformity
- greyscale, a closing lens iris will treat different wave lengths differently.
B A possible explanation of how white can stay the same and black go down.
I think Sim2 has left some head room in driving the lamp. Enabling DB will allow the projector to drive the lamp harder when necessary to preserve the white level.
Also I must ask
Does Sony use hard drive motors for their lens iris. Using hard drive motors was part of the Eclipse concept that first was shown many years ago.
coldmachine
We are eager to learn more, please report. The fact that DB works so well for the Lumis is a sign to me that DB should be implemented by DCI projectors!
Mattias Ohlson
Ohlson is offline
post #216 of 522 Old 01-14-2009, 04:58 PM
Steve Bruzonsky's Avatar
Quoted: 439 Post(s)
Liked: 100
Originally Posted by GetGray View Post
Steve Bruzonsky:
If someone will reimburse me the $12K Maui family vacation, and buy my
C3X 1080 for near what I paid for it, I would consider it. HA!
Better yet, Scott, you should sell you HT5000 (didn't you recently buy a used one?) and get the Lumis. HA!
Scott, that was funny.
You mean you don't remember me? Back 1999 - 2003, I started and moderated the AVS Tweaks forum and also the AVS Special Guests forum.
My home theater at:
http://www.avsforum.com/avs-vb/showthread.php?t=1158431
Steve Bruzonsky is offline
post #217 of 522 Old 01-14-2009, 05:48 PM
Digital2004's Avatar
took a few shots of the C3X 1080here
screen is 400x171cm scope, microperforated, no gain.
the Lumis much higher brigthness would be welcome (for a client set up same screen size). the C3X 1080 is a bit less bright than the 720E.
note the digicam "peaks" the whites and flashies colors, the image is not as punchy.
i guess around 1000 lumens max / 68sq ft= 14.7FTL (max)
lamp in full 250 iris open. brigthness 50 contrast 67 color SMPTE D75. gamma user 2.2 sharpness 4 noise red 44. color 54.
one "needs" 1500-2000lumens with such a screen if you like punch
how could we live with 250lumens calibrated pj for so long ? or even 400 lumens?
SIM2 has a killer product with the LUMIS.
Digital2004 is offline
post #218 of 522 Old 01-14-2009, 06:07 PM
Gradius2's Avatar
Quoted: 20 Post(s)
You need a better camera (IMHO).
But the last photo is passable.
[]s,
Fernando
Gradius2 is offline
post #219 of 522 Old 01-14-2009, 06:11 PM
Quoted: 238 Post(s)
Liked: 295
It isn't just that those sorts of screen shots don't tell much since they tell almost as much about the camera and photographer perhaps more. I would like to see a close up of the panel alignment with clear pixels to give a reference.
Something like this of the lower right corner of my HT 5000...
Art
My HT
post #220 of 522 Old 01-14-2009, 06:31 PM
Gradius2's Avatar
Quoted: 20 Post(s)
Art
That photo is a killer for sure.
[]s,
Fernando
Gradius2 is offline
post #221 of 522 Old 01-14-2009, 07:07 PM
Mark Petersen's Avatar
Yes that's what I was thinking too. I can't see how else they could eliminate BC.
A black level decrease of 3.5x without BC is a huge advancement and seems as though it would be equivalent to a 3.5x improvement in native on/off.
Mark Petersen is offline
post #222 of 522 Old 01-14-2009, 09:30 PM
GetGray's Avatar
Quoted: 170 Post(s)
Liked: 146
Thought you'd get a kick out of it . Nope, no HT5k for me, yet.
GetGray is offline
post #223 of 522 Old 01-14-2009, 09:32 PM
PRETERNATURAL IMMERSOPHIL
CINERAMAX's Avatar
Quoted: 1672 Post(s)
Liked: 914
Send a message via Skype™ to CINERAMAX
Oh I think I am seeing the symptoms of another wave of collective obsessional behavior in this forum.
Be warned CM that your posts herein could provoke a more dangerous epidemic than the Dancing Plague of 1518
Discipline 007...
Sincerely, GC*
rAVe Best ATMOS DEMO CEDIA 2016. HOARDS AWARDS, ACCOLADES, 1ST ART CREDS.,WLD. RECORDS, & HI PERFORMANCE 16-24-32-48 CH. MIDI-PLF CINEMAS WW. - CUSTODIAN HIGH END IMMERSIVE CINEMAS TO SMPTE & ADV. IMAGING SOC. HELP Combat Channel Insufficiency with Altitude 48!*GC = GANGSTA C. genus: cineramus maximus. GC Twitter (Now staging Humanitarian Relief Aide to Great Bel-Air Circuit B-chain & 6P/HDR Projection Famine of 2017)
CINERAMAX is online now
post #224 of 522 Old 01-15-2009, 02:55 AM
i need to calibrate my pana digicam.
the last shot looks punchy contrasty but it's not like that in real life last night.
the 1080 is not bright enough. the 720 did better but the Lumis as per Alan's measures is twice as bright as the C3X 1080 (and i dont even mention contrast) and is the one to get if one has a giant screen.
big screens= lots more constraints and requirements (super black room, lumens!)
the RS10 yesterday on a 220cm wide screen with client was as punchy as the screenshots. (800 lumens/27sq f= 29ftl ?). it was in iris full open, full lamp. close (340cm distance).
we NEED lumens guys....
so a new Lumis on a giant screen 400cm scope is about 2000/68=29FTL.
post #225 of 522 Old 01-15-2009, 03:22 AM
Discipline 007...
Peter, YOU urging restraint and discipline.
The entire AVS universe is in danger of being swallowed by the vortex of hypocrisy. Are we all to be enveloped by the tsunami of sanctimony.
I will try to refrain from using such phrases as "The Barco Buster", "Video Viagra" or Art's multi level masterpiece... "Uber Kontrast".
Seriously, you make a very valid point.
This machine will, like any other, have flaws and compromises. Every machine does. The measure of most machines, and manufacturers, is how they address and manage those compromises. For example, I don't expect this machine, with a T series lens, to offer some of the clarity that will come from machines like the HT5k and the DCI unit I'll look at. Some people will see that it doesn't have a pro level zoom, so will loose light defendant on zoom position, but neither does anything near this price. Im sure. on critical viewing, I'll see some issues of my own. I imagine there will be some sort of compression somewhere.
I also wont be too swayed by the contrast numbers. We all know its important, but its certainly not the be all and end all. Im certainly not willing to indulge in the declaration of messianic qualities, that we see elsewhere, based on a CR number.
Recently I have had a very hard time trying to explain to some people that this single metric does not define the absolute quality of an image. I used the example of a Barco unit that provides on 2.5k. People declared that such a unit must be crap, the image could not be engaging, etc. On other occasions I've even saw people blatantly fabricate bogus results, and invent imaginary friends, to support their viewpoint. The impact of factors such as color fidelity, pixel noise, MTF, ANSI etc seem either misunderstood, ignored or willfully misrepresented.
I'll try to abstain from the infantile idolatry thats all too prevalent in some sections of AVS. Thankfully this forum is fairly free of that. The taste of Kool-aid makes me wretch.
Your point is well made.
post #226 of 522 Old 01-15-2009, 05:33 AM
Quoted: 238 Post(s)
Liked: 295
I'm just excited that this forum has some projector action for a change. With that you do measurements, sit and look at it with varied softwarand from that you get performance. No need to be "trained" have double blind testing or have experience in Caribbean medicine to get it.
Art
My HT
post #227 of 522 Old 01-15-2009, 05:34 AM
Lawguy's Avatar
Art
You forgot to mention pictures.
Affable Nitwit
Lawguy is offline
post #228 of 522 Old 01-15-2009, 08:08 AM
sierraalphahotel's Avatar
Art
Oh you mean like "Just shut-up and listen, I mean look, umm, ohh whatever!"
Having said that, this does not eliminate the potential for nefarious jitter from the HDMI audio entering into the HOST box, mixing with the video and corrupting the whole experience!
sierraalphahotel is offline
post #229 of 522 Old 01-15-2009, 08:24 AM
mrlittlejeans's Avatar
Quoted: 146 Post(s)
Liked: 246
CM - Sometimes you remind me of a modern day Ignatius Reilly with writing like this. I can almost feel my valve slamming shut...
Absence of evidence is not evidence of absence
mrlittlejeans is offline
post #230 of 522 Old 01-15-2009, 08:51 AM
Would that make you one of the Confederacy of Dunces?
post #231 of 522 Old 01-15-2009, 10:06 AM - Thread Starter
Alan Gouger's Avatar
Quoted: 31 Post(s)
Liked: 56
Ive taken some measurements and will post shortly.
Alan Gouger is offline
post #232 of 522 Old 01-15-2009, 10:46 AM - Thread Starter
Quoted: 31 Post(s)
Liked: 56
Ok here we go. I cant wait any longer.
Here are some solid numbers. I ck and double ck. These numbers are very accurate.
17" L x 16" W x 7.5 H
Anyone disputing these numbers..I used a Stanley
post #233 of 522 Old 01-15-2009, 11:15 AM
GetGray's Avatar
Quoted: 170 Post(s)
Liked: 146
Surely it's a metric unit
GetGray is offline
post #234 of 522 Old 01-15-2009, 11:29 AM
Indeed. Alan's Lumis is clearly broken.
post #235 of 522 Old 01-15-2009, 11:48 AM
brain sturgeon's Avatar
Was it a FatMax Xtreme? The sensitivity of lesser measurement devices can really skew the results...
Seriously though, these initial comments/impressions are extremely tempting. I may have to kick my 11s2 to the curb as well.
Alan, with your smaller screen size, are you using an ND or ND2 filter (sorry if this has been asked/answered-- didn't see it in the other 8 pages)? If so, which filter?; and as CM alluded to earlier, how much of a detriment has it been to the image?
brain sturgeon is offline
post #236 of 522 Old 01-15-2009, 12:31 PM
darinp2's Avatar
Quoted: 1129 Post(s)
Liked: 1765
Originally Posted by Lawguy View Post
Here is a very brief summary of Greg's explanation.
Intra image gamma is not changed by Dynamic Black and no dynamic gamma is used. Greg claims that this approach avoids brightness compression.
It isn't clear to me what Greg is saying here. Using a lens DI to make it easier, dynamic gamma has to be applied before the iris or the gamma will have been changed after the iris, since the iris is reducing the light. For example, for a 20 IRE object, if the iris is shut down the only way to keep that object at the same level is to use a dynamic gamma somewhere in the projector to account for that (like 1/3 * 3 = 1). I suspect that Greg is talking about after the iris, meaning that the projector has a dynamic gamma that pretty much perfectly accounts for iris reduction to keep everything except video black and pixels that will be clipped at the same level. That does mean clipping instead of brightness compression, but clipping can be reduced by making sure the iris isn't too aggressive. Although that same approach can reduce brightness compression.
If they leave headroom with the lamp in order to allow the DI to close further and they get a native on/off CR improvement from that then I can understand that, but they are still limited to the native or static on/off CR of the current iris position.
To avoid BC and clipping they would have to have the iris open on things like some 90 IRE and some 100 IRE stuff on a black background, so wouldn't get as much intra-image CR in scenes like those as if they had a 3.5x improvement to native on/off CR, but it is possible they could get close as far as perception to people's eyes. I doubt it would be indistinguishable over an actual 3.5x improvement to native on/off CR (of course leaving all else equal), but it would be great if they have gotten it close.
--Darin
This is the AV Science Forum. Please don't be gullible and please do remember the saying, "Fool me once, shame on you. Fool me twice, shame on me."
darinp2 is offline
post #237 of 522 Old 01-15-2009, 12:41 PM
beuh ???
post #238 of 522 Old 01-15-2009, 01:06 PM
odyssey's Avatar
Darin,
I read Greg's article and he is saying no dynamic gamma at all. The only change is a simple multiplication of all levels to bring the highest level in the image to full white. The CR improvement is due entirely to the smaller aperture. What I don't understand is how this would increase the CR to 35,000:1. The other potential problem is uniformity. Anything that decreases stray light can cause a uniformity problem. Most, possibly all, of the illumination systems in these projectors rely on stray light to increase uniformity.
odyssey is offline
post #239 of 522 Old 01-15-2009, 01:09 PM - Thread Starter
Quoted: 31 Post(s)
Liked: 56
This was using the 11S2 as well right before the arrival of the Lumis. The 11S2 is no slouch.
Brian
Most Blue Ray looks fine with the Lumis running wide open but I also have a server with content recorded off Satellite at low compression that falls apart at times so yes I am using an ND filter.
I have tried both a 4x and 8x. I prefer the 8x for my taste and screen size. I do not notice any hit to ANSI. I have the ND filter at an angle per odysseys advice below.
All measurements will be performed without any filters.
Originally Posted by odyssey View Post
Schneider makes very high quality glass ND filters with high performance AR coatings. The trick is to use them at an angle of about 7 degrees to minimize back reflections.
Another option is a very low gain screen. Stewart can make matte gray screens in the 0.6 gain range. These would also help with retaining ANSI CR because of the low gain, although the lack of directionality cancels some of that.
post #240 of 522 Old 01-15-2009, 01:30 PM
Kevin Snyder's Avatar
Alan,
Could you please let us know what size / type / brand of ND filters you are using? How do they situate at an angle? Are they actually placed in the lens housing just superficial to the lens itself?
Kevin
Kevin Snyder is offline
