Sim2 Lumis Owners Thread - Page 19 - AVS Forum | Home Theater Discussions And Reviews
 28Likes
post #541 of 2227 Old 05-10-2009, 08:27 AM
odyssey's Avatar
A note of caution regarding the SDI (HD-SDI) BNC connector on the Host. It seems to have a tendency to become loose. If you feel any rotation at all, stop and open the unit to tighten the retaining nut very tightly. It's very easy to do and it could be a good idea to do it before the connector has a chance to loosen. A rotating connector will break the short internal wire connection.
odyssey is offline
post #542 of 2227 Old 05-10-2009, 08:33 AM
thebland's Avatar
Quoted: 1492 Post(s)
Liked: 844
Have you noticed any bugs with HD-SDI that Alan eluded to above?
What do you see vs HDMI at 1080P24?
It's back!! Wine of the Week! Clos Martinet Tinto, Priorat DOCa, Spain ~$60. If you've not had a good Priorat, you've not truly tried Spain's smallest, yet most unique terroir.
My Home Theater of the Month- Le Petit Trianon
thebland is online now
post #543 of 2227 Old 05-10-2009, 08:52 AM
odyssey's Avatar
I have not tested the HD-SDI input fully, but I will soon.
You should not expect an improvement in image quality using HD-SDI vs. HDMI for BD. The advantages of HD-SDI are very long cable runs, compatibility with SDI (HD-SDI) input processors, and no HDMI handshake issues.
odyssey is offline
post #544 of 2227 Old 05-10-2009, 10:55 AM
Health Nut's Avatar
Agreed, additionally, the BNC connector is superior as well. A BNC connection is solid, whereas the HDMI connector is a piece of ****... of course we all know that...
All of the above are more than enough reason for me to want to use HD-SDI...
Will dealers please alert Sim2 to this as well, this is QC stuff that needs to be addressed. Usually people put a lock washer back there as well.
Health Nut is offline
post #545 of 2227 Old 05-10-2009, 11:25 AM
odyssey's Avatar
There is a lock washer, but it's not very effective. The nut needs to be very tight and it's hard to grab it with a wrench. As you can guess, I broke the connection, but my poor soldering skill was good enough for the repair.
odyssey is offline
post #546 of 2227 Old 05-10-2009, 08:49 PM
Art Sonneborn's Avatar
Quoted: 238 Post(s)
Liked: 295
Art
My HT
iRule rules my theater
Art Sonneborn is offline
post #547 of 2227 Old 05-11-2009, 06:57 AM
thebland's Avatar
Liked: 844
Is there a USA SIM2 website?
I go to SIM2.com and it all Int'l.
post #548 of 2227 Old 05-11-2009, 07:07 AM
coldmachine's Avatar
There is, but they're just trying to avoid you, and the inevitable barrage of preposterous questions.
"Wow, do you think you are Adonis"...... "Baby, I'm not A-donis, I'm THE-donis"
coldmachine is offline
post #549 of 2227 Old 05-11-2009, 07:16 AM
thebland's Avatar
Liked: 844
I figured as much........
I just want a PDF of the manual as I am at my office and wanted to do a bit more programming...Do you have a LUMIS manual to email?
post #550 of 2227 Old 05-11-2009, 07:57 AM
Quoted: 238 Post(s)
Liked: 295
Jeff and CM, please respond to PM.
Art
My HT
post #551 of 2227 Old 05-11-2009, 08:42 AM
Art
I didn't receive one. Thats assuming its one you sent today.
post #552 of 2227 Old 05-11-2009, 08:45 AM
I dont, sorry.
post #553 of 2227 Old 05-11-2009, 08:52 AM
Ash Sharma's Avatar
Quoted: 477 Post(s)
Liked: 466
Jeff,
Please check your gmail e mail, I sent you the manual (17MB).
Ash
Ash Sharma is online now
post #554 of 2227 Old 05-11-2009, 09:11 AM
thebland's Avatar
Liked: 844
Thanks, Ash..
I'm at my office and ma programming now...
Can I change the input number of any the 18 inputs?
QUESTION:
For example, HDMI1 is default input #12. Can I make it input #1 for example?
I'd like to make all of my regular inputs low in numbers so if I change an input, it won't renumber them all..
post #555 of 2227 Old 05-11-2009, 09:21 AM
donaldk's Avatar
Quoted: 409 Post(s)
Liked: 85
http://www.sim2usa.com/home/404
Note the 404;-), the page the php refers to doesn't exist. So, http://www.sim2usa.com/home/en should get you there.
And the manual download site doesn't list the lumis.
donaldk is offline
post #556 of 2227 Old 05-11-2009, 10:53 AM
Jason Turk's Avatar
Thanks again Jeff!
It was nice meeting you in person last week!
Jason Turk is offline
post #557 of 2227 Old 05-11-2009, 02:00 PM
thebland's Avatar
Liked: 844
Another Question...
1. How would you set up the HOST to correctly display 1.85 in my CIH set up? Mind you I have movealde masks on the L and R sides and can customize their position for 1.85.
I assume you'd use the custom aspects but how would you adjust?
2. Also, I noticed my HD DVR (Directv) when outputting 1080i60 comes up on the HOST as 1080i30.. Any reason why?
post #558 of 2227 Old 05-11-2009, 11:59 PM
Health Nut's Avatar
By the way, what is the difference in lumen output between the Lumis and HT5000?
As far as 1.85 goes, I remember making a custom setting under "user 2" with the C3X1080... there was a specific number for the vertical and another number for the horizontal that trimmed off the small amount of black bars... I forgot how I did it with the C3x1080, but like you, I'll have to figure out how to do it with the Lumis...
post #559 of 2227 Old 05-12-2009, 05:57 AM
thebland's Avatar
Liked: 844
Last night was the first time I had 20 minutes to go through the menu.. Mother's day was all weekend long, so I had zero time all weekend.
I'll get more time tonight..
I noticed my commands for Signal, Status and Lamp did not work at all (RS-232). I followed the examples exactly (I thought).
Did anyone / you implement these RS-232 commands? Any ideas?
post #560 of 2227 Old 05-12-2009, 10:39 AM
Jason Turk's Avatar
There are 3 custom aspect ratios in the Lumis (per input). You actually have horizontal and vertical control of each, so you can pretty much set most all aspect ratios (when used in conjunction with the standard preset ones).
post #561 of 2227 Old 05-12-2009, 10:43 AM
Jason, excuse my pedantry, but isn't it actually 3 custom ratios per memory, with 6 nameable memories per input, giving 18 ARs per input.
For those wondering how to do it, its really simple......Just enter the "Aspect" menu. There will be 3 user ratios as well as the presets, go into one of those user ratios. Dial the vertical axis to remove the bars. Apply the same number the the horizontal axis to restore correct geometry. Rather than use 3 user ARs in one memory, I would use 1 per memory and rename that memory to reflect your choice. A simple macro will allow easy AR switching. If you are using 12v triggers, each memory can also fire a trigger if required.
post #562 of 2227 Old 05-12-2009, 11:18 AM
Alan Gouger's Avatar
Quoted: 31 Post(s)
Liked: 56
I know everyone has their favorite brand of projector but it is stuff like this that is lacking from other projector manufactures that are keeping the stand alone add on "video processor" guys in business costing us another 4k + just to get back the basic features that the processing chip in these projectors already provide yet the manufactures are not taking advantage of.
Alan Gouger is offline
post #563 of 2227 Old 05-12-2009, 11:24 AM
thebland's Avatar
Liked: 844
Can each input have a separate memory for USER ASPECT 1, USER ASPECT 2, USER Aspect 3?? The Lumagen allows for this.. I think this is what CM is saying that each input will have its own USER ASPECT 1, 2, and 3.... OR are USER ASPECTs 1,2,3 global (meaning you set up the three and each input has the choice of only those 3)??
I could get away with just 3 User Aspect memories (for 2.40, 1.66 and 1.85). 1.78, 4:3 and 2.35 are already available..
As CM mentioned above, I incorporate a defined Aspect in a macro for each type of aspect ratio.
post #564 of 2227 Old 05-12-2009, 11:50 AM
Jason Turk's Avatar
As I would say to my daughters should I make a mistake...whoopsy daisy. You are correct.
Bingo.
post #565 of 2227 Old 05-12-2009, 12:24 PM
Here we go....
Its as I explained above......Each input has 6 user memories that contain all the VP/menu settings, including the three AR settings. Each user memory can be named.This means there are 18 possible user ratios per input.
You could use the 3 user AR slots in 1 memory or just use 1 user AR in each of three separate memories. Using three separate memories allows you to name them appropriately.
Just to be doubly clear...Each input has 6 nameable User Memories. Each user memory has 3 user aspect ratios. This means that each input has 18 user aspect ratios.
Hope that helps.
post #566 of 2227 Old 05-12-2009, 12:44 PM
Totally.
Almost any PJ is fundamentally capable of that sort of flexibility.
The main issue is that very few companies have the expertise to write their own VP software. They are also terrified of the dollar hit that doing so would involve.
The fact that stuff like that doesn't leap out of a spec sheet designed for J6P is another major issue. Its the same with, amongst other things, power control that extends lamp life and minimizes the loss of output over time.
post #567 of 2227 Old 05-12-2009, 12:55 PM
thebland's Avatar
Liked: 844
Here we go....
Hope that helps.
Gotcha.. So, memories are not global.. I appreciate the help, as I get more familiar with the GUI, it should make more sense.. This info will help expedite things..
Appreciate it.
post #568 of 2227 Old 05-12-2009, 01:03 PM
jocurimasini's Avatar
I'm satisfied with my own
jocurimasini is offline
post #569 of 2227 Old 05-12-2009, 01:13 PM
your own what?
post #570 of 2227 Old 05-12-2009, 02:17 PM
cal87's Avatar
Quoted: 30 Post(s)
Liked: 29
For 1.85 material, what are people's opinions on the best way to handle it?
1) Leave it alone so there is no scaling involved and deal with small black bars.
2) Have not tried it, but I am guessing it is about +2 or +3 to H and V for the method that CM describes above. You are scaling from about 1038 to 1080 - any loss of sharpness?
3) Use the lens, stretch a little vertically, and squeeze horizontally - would lose some resolution horizontally, but gain a slightly wider picture.
cal87 is offline
