Sim2 Lumis Owners Thread - Page 51 - AVS Forum | Home Theater Discussions And Reviews
 28Likes
post #1501 of 2222 Old 03-11-2010, 12:02 PM
Health Nut's Avatar
DOH! I remember Jeff Meier Playing with it, I'll have to check... I think mine is fully open... Ok, I'll make sure mine is set to 100
Health Nut is offline
post #1502 of 2222 Old 03-11-2010, 02:54 PM
thebland's Avatar
Quoted: 1414 Post(s)
Liked: 777
Anyone have issues with the Network Settings? I hooked up my internet line to use IRULE IPHONE APP AND NOT ONLY DID THE HOST NOT enter the network menu and had a message 'reading, please wait'. Can't get Network settings to work at all. And it locked up my HOST.
Any ideas?
OWL1 I know has his working.... Anything anyone can suggest?
It's back!! Wine of the Week! Clos Martinet Tinto, Priorat DOCa, Spain ~$60. If you've not had a good Priorat, you've not truly tried Spain's smallest, yet most unique terroir.
My Home Theater of the Month- Le Petit Trianon
thebland is offline
post #1503 of 2222 Old 03-11-2010, 03:12 PM
cal87's Avatar
Quoted: 29 Post(s)
Here is what I did for the network setup.
1. Turn on projector.
2. Change to input with no signal.
3. Enter Network Setup.
4. It takes a minute or so, then comes up with a screen showing your IP address and MAC address. Write down your IP address.
5. Enter the IP Configuration Menu.
6. Change the Port 1 number for Remote Control to a different number (00000 does not work). I chose 10001.
7. Apply the settings.
8. Power off the projector.
9. Turn off the power button on the HOST. Wait 5 seconds and turn it back on.
10. Enter the IP and Port Number (10001 or whatever you chose) into the iRule Network setting.
Not sure why in your case it hung at reading the network settings. Might consider powering off with the button on the HOST and trying again.
cal87 is offline
post #1504 of 2222 Old 03-11-2010, 03:17 PM
shawnwalters's Avatar
Originally Posted by Citation4444 View Post
I'd be very tempted to try the 1.3 bulb. 1.3 refers to the electrode gap, so this version has a wider gap to be fired. If your pj will fire the bulb up, I think it will work fine as all the other characteristics are the same.
Bob
The 1.3 works!!!! I'm happy
How do I rest the lamp counter on my c3x1080?
shawnwalters is offline
post #1505 of 2222 Old 03-11-2010, 03:20 PM
thebland's Avatar
Liked: 777
thanks for the detailed response. Not sure why it hung it up either.
I'll unplug and retry.
You running latest firmware? 3.14.16?
thebland is offline
post #1506 of 2222 Old 03-11-2010, 03:23 PM
cal87's Avatar
Quoted: 29 Post(s)
I think I am on 3.14.08 or thereabouts.
cal87 is offline
post #1507 of 2222 Old 03-11-2010, 03:27 PM
thebland's Avatar
Liked: 777
Gotcha. If no luck I'm going back to 3.14.08.
I'll keep you posted!
thebland is offline
post #1508 of 2222 Old 03-11-2010, 08:00 PM
thebland's Avatar
Liked: 777
OK got it... But I can't see where the iRule Network Settings are. Where do I enter the IP and Port #?
Are they on the iPhone or in the settings page on my lap top.
thebland is offline
post #1509 of 2222 Old 03-11-2010, 08:21 PM
cal87's Avatar
Quoted: 29 Post(s)
In the iPhone/iPod iRule app -
Go to Gateways, Click on the Edit button on the upper right corner.
Under the Network type gateway, select add new gateway.
Enter the name, IP address and port number.
Then connect to device and choose the proper device (the Lumis) under the list. This is the device that you have added/created in the iRule Builder.
cal87 is offline
post #1510 of 2222 Old 03-11-2010, 08:41 PM
thebland's Avatar
Liked: 777
Hey Cal. Entered it.
Everything seems right.
But when I go to PANELS, select my LUMIS, the app is trying to connect but comes up with an error message 'Failure to connect to gateways"
Now I didn't add a new gateway any where (just the IP and port #)... Am I missing something?
This should work over the ipHone network... not having wifi on.. Any ideas? Thanks for your help.
EDIT: It works over the home's WIFI network but not on the AT&T network
EDIT: Works on WIFI but I think my router is ****-blocking my iPhone from reaching my LUMIS. GOtta punch a hole in my firewall...
Very cool.
thebland is offline
post #1511 of 2222 Old 03-11-2010, 09:21 PM
thebland's Avatar
Liked: 777
I also noticed when setting up SIM2 Network that RS-232 commands fail and IR is how you go.
thebland is offline
post #1512 of 2222 Old 03-11-2010, 10:41 PM
cal87's Avatar
Quoted: 29 Post(s)
Next thing to do is to open up a port on your home network so you can control your equipment from a remote site. I have not figured out how to do this yet.
cal87 is offline
post #1513 of 2222 Old 03-12-2010, 04:50 AM
thebland's Avatar
Liked: 777
Itai stopped by my place yesterday... He did this for another IpHone app that needed to get through my firewall. I am sure he'll figure this out, too (he said he could)... I'll pass along the info. Using a U-Verse 2WIRE router (but do not use their crappy cable service.
thebland is offline
post #1514 of 2222 Old 03-14-2010, 08:31 PM
thebland's Avatar
Liked: 777
3.14.16 issue.
EDIT: NO ISSUE> BAD COMPONENT CABLE. ALL IS GOOD!!!
With component output, picture is greenish and flashes a bit between green an normal for first 15 minutes then fades off to normal. This does not occur with HDMI.
Anyone else notice this? Did not have this with 3.14.08. Using D* HD DVR OVER COMPONENT. Looks like I'll be going back to prev firmware.
thebland is offline
post #1515 of 2222 Old 03-16-2010, 11:43 PM
Wireless_Mind's Avatar
This past weekend I had a professional calibration performed by Jeff Meier on three video displays. Jeff calibrated my Lumis Host, Kuro 111FD and Sony Bravia LCD. Since the calibration I'm totally impressed with the improved picture quality of all 3 displays. I'm especially impressed with the improved picture quality, of the Lumis Host and Kuro 111FD. I thought these units produced a very good picture prior to the calibration, but I'm astounded by the improved picture quality after the calibration. I also had Jeff calibrate the audio in my HT. Once again, I was impressed with the outcome. Jeff provided valuable feedback for improving sound quality. As with others that have used Jeff service, I highly recommend Jeff's work.
Wireless_Mind is offline
post #1516 of 2222 Old 03-18-2010, 02:35 PM
Coyote Waits
htwaits's Avatar
Quoted: 901 Post(s)
Liked: 1999
Originally Posted by Wireless_Mind View Post
This past weekend I had a professional calibration performed by Jeff Meier (UMR) on three video displays. Jeff calibrated my Lumis Host, Kuro 111FD and Sony Bravia LCD.
Thanks for your calibration report. I've included it in the lists that are linked at the bottom of my post.
htwaits is online now
post #1517 of 2222 Old 03-18-2010, 03:20 PM
thebland's Avatar
Liked: 777
Where's the link?
thebland is offline
post #1518 of 2222 Old 03-18-2010, 07:03 PM
Home Theater Lover
Craig Peer's Avatar
Quoted: 2673 Post(s)
Liked: 2462
It's here - click on -
Customer's Reports -- Professional Calibrations
( in htwaits post ).
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is offline
post #1519 of 2222 Old 03-19-2010, 12:31 AM
Coyote Waits
htwaits's Avatar
Quoted: 901 Post(s)
Liked: 1999
Right. Just point and click. The flat panel reports are in Post#2, all the other reports are in Post#1.
post #1520 of 2222 Old 03-21-2010, 06:40 AM
owl1's Avatar
I’m astounded by the improved picture quality after the calibration. I also had Jeff calibrate the audio in my HT. Once again, I was impressed with the outcome. Jeff provided valuable feedback for improving sound quality. As with others that have used Jeff service, I highly recommend Jeff's work.
Man, I was also very surprised at the improvement. These are truly spectacular machines. After spending some time at 16ftL however I am going to play around with higher bulb settings and see what reintroducing some serious slam will do...Hopefully I don't have to recalibrate if everything is linear (which I doubt). The picture is just so perfect now that I hate to mess with Jeff's settings. But I will
owl1 is offline
post #1521 of 2222 Old 03-23-2010, 02:03 PM
JeffinChelsea's Avatar
Owl,
I have a similar question regarding higher bulb settings. Finally decided the Lumis (w/o host) was reliable enough to finally justify replacing my Qualia. Jason installed it Sunday and no regrets. IMHO, bests the Qualia in every way. Currently, on my 13"8" wide 1.78 SMX I am running at lowest bulb setting with manual iris at 100 (wide open). Has anyone played with closing the iris down to 0 and turning up the bulb to compensate for the light loss? The crux of the question is would this lead to higher contrast with the same image brightness? Like I said, love the image currently, but always fun to play!
Jeff
JeffinChelsea is offline
post #1522 of 2222 Old 03-23-2010, 02:54 PM
thebland's Avatar
Liked: 777
Originally Posted by JeffinChelsea View Post
Owl,
Jeff
Congrats.... from an ex-Qualia owner.
Have not tried playing with the iris.
thebland is offline
post #1523 of 2222 Old 03-23-2010, 03:10 PM
umr
umr's Avatar
Quoted: 33 Post(s)
Liked: 76
Owl,
Jeff
I have played those games and found no benefit to ANSI or sequential contrast. I would use the lamp and iris to achieve a target light level.
umr is offline
post #1524 of 2222 Old 03-23-2010, 08:59 PM
barrakmf's Avatar
Is that 13'8" or 138" width screen? What's the screen gain?
barrakmf is offline
post #1525 of 2222 Old 03-24-2010, 04:33 AM
thebland's Avatar
Liked: 777
If 13'8", that is more screen sq footage than I have... And I'm 250W! Then again I have a bulb with 400 H. Newer bulbs are at their brightest... of Jeff has some magic.
thebland is offline
post #1526 of 2222 Old 03-24-2010, 05:48 PM
Christy Warren's Avatar
Has anyone seen a Lumis 3D?
Christy Warren is offline
post #1527 of 2222 Old 03-25-2010, 10:32 AM
Thanks UMR and all for the advice. I guess I'll leave the manual iris wide open and the bulb at 230, giving me more head room at bulb ages. The screen is 164" wide 1.79 SMX, which I have been told is around 1.1 (or maybe a little more?) gain. The theater is absolute black hole (even went with black cloth chairs rather than black leather to keep reflections down. Plenty bright with new bulb, manual iris at 100, and 230 watt setting. Jason Turk may be able to provide data on ft. lamb at screen, but visually obvious to all family members that it is brighter than Qualia with High Lamp and Open iris settings (1100 hours on Qualia bulb).
post #1528 of 2222 Old 03-25-2010, 11:40 AM
umr
umr's Avatar
Quoted: 33 Post(s)
Liked: 76
I will be in your area in May if you want to get the audio and video setup. I can also tell you how many foot Lamberts you are getting.
umr is offline
post #1529 of 2222 Old 03-25-2010, 02:11 PM
barrakmf's Avatar
That's even bigger than my 180" diagonal 16:9 screen (13' width). Mine has unity gain so they're both fairly equivalent in terms of light reflection. I'm getting 13.5 ft-L after calibration at maximum iris and lamp power (counter at 50 hrs). Every 10W reduction shaves off approximately 5% from light output.
barrakmf is offline
post #1530 of 2222 Old 04-01-2010, 09:23 PM
thebland's Avatar
Liked: 777
Iris pumping.
Never really noticed it til tonight. Watched the Blind Side. The latter half of the film was full of iris pumping scenes. 20 or 30 scenes. Aside from that the video was phenomemal.
I never, ever noticed this before - except perhaps here and there recently. I'd bet it is the latest firmware as it is the only change in my set up. I have the previos firmware. I'll reinstall.
Stay tuned....
thebland is offline
