Sim2 Lumis Owners Thread - Page 54 - AVS Forum | Home Theater Discussions And Reviews
 35Likes
post #1591 of 2245 Old 06-19-2010, 03:35 AM
thebland's Avatar
Quoted: 1676 Post(s)
Liked: 1012
Originally Posted by coldmachine View Post
My own DI became slightly visible a while back, and a hard rest took acre of it.
I only mention this as I was given the following advice, if a straight deselect/reselect of the DB fails to clear the issue.
Assuming the DI is selected and the unit is powered up.... De-select DI and power down the entire unit, including the Host. Disconnect from mains.
Reconnect and power up. Select DB to on. Power down as before, including mains disconnection.
Reconnect and power up. Done.
CM,
What are 'mains' you're referring to? Unplugging the main power cords (HOST and Lumis) from the wall??
I'd like to try this.
Goodbye to a great audio and video genius and writer... JOHN GANNON. I enjoyed your friendship, wit and a nice long run we took around Indianapolis at CEDIA years back... and for buying my Runco 980 Ultra years back... you saved my ass! Rest in peace.
thebland is offline
post #1592 of 2245 Old 06-19-2010, 04:10 AM
coldmachine's Avatar
Yes, household power.I was addressing an international audience
I used the term "Hydro" s a kid, but when I stated working in the US no one knew what I meant.
http://en.wikipedia.org/wiki/Mains_electricity
"Wow, do you think you are Adonis"...... "Baby, I'm not A-donis, I'm THE-donis"
coldmachine is offline
post #1593 of 2245 Old 06-19-2010, 05:23 AM
thebland's Avatar
Liked: 1012
Gotcha, eh!?
Well, if this does it, I guess we can assume this pumping is a software related issue rather than a failing hardware problem.
thebland is offline
post #1594 of 2245 Old 06-22-2010, 12:49 PM
Gary16's Avatar
Quoted: 61 Post(s)
Seems to have worked for me. Two days. No visible pumping. First time since I've had the Lumis.
Gary16 is offline
post #1595 of 2245 Old 06-22-2010, 01:29 PM
thebland's Avatar
Liked: 1012
I did the re-do last week. Haven't had time for a movie yet. Cool.
thebland is offline
post #1596 of 2245 Old 06-22-2010, 03:07 PM
Home Theater Lover
Craig Peer's Avatar
Quoted: 4145 Post(s)
Liked: 4228
I'll have to watch " The Blind Side " now as a test.
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is offline
post #1597 of 2245 Old 06-22-2010, 05:12 PM
Glad to be of assistance.
post #1598 of 2245 Old 06-22-2010, 10:27 PM
Dizzman's Avatar
Word! i still have problems with words nobody seems to know
A toque is a hat,
a chesterfield is a couch,
and it is pronounced 'zed' not 'zee', 'zed' !!!!
just hanging out, rollin with the flow.
Dizzman is offline
post #1599 of 2245 Old 07-08-2010, 04:15 AM
thebland's Avatar
Liked: 1012
CM,
You da man! My dynamic iris had become so bad, I had to disengage it.
I have watched 3-4 movies since following your Dynamic Iris fix protocol (above) and my dynamic iris is fixed!!!
No issues what so ever. I actually forgot it was broken and had to check my menu just to see if I even had Dynamic Iris engaged.. I did!
thebland is offline
post #1600 of 2245 Old 07-11-2010, 01:02 PM
mani's Avatar
Quoted: 70 Post(s)
I am thinking of buying Sim2 lumis for 12-13 ft wide 16:9 screen . I talked to my local dealer and he told me that lumis is not meant for that big screen and I will need 5000e. I will like to get opinion of the lumis owners. My theater won't we done for another 2-3 mths.
mani is offline
post #1601 of 2245 Old 07-11-2010, 02:31 PM
thebland's Avatar
Liked: 1012
Looks like revenue is down for your dealer.. I have a 14' wide scope microperf that lights up like a champ with one Lumis.
That said, to get max light output, place the Lumis at the end of it's throw such that the lens is wide opened. I am at the very front (2.7ish) of the T3 lens throw.
Two projectors would be a headache to place and converge... I'd get a bigger output model like the HT5000.
thebland is offline
post #1602 of 2245 Old 07-11-2010, 02:48 PM
mani's Avatar
Quoted: 70 Post(s)
Thanks for the input. But my screen will be 16:9, so even 12 ft wide screen will have more surface area to light , than 14 ft wide scope screen... 87 vs 84 sq ft. So is that the limit for lumis to comfortably light the screen without compromising black levels , contrast and the "pop" . Also it will be important to have some headroom to account for aging of the bulb!
mani is offline
post #1603 of 2245 Old 07-11-2010, 03:17 PM
thebland's Avatar
Liked: 1012
True but add 10% screen size to my sq footage due to perfs and my screen is net larger (92.4 v. 87)...
UHP drop off is not like xenon. I have not noticed much light drop off and I'm at 400 hours.
But if you want more and need headroom, just buy the 5000.
thebland is offline
post #1604 of 2245 Old 07-11-2010, 05:02 PM
mani's Avatar
Quoted: 70 Post(s)
Hi Jeff
My screen will be AT as well. I definitely dont want to spend any more than Lumis. I was fairly confident reading through all these posts that Lumis will be able to light 12-14 ft 16:9 screen without any problem. Its only after talking to the dealer I am having doubts. He is selling Demo HT5000 at lower price than Lumis (Its not 5000e). So i gues its not money -... thats why I am second guessing my decision now.
But if you say that Lumis is lighting 92 sq ft AT screen with enough headroom left with no compromise on black levels and POP , than I do feel more comfortable.
IS anyone else using it on bigger screen??
Mani
mani is offline
post #1605 of 2245 Old 07-11-2010, 06:10 PM
thebland's Avatar
Liked: 1012
I think my screen is the largest.
If you want max light, you have to have it at with the minimum zoom at the 2.7 end of the T3 lens, for example. If you are zooming into the screen, it will limit the light output (but inc CR).
So where you mount it is critical for you since you need light output.
If you're near Detroit, come on out and I'll demo it!
thebland is offline
post #1606 of 2245 Old 07-11-2010, 07:35 PM
mani's Avatar
Quoted: 70 Post(s)
Hi Jeff
Thanks for ur offer. I used to live in Harper Woods till about 8 yrs ago, but I am in Phoenix now.
mani is offline
post #1607 of 2245 Old 07-14-2010, 11:22 AM
scottsol's Avatar
Quoted: 27 Post(s)
Liked: 31
Mani
Your dealer has a very expensive out of date display model that he is dying to get rid of. He may be giving you his honest opinion, but it also happens to be self serving.
scottsol is offline
post #1608 of 2245 Old 07-17-2010, 07:05 AM
adidino's Avatar
Quoted: 367 Post(s)
Liked: 282
What's the bottom line on this projector? Is it still worth considering at this point or wait for CEDIA/CES?
adidino is offline
post #1609 of 2245 Old 07-17-2010, 07:49 AM
thebland's Avatar
Liked: 1012
It's is an excellent pj. Perhaps the best. Butid still check CEDIA..
thebland is offline
post #1610 of 2245 Old 07-22-2010, 01:04 PM
wiseknight's Avatar
Originally Posted by shawnwalters View Post
Just opened mine (C3X1080) up tonight! It is very easy and will also be easy to change. The lamp itself just snaps in and can come out with 4 screws on the front and then 2 screws for the wires. I didn't actually change mine yet, since it was just an exploration mission, but now I know I can change my lamp for only a couple hundred bucks! Now I rack up the hours big time Actually I already have 1500 and it still looks great, but I should have one on hand.
Anyway, looks like this lamp is available online. I found a couple places that sold it. So I'll try one of them and see.
The lamp is: osram p-vip 250/1.0 p22
Hi Shawn, what is the manufacture date on your C3X1080 ? -
wiseknight is offline
post #1611 of 2245 Old 07-28-2010, 12:39 PM
Home Theater Lover
Craig Peer's Avatar
Liked: 4228
Just got my Lumis back from SIM2. I couldn't do a firmware update as my projector was one of the first out, and needed a hardware update to take the current firmware. Had them put a new bulb in too, as I always felt my original bulb was not as bright as others reported theirs were. Everything works and looks great !! No more menu freeze, and with the manual iris closed and the bulb power at its lowest setting, we are back up to 26 foot lamberts - just where I like it!! Kudos to SIM2 and AV Science for great service!!
Also, that trick of turning off the dynamic iris and turning it back on really works great. No pumping at all with anything other than " The Blind Side ". Watched " The Blind Side " and while there are about 12 scenes that do something weird ( I wonder if those scenes pump on other DI projectors ? ) the rest of the movie looked great.
post #1612 of 2245 Old 08-03-2010, 06:56 PM
Scott Horton, techht.com
GetGray's Avatar
Quoted: 194 Post(s)
Liked: 155
Still necessary after your service?
GetGray is offline
post #1613 of 2245 Old 08-04-2010, 08:36 AM
Home Theater Lover
Craig Peer's Avatar
Liked: 4228
To what do you refer, the DI on / off trick? Everything is working great right now - just like new. IF I see pumping again after a few hundred hours, I'll know what to try anyway.
post #1614 of 2245 Old 08-04-2010, 08:41 AM
Gary16's Avatar
Quoted: 61 Post(s)
FWIW, mine was pumping from day one including after several firmware updates. Only after I did the on/off reset did the pumping stop. What I don't understand is why no one at Sim seemed to know about this since they were aware of pumping complaints for several months?
Gary16 is offline
post #1615 of 2245 Old 08-04-2010, 09:45 AM
thebland's Avatar
Liked: 1012
Mine has been good since the ON/OFF trick.
Mine was not pumping at all, many months after purchase, until recently.
thebland is offline
post #1616 of 2245 Old 08-04-2010, 12:51 PM
Home Theater Lover
Craig Peer's Avatar
Liked: 4228
Same here.
post #1617 of 2245 Old 08-08-2010, 09:05 AM
Warren460's Avatar
Later today, I am planning to do a firmware update on my non host lumis.
This will be my first firmware update and I am a little apprehensive.
Will I lose any settings, do I need to back up anything before following the sim update instructions. Will my calibration be affected?
Warren460 is offline
post #1618 of 2245 Old 08-10-2010, 02:28 PM
hhelmut's Avatar
Sorry to say, but with the firmwareupdate you will loose all your settings and calibrations, you cannot store it; you have to note it;
on the other way I would recommend a new calibration. Firmwareupdate will also affect the videoprocessing. Settings based on the older firmware are often not okay with the new firmware
But doing the settings and the calibration new with the LUMIS running on the latest firmware, you will win in a better picture
________________
hhelmut
hhelmut is offline
post #1619 of 2245 Old 08-10-2010, 03:26 PM
Gary16's Avatar
Quoted: 61 Post(s)
________________
hhelmut
Previous firmware updates did not cause settings to be lost. Is this something new?
Gary16 is offline
post #1620 of 2245 Old 08-10-2010, 06:01 PM
thebland's Avatar
Liked: 1012
Must be new... or the poster is mistaken.
thebland is offline
