Playing DVD's on Barco DP-1500 - AVS | Home Theater Discussions And Reviews
post #1 of 7 Old 03-12-2009, 12:18 PM - Thread Starter
7horns's Avatar
This question will seem very n00bish, because, well, I'm a n00b.
I'm part of an organization that collects independent movies from around the world and shows them around Beijing. We're fairly new, and we've been learning the technical details involved in our hobby as we go. Up to now, that's been DVD's or AVI's run off our laptops to small home projectors in bars or very small theaters; which means that our expertise goes DVD->tray->VGA out->watch.
But we've just been smacked with an opportunity to fill a theater...if we can figure out the equipment. We have DVD's and laptops, and we need to play them on a Barco DP-1500.
Here's what I've been able to figure out in my research:
1) We need a DVI-D cable, or an HDMI->DVI-D adapter.
2) We might need to convert the video to JPEG 2000 (this is what my friend's friend tells me, don't know if he knows what he's talking about). If this is true, what software we'll need to do this, and how specifically to go about this, I don't know.
3) We might need to look into getting a DVD player. This being China, there are 500 brands on the market and none of them are the familiar North American/European ones, so if we take that route we'll need to know specifically what features to look for.
Any help is appreciated, and if you're in Beijing, beers are on offer if you can help me figure this out!
7horns is offline
post #2 of 7 Old 03-12-2009, 02:00 PM
Dizzman's Avatar
the DP 1500 has an external switcher/input box for it that has all the different ones. that is choice number 1.
HDMI-DVD may not work due to the fact that HDMI may have ancryption on it. your best bet is a scaler that has a DVI output.
other than that, get the adaptor and find a few dvd players (oh my goodness... where ever will you find one) and see if it works.
Proud Daddy to Anastasia and Christopher.
Born October 26 2005.
Ob was the delivery doc.
Since i cannot rant on a soapbox in the town square...
http://commonsensehasdied.blogspot.com/
Dizzman is offline
post #4 of 7 Old 03-20-2009, 06:20 AM
Tedd's Avatar
Quoted: 259 Post(s)
Liked: 114
Why not just plug the laptops into the Barco and set the resolution to the Barco's 2048 x 1080 native resolution?
If we're solely talking dvds here, find yourself an Immersive Holo3Dgraph card on the used market and install it into an XP based pc. It will give you 480i capture via component or SDI. Plug a dvd player into the H3D card and set the pc video output to the Barco's native 2048 x 1080 resolution.
Tedd is offline
post #5 of 7 Old 03-20-2009, 07:39 AM
AVS Club Gold
Alan Gouger's Avatar
You can use Qube Master express to convert JPEG and BMP images; Flash animations; and AVI and Quicktime movies into standards compliant DCPs in DCI JPEG2000 format.
http://www.qubecinema.com/qmx/default.htm
Alan Gouger is offline
post #7 of 7 Old 06-01-2009, 08:54 AM
neurainbow's Avatar
Have you solved the problem?
I have a familliar problem.
neurainbow is offline
