Monster MP HTS 5100 SS vs. Panamax M5400-PM - chime in from the high end folks - AVS Forum | Home Theater Discussions And Reviews
Old 10-12-2009, 09:29 AM - Thread Starter
mrtvgame's Avatar
So I did a search and saw there was a brief discussion on this back in 2007.
I have a dilemma as to which on these two units I should add to my gear.
I can get the Monster HTS 5100 Signature Series for $300 and the Panamax M5400-PM for $360.
Price aside, does anyone have insight into which unit is better for overall filtering and line protection.
I see in this section you guys would probably go with something better but if you have opinions or experience with these products please chime in.
Thank you!
mrtvgame is offline
Old 10-12-2009, 11:22 PM
rider's Avatar
Monster products = overpriced crap
Monster advertising = fraudulent claims and/or deceitful misrepresentation
"I am determined to be cheerful & happy in whatever situation I may be; for I have also learned from experience that the greater part of happiness or misery depends upon our dispositions & not upon our circumstances."
Martha Washington
rider is offline
Old 10-13-2009, 02:56 AM
kucharsk's Avatar
Quoted: 1261 Post(s)
Liked: 685
Now that we've had the Monster hater take on things, the Monster Power products are actually quite good.
It's sort of your call as to whether the Monster or Panamax products suits your purposes better and/or is priced better.
Both will do surge suppression/protection and do reasonable quality filtering.
kucharsk is offline
Old 10-13-2009, 04:40 AM
rider's Avatar
And now that we've had the Monster fanboy take on things, back to reality.....
Martha Washington
rider is offline
Old 10-13-2009, 05:15 AM - Thread Starter
mrtvgame's Avatar
And this is not what I wanted back and forth.
Anyone with informed opinions or experience with both models?
mrtvgame is offline
Old 10-13-2009, 08:30 AM
Curt Palme's Avatar
Quoted: 32 Post(s)
Liked: 58
Yes, neither unit has significant surge protection devices or power conditioning equipment to make a difference to your system. Do a search on various power conditioning threads here, and you'll find some suggestions on what to buy to get protection to happen right at your breaker panel.
The small amount of parts in the box are more or less already duplicated within your stereo equipment, and both brands do cater to your fear factor in order to sell stuff that you don't really need.
You also need to figure out why you want a power conditioner in your system. If you have brownouts or power sags, you'd need significantly larger and more expensive units to cure that. If you have frequent lightning strikes in the area, a brute force crowbar style unit at the breaker panel will do more good than the Monster or Panamax units.
www.curtpalme.com - CRT tech info
www.soundsolutionscanada.com -pro audio website
Curt Palme is offline
Old 10-13-2009, 08:40 AM
Dizzman's Avatar
if you have line issues (and that is a MASSIVE IF) then there are many better steps to take.
if you have been sucked in as to how bad your power is by either of their marketing materiels... then please understand that the term power conditioner is a meaningless term.
If you need a voltage regulator... ok
If you need a surge supressor... ok
If you need a UPS... ok
in all of those categories there are many better. IF you need anything at all.
just hanging out, rollin with the flow.
Dizzman is offline
Old 10-14-2009, 01:11 PM
kucharsk's Avatar
Liked: 685
Ah, I'm a fanboy because I don't consider their products garbage.
That makes sense…
kucharsk is offline
Old 10-14-2009, 02:33 PM
JamE55's Avatar
Thank you!
Don't have any experience with Panamax so i can't comment on their stuff. However i do own a Monster HTUPS 2700 which i've had for almost a year now and pretty satisfied with it. It weighs somewhat on the heavy side which is ok because it's probably the transformers and regulators that's in there.
The nice thing i like about it is the stabilizes the electricity. So any spikes, noise or fluctuations it keeps it in check and you can hear the clicking inside the unit which tells me it's doing it's job. Not really sure about HTS 5100 so no comment on that either. Another great feature on the HTUPS 2700 is that there's a backup battery. So if the electricity goes out and you have that unit hooked up to a DVR it'll keep on recording for a few minutes or so.
Hope that helps.
JamE55 is offline
Old 10-14-2009, 09:01 PM - Thread Starter
mrtvgame's Avatar
Okay, how about I throw Furman into the mix. Now also considering either the Elite 15PFi or the 20PFi.
Any thoughts?
mrtvgame is offline
Old 10-14-2009, 09:44 PM
Mr.Poindexter's Avatar
Quoted: 20 Post(s)
Liked: 29
I haven't owned a Panamax but I have owned several Monster HTS-5000 and one did in fact stop a power problem from killing a component. My old house had some jacked up ground differentials that killed items before when put on multiple circuits. The power filter saved me once but smelled like smoke afterwards. I have also had several Adcom power filters and Equitech balanced power filters.
That said, I wouldn't buy another Monster unit. While I don't agree with their company's ethics, the real reason is I think that balanced power is really the way to go for power filtering and as for surge protection, you can do that at the breaker panel most cost effectively.
Mr.Poindexter is offline
Old 10-14-2009, 09:50 PM
SRR
SRR's Avatar
http://cdn1.libsyn.com/gearcast/Surg...9a19540bc67bd8
http://www.fullcompass.com/brand/SGX...-Standing.html
I don't work for fullcompass, but that podcast better have you thinking away from mov based surge protectors aka Monster, Panamax, low end Furman's (low end furmans as in $100 ones). But the higher end furmans $230 or so and up have similar surge protection as the surgeX products. I bet it is a toss up on which has the better filtering.
SRR is offline
Old 03-27-2013, 01:10 PM
ss9001's Avatar
Quoted: 338 Post(s)
Liked: 397
Resurrecting this old thread
I can't comment on how one works over the other. But I can state that I've owned 3 Monster power/surge centers (2600, 5100 signature & hdp1800) and there's only 1 left that works (2600) 2 didn't die but developed problems over the yrs: 5100 with the delays (died early on) & recently the filtration circuitry (died) & the 1800 with the microprocessor shut-off circuitry (doesn't work on 2 outlets but works on others).
OTOH, the Panamax 20 amp 4400 I've owned for as long as the 2600 is still working just fine so I bought a Panamax 4300PM to replace it & had planned to replace the 5100 with the 5400PM Panamax.
Based on my own experience over 9 yrs, I wouldn't trust another Monster Cable power product & won't ever buy another one at any price. they are not reliable.
Sorry but my having to replace another fubar'd Monster made me respond to this old thread just to vent tongue.gif
I'm going to look at Furman & SurgeX before I buy the Panamax.
Steve
ss9001 is online now
