ADA Mach 4......WOW!!!! - Page 43 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #1261 of 2151 Old 01-17-2012, 11:42 AM
Randy Bessinger's Avatar
Quoted: 210 Post(s)
Liked: 166
Originally Posted by AngelEyes View Post
Hi Randy,
A few things, 'Update All' won't change the inputs, you need to 'retrieve inputs' to update the software, make the changes and then either 'Send input' or 'Send All' if you have edited more than one.
If connecting via network use a Static IP on the laptop and use the ISO-E to set things up just to make sure. You should have a manual for that to.
Don't use the Beta software as it does have a few minor bugs so really it is best to rule that out.
Adam
ok, thanks.
Update...got it working. Thanks to those here and a special thanks to Dennis Erskine.
Randy Bessinger is offline
post #1262 of 2151 Old 01-17-2012, 12:23 PM
magicj1's Avatar
Quoted: 67 Post(s)
Originally Posted by thebland View Post
IF you go iRule or RTI, I can have working codes to you in a minute... Easy to program.
pm sent
magicj1 is offline
post #1263 of 2151 Old 01-17-2012, 02:09 PM
virusc's Avatar
Does anyone have the program for the Mach2 ?
or any of the older gear for that matter?
It is not on the ADA site anymore and I need to reconfigure mine.
virusc is offline
post #1264 of 2151 Old 01-18-2012, 04:56 AM
Joelc's Avatar
Originally Posted by kamenoff View Post
Joel, it looks nice but is there any real difference between the Cinema Ref and the Mach IV + Trinov? Do you really need all these interconnects? I would still audition it first before throw your hard earned money...
This is the dilemma that I am facing in that as much as I would like to audition the piece it seems impossible and, yes, it is an awful lot of money for how much a sound improvement...this is why I am still thinking about it...
By the way I also don't get two way connection with my Mach IV..When I connect my laptop I always get the default settings, not my Unit's settings..Would be nice to get two way communication...
As noted above when you load the HD Suite software all you get is teh default settings...you need to press Update All and go from there...with that, I will also add that I found that sometimes the Update All does not work and one needs to hit Update for the specific tab that they are in...
If there is anything else, let me know as I am happy to help...
Joel
Some people choose to have a pool, I choose to have a home theater!
Joelc is offline
post #1265 of 2151 Old 01-18-2012, 05:13 AM
magicj1's Avatar
Quoted: 67 Post(s)
ADA BUS connector.
So I have my Global Catche IP2RS, my cable is made, but my ADA BUS connector is not their on the back of my ADA .
I have emailed my supplier, but I was just wandering if this was a common connector, could I buy one from ebay?
magicj1 is offline
post #1266 of 2151 Old 01-18-2012, 05:16 AM
AngelEyes's Avatar
Originally Posted by magicj1 View Post
ADA BUS connector.
Yes it is a standard connector
Adam
AngelEyes is offline
post #1267 of 2151 Old 01-18-2012, 05:20 AM
magicj1's Avatar
Quoted: 67 Post(s)
Adam
You couldn't give me a link to one please Adam
magicj1 is offline
post #1268 of 2151 Old 01-18-2012, 05:42 AM
AngelEyes's Avatar
This should work although ideally you want one with the same orientation as the ones that come with:
http://uk.rs-online.com/web/p/terminal-blocks/1896509/
The one top right in this picture is the actual orientation ADA use I believe:
http://uk.rs-online.com/web/p/terminal-blocks/1012818/
Adam
post #1269 of 2151 Old 01-18-2012, 07:53 AM
magicj1's Avatar
Quoted: 67 Post(s)
Adam
Thanks Adam. I will get one ordered right away.
magicj1 is offline
post #1270 of 2151 Old 01-18-2012, 08:07 AM
AngelEyes's Avatar
Welcome
post #1271 of 2151 Old 01-18-2012, 09:24 AM
Skillet's Avatar
PM Sent.
Skillet is offline
post #1272 of 2151 Old 01-18-2012, 01:17 PM
s_inman's Avatar
Originally Posted by Skillet View Post
PM Sent.
I could also do with this .
s_inman is offline
post #1273 of 2151 Old 01-21-2012, 05:56 AM
magicj1's Avatar
Quoted: 67 Post(s)
Welcome
I am liking this ADA/RS232 control Adam, it's so much more responsive than my old Harmony.. Very nice
Thanks again for all your help.
magicj1 is offline
post #1274 of 2151 Old 01-21-2012, 03:48 PM
DazedandConfused's Avatar
Hey guys, I'm luckily enough to be the new owner of a Suite 7.1 HD. I purchased it used so I don't have a relationship with the local dealer - yet. The seller did not include any of the documentation or the PC setup program. I was able to download the June 2010 edition of the Installation Manual and the June 2010 edition of the User Manual from the ADA web-site. My unit left the factory in August 2011, but I assume that the guides are still current (please let me know if I'm wrong on that point).
What would help me out immensely is if one of you generous AVSForum members would help me get a copy of the PC software to program the Suite 7.1 HD. I believe my sample has firmware version 3.02 and I would need the software that works with that version.
I think this is going to be a significant upgrade over the Marantz AV7005 that I'm running now and I'm looking forward to getting it ready to take the Marantz's place in my system.
Thanks for the help
My user name says it all
DazedandConfused is offline
post #1275 of 2151 Old 01-21-2012, 04:09 PM
AngelEyes's Avatar
Thanks for the help
Send me a pm with your email
post #1276 of 2151 Old 01-21-2012, 06:08 PM
Quoted: 210 Post(s)
Liked: 166
I am really happy with the Suite 7.1. Bland does not lie!
post #1277 of 2151 Old 01-23-2012, 12:25 PM
magicj1's Avatar
Quoted: 67 Post(s)
You will have to give us your honest opinion once you get set up and running. I was considering the AV7005 at one point
magicj1 is offline
post #1278 of 2151 Old 01-24-2012, 10:01 AM
I sure will. I just got it working yesterday and will need to spend a little time with it to get a handle on how it sounds.
post #1279 of 2151 Old 01-24-2012, 10:03 AM
magicj1's Avatar
Quoted: 67 Post(s)
Great stuff, thanks
magicj1 is offline
post #1280 of 2151 Old 01-26-2012, 11:24 AM
magicj1's Avatar
Quoted: 67 Post(s)
Originally Posted by DanFrancis View Post
If you control via RS-232; the feedback is always there.
The controls for the Suite7.1, Suite 7.1HD, Rhapsody MachIV, Reference, are all the same so you can absolutely do this with a Suite 7.1HD.
Dan
Is there a setting within the ADA's menu I need to set for the volume feedback to work?
magicj1 is offline
post #1281 of 2151 Old 01-26-2012, 12:04 PM
AngelEyes's Avatar
No, it always provides feedback.
Adam
post #1282 of 2151 Old 01-26-2012, 02:05 PM
kamenoff's Avatar
Quoted: 91 Post(s)
Liked: 29
Guys, last night I watched "Abduction" on Blue-Ray. If somebody has any doubt how the Rhapsody sounds should watch this movie. The most impresive were the clarity of the dialog and the tight bass. In the movie there was shooting, explosions, trains and helicopter sounds. I felt that it was happening in the room. The seats were trembling, the kids were crying and suddenly my wife's period came again...great stuff.
I think that the movie will be great for demonstration purposes but at the sme time reassurence how great this machine sounds.
HT Gear: Altitude 24/32, Quested Lt8 x 11, Paradigm Sub 1, ATI AT6000 Reference, Anthem Statement P5; PJ JVC X9000, PJ Screen: Screen Excellence (Reference)
kamenoff is offline
post #1283 of 2151 Old 02-04-2012, 08:19 AM
magicj1's Avatar
Quoted: 67 Post(s)
How do the 'Discrete Cinema' Modes work? What I mean is I have been setting up iRule to control my ADA, for this I have been using mani's Mode tab's so I can switch between my favourite modes, and I have found that I can switch to all Modes except for the 'Discrete Cinema' ones.
magicj1 is offline
post #1284 of 2151 Old 02-04-2012, 09:19 AM
Joelc's Avatar
I do not know exactly what you mean by the "Discrete Cinema" one but it may be the source input...that is, the surround modes that are available for 5.1 / 7.1 signals are different than those that are available for 2.0 / 2.1 sources...try changing the source to ensure that you are inputting a 5.1 source...
Joel
Joelc is offline
post #1285 of 2151 Old 02-04-2012, 09:26 AM
magicj1's Avatar
Quoted: 67 Post(s)
Hi Joel, sorry I do mean source input. When I played a TrueHD film it switched to this input 'Discrete Cinema', but not until it receives this signal, unlike the other source inputs.
Another question, in the 'Tones' settings there is a loudness control, when would you use this?.
magicj1 is offline
post #1286 of 2151 Old 02-04-2012, 09:40 AM
Joelc's Avatar
Apologies but I do not understand what you are asking...
I can tell you that when I watch a DTS-MA or TrueHD Blu-ray that the surround format jumps all over the place depending on what signal is being received for the advertisements / shorts, etc. but eventually, when the movie starts, it does lock onto the "default / preferred selected" surround mode which in my case is PLIIx as I am running a 7.3 system...
I do not use the TONE controls at all...I have outboard DSP engines that I use to "correct / tweak" the sound...
Joel
Joelc is offline
post #1287 of 2151 Old 02-04-2012, 09:56 AM
magicj1's Avatar
Quoted: 67 Post(s)
I think I am just having a blond moment Joel, sorry. I have just tested with a HD signal being played and I am able to switch between these Modes.
magicj1 is offline
post #1288 of 2151 Old 02-05-2012, 10:42 AM
Joelc's Avatar
No worries...happy you got it sorted...
Joel
Joelc is offline
post #1289 of 2151 Old 02-06-2012, 11:38 AM
michelmia's Avatar
Hi,
I am almost done building my theater. It is a Dennis Erskine project.
As part of my equipment I decided to go with the ADA Cinema Rhapsody Mark IV balanced. This thread was very helpful in helping me make a decision.
Question: No manual or software CD is included in my box. Is this right?
thanks
Chartrand Family Theater Design & Build
http://www.avsforum.com/avs-vb/showthread.php?t=1357481
michelmia is offline
post #1290 of 2151 Old 02-06-2012, 11:43 AM
thebland's Avatar
Quoted: 1499 Post(s)
Liked: 852
Originally Posted by michelmia View Post
Hi,
thanks
Correct.. Nada in the box.
It's back!! Wine of the Week! Clos Martinet Tinto, Priorat DOCa, Spain ~$60. If you've not had a good Priorat, you've not truly tried Spain's smallest, yet most unique terroir.
My Home Theater of the Month- Le Petit Trianon
thebland is offline
