ADA Mach 4......WOW!!!! - Page 54 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
Old 05-01-2012, 06:03 AM
Joelc's Avatar
Originally Posted by thebland View Post
Thanks! We didn't finish it either. Going in later this week to finish. I went into the set up today and all still works!
Jeff, I won't ruin the movie for you but will say that the first half is better than the 2nd half particularly in terms of the soundtrack...
Joel
Some people choose to have a pool, I choose to have a home theater!
Joelc is offline
Old 05-02-2012, 03:47 PM
CCLAY's Avatar
I'm having trouble with the PEQ software connection. I get a Run-time error '13' when try to establish connection. Any ideas? I have UMR coming here tomorrow morning to calibrate the Mach4 and
i sure could use some quick help. TIA
Chris
My Home Theater is a work in progress.
CCLAY is offline
Old 05-02-2012, 05:03 PM
CCLAY's Avatar
I didn't know that the PEQ could accessed from the front panel so I think I'm good to go.
CCLAY is offline
Old 05-02-2012, 10:28 PM
magicj1's Avatar
Quoted: 67 Post(s)
Chris
Are you able to use the HD suite software?
I've had the above message, but only when the ethernet connection was broken.
magicj1 is offline
Old 05-03-2012, 08:15 AM
CCLAY's Avatar
Yes, the HD Suite works fine.
CCLAY is offline
Old 05-03-2012, 08:46 AM
magicj1's Avatar
Quoted: 67 Post(s)
Did the PEQ connection ever work Chris?
I remember the fun I had when trying to get the HD Suite to work on mine which was for a newer software version.
magicj1 is offline
Old 05-03-2012, 10:04 AM
CCLAY's Avatar
Gave up on trying to get it to connect. Jeff Meier is doing the basic levels, tones, etc. right now then he'll finish by using the PEQ on the front panel display.
CCLAY is offline
Old 05-03-2012, 10:18 AM
thebland's Avatar
Quoted: 1496 Post(s)
Liked: 847
Call ADA> Might be simple.
It's back!! Wine of the Week! Clos Martinet Tinto, Priorat DOCa, Spain ~$60. If you've not had a good Priorat, you've not truly tried Spain's smallest, yet most unique terroir.
My Home Theater of the Month- Le Petit Trianon
thebland is online now
Old 05-03-2012, 01:05 PM
AngelEyes's Avatar
I think this is a common problem, I certainly had this loads when I first started out with the ADA. I only wish I could remember how to fix it, I still get this on my Office PC (Win7 Ultimate x64) but not on my HTPC (Win7 Ultimate x86) which works perfectly.
Whether it is the 64bit Win7 that is the issue I couldn't say, it is probably a red herring. HD Suite works fine on both though.
Adam
AngelEyes is offline
Old 05-03-2012, 01:57 PM
Randy Bessinger's Avatar
Quoted: 209 Post(s)
Liked: 163
Are you the one he was doing this with that he posted on Twitter that he was disappointed in the noise in the surrounds?
Randy Bessinger is offline
Old 05-04-2012, 10:55 AM
CCLAY's Avatar
I don't know. I don't think so but can you post a link to that? I gave up on the PEQ from my PC. I think it ended up being easier for him to just do it on the unit itself.
He did the full calibration and was very impressed with the ADA. It sounds phenomenal. I listened to some of my favorite movie tracks and was blown away at how I heard things in a way I've never heard before. For the first time ever it sounded like the music coming from the surrounds was coming from out of the room and not out of the speakers. Way good.
Chris
CCLAY is offline
Old 05-04-2012, 11:09 AM
thebland's Avatar
Liked: 847
Chris
I know the PEQ has no shelf filters. Was that much of an issue in calibrating?
Old 05-04-2012, 11:39 AM
CCLAY's Avatar
I'm not sure but the levels I had set using the ADA's internal noise and my sound meter were way off comared to his Avia disc and his gear. He said rarely does using a units internal noise better a disc and proper calibration equipment.
CCLAY is offline
Old 05-04-2012, 01:15 PM
Quoted: 209 Post(s)
Liked: 163
Chris
https://twitter.com/#!/HomeCinemaGuru
Old 05-05-2012, 01:50 AM
Roger Dressler's Avatar
Quoted: 1523 Post(s)
Liked: 711
Could you post the PEQ settings?
Deadwood Atmos theater [HTOM]
AV7702 Atmos 7.4.4, SSP-800 PLIIx 7.4
Aerial Acoustics 7B/CC3B fronts, B&W CWM8180 surrounds, Tannoy Di6 DC heights, Hsu ULS-15 subs
Roger Dressler is offline
Old 05-05-2012, 12:05 PM
CCLAY's Avatar
Yeah, that would be me. Odd, he didn't say anything to me about 'noise foor'. I don't really know what he is talking about.
CCLAY is offline
CCLAY's Avatar
Will do.
CCLAY is offline
Old 05-05-2012, 09:20 PM
thebland's Avatar
Liked: 847
If you have your PEQ engaged and you put your ear next or your rear speakers do you hear a loutish hiss or noise?. I imagine you might hear it if you have disc not even playing. What ADA firmware version do you have?
I'll check mine tomorrow.
Old 05-06-2012, 12:20 PM
AngelEyes's Avatar
That would be because a) the ADA internal tones are not full range pink noise, b) only an external noise generator/disc will include the PEQ or any other audio processing modes and c) most SPL meters aren't all that accurate especially with the bass and high frequencies.
Adam
Old 05-07-2012, 02:19 PM
CCLAY's Avatar
I think there may be a very soft hiss coming out of the surrounds if I put my ear next to the speaker, but I can't hear it otherwise. I have the older firmware, don't remember the exact.
CCLAY is offline
Old 05-08-2012, 11:16 AM
djnickuk's Avatar
Quoted: 248 Post(s)
Liked: 62
Hi guys.. A couple of q's for your CRM4 owners.
I am just about to upgrade from the 7.1HD to the crm4.
Reason being is I need another sub but have no space. So figured why not use my B&W 802d to their full potential and get the bass from them using the double bass option, for want of its correct terminology.
Also, I can implement a house curve onto the bass domain whereas at the mo I use an audyssey sub eq which only allows flat, no curve to be used.
So, I want to know does the double bass option work on all inputs. Ie, hdmi from my blu ray and analogue from my linn akurate ds. Only reason I ask is I read an old post yesterday where richard s. states the double bass is only available on the analogue 7.1 channel inputs, however these are designed to bypass the dsp so I perhaps miss understood that.
Also, if I want to use true 2 channel bypass or direct as it were and completely miss the dsp, I would need to use the multichannel 7.1 inputs and not the standard 2 channel analogue inputs as they are always subject to dsp?
Many thanks in advance.
djnickuk is online now
Old 05-08-2012, 01:04 PM
Quoted: 1394 Post(s)
Liked: 589
What do you guys with dual subs at different distances do to time align both subs as the Cinema 12 only has 1 subwoofer output?
JimP is offline
Old 05-08-2012, 01:34 PM
thebland's Avatar
Liked: 847
QSC DSP 30. Inexpensive and powerful.
Old 05-10-2012, 12:24 PM
magicj1's Avatar
Quoted: 67 Post(s)
Can anyone please remind me how to set up iRule to control the ADA over IP?
(I can at the moment control it via RS232)
I have managed to get the ISO working on Windows 7 by trouble shooting compatibility, this ends up running this in XP.
What I do not understand is my Iphone is showing A Green gateway
magicj1 is offline
Old 05-11-2012, 06:25 AM
magicj1's Avatar
Quoted: 67 Post(s)
All sorted, it was either my Router or W7 stopping me.
Just glad I didn't throw out my old 'just about hanging in there by a thread' Windows XP laptop last week.
magicj1 is offline
Old 05-11-2012, 03:49 PM
AlexanderEM's Avatar
Mani,
Then you need to have one button in one of the panels where you can assign that command to
I think here's my problem - I have no button. I did create an ADA feedback device and an empty command in it but I didn't assign the command to a button
Now I'm gonna add a button, reset all the network settings back to defaults and then try again.
Thanks a lot!
AlexanderEM is offline
Old 05-14-2012, 10:09 AM
CCLAY's Avatar
Here are the results of the calibration UMR(Jeff Meier) did a couple weeks ago.
AccuCal Calibration Report.pdf 364.4775390625k . file
CCLAY is offline
Old 05-15-2012, 04:26 PM
AngelEyes's Avatar
+10dB boost @ 25hz on the sub channel! Either you have a massive amplifier overhead on your subs, or you are asking for some clipping?
Old 05-17-2012, 09:58 AM
CCLAY's Avatar
I have 2 powered SVS 16" subs. They rock. Haven't heard any clipping to date.
CCLAY is offline
Old 05-17-2012, 10:05 AM
Quoted: 209 Post(s)
Liked: 163
Was the +10 at 25 something you requested or something Jeff recommended?
