Meridian 861 V6 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 48 Old 03-22-2010, 01:05 AM - Thread Starter
sepehr's Avatar
Hi guys,
I'm thinking of getting Meridian 861 V6 with the following option:
A) Meridian HD621 HDMI Audio Processor - 6 x HDMI Inputs, MMHR and
Smart-Link Outputs, 1 x HDMI Output
B) 2 X Meridian OA18 Analogue Output card 4x Analogue Outputs, XLR, configurable, with 24-bit, 192kHz DAC
C) Meridian ID26 Digital Input card with 4x Optical Audio Inputs, Toslink 2x Speaker-Link inputs, RJ45
The rest of my equipment (5 Channels AMP, Speakers and Sub) is Burmester with the exception of CD player, which is Mark Levinson 390S and blue-ray player, which is going to be Theta Compli Blu. For scaler I'm going to use Radiance XE. Turntable CLEARAUDIO CONCEPT (I still have some classical LPs)
Before I do that, I have some questions and need some advice from people who are familiar with Meridian processor.
I'm going to get a professional installer to put my system together. If later on I decide to make changes, is Meridian 861 setup very complicated? I understand that I have to use PC but is it very difficult to change the setup or upgrade the firmware?
Is it a good idea to run the Mark Levinson 390S from bypass input?
My other choices for processor are Mark Levinson No 502 or Classer SSP-800.
Finally, as I mentioned in my other post I usually change my system every 6 to 8 years so I need something, which is well built.
Many thanks.
Sepehr
sepehr is offline
post #2 of 48 Old 03-22-2010, 05:00 AM
Brucemck2's Avatar
Quoted: 70 Post(s)
Liked: 36
The Meridian Unplugged Forum may be a better place to get answers.
I owned an 861v4 and recently swapped it out for an 861v6. The programming interface (via a laptop) is pretty simple, and there are plenty of people on the Forum who will help out if you have problems.
The sonics are really terrific.
Brucemck2 is offline
post #3 of 48 Old 03-22-2010, 05:30 AM
Dennis Erskine's Avatar
Quoted: 64 Post(s)
Liked: 111
I agree ... the Meridian Forum. I just installed a V6 ... very nice.
Dennis Erskine CFI, CFII, MEI
Architectural Acoustics
Subject Matter Expert
CEDIA Chairman
www.erskine-group.com
Dennis Erskine is offline
post #4 of 48 Old 03-22-2010, 06:15 AM - Thread Starter
sepehr's Avatar
Thank you guys.
I feel much better now that both of you are happy with the V6.
Do you guys think I will miss something by not having the Meridian speakers?
I will check Meridian Unplugged Forum now and repost my questions there as well.
Thank you again
Sepehr
sepehr is offline
post #5 of 48 Old 03-22-2010, 06:46 AM
Quoted: 64 Post(s)
Liked: 111
The PC interface is pretty easy to use. If it has a fault, it is similar to most sets of documentation ... given a list of choices, sometimes it is not clear why you'd use one over any of the others.
CEDIA Chairman
post #6 of 48 Old 03-22-2010, 08:24 AM
Will Binegar's Avatar
Liked: 29
What do you think of the v6 as compared to the v4?
Will Binegar is offline
post #7 of 48 Old 03-22-2010, 09:30 AM
isb
isb's Avatar
I agree with the comments about the Meridian configuration program being reasonably easy to use. There are one or two 'tricks', and the HitchHikers forum is excellent for support.
When the installer sets you up, make sure they leave you with the configuration file saved on your PC. When you want to change, you can take this as a starting point and save any changes in a new file (so reloading the original one is an option). There is a 'fetch' option, but it doesn't pull back the room correction filters, if I remember correctly.
The configuration and firmware updates are both handled through MConfig, which checks for new software as it relates to your equipment. I don't know if 861v6 differs from prior versions, but RS232 has been the communication method. Some people have USB to RS232 working, but it's finicky initially. I just leave an old laptop in the equipment rack for G68, G98 and RadianceXD updates.
Looking forward to hear some listening comparisons.
Cheers, Ian
isb is offline
post #8 of 48 Old 03-22-2010, 09:40 AM - Thread Starter
sepehr's Avatar
Thanks Ian,
By RS232 you mean serial connection?
Once I get it my comparison (Meridian V6 and Burmester speakers) will be with my old TAG AV 192R and Revel Salon speakers.
I just hope Meridian will not end up like TAG.
Sepehr
sepehr is offline
post #9 of 48 Old 03-22-2010, 09:55 AM
Brucemck2's Avatar
Quoted: 70 Post(s)
Liked: 36
Physically and operationally the unit is nearly identical to the v4. The interfaces, touch and feel, etc., are very similar to the v4.
I have not listened to any multichannel sources, and can't comment on processing of those types of sources. My listening consisted entirely of Redbook CDs played back via the 861s Trifield setting.
The audio quality of the v6 is markedly improved over the v4. You don't even remotely need to A/B to hear it. Three qualities stand out.
First, there is more information coming through. There is one track I listened to where a couple of female singers with some background instrumentation kicks in to augment the primary musicians. In that track you can easily hear that the additions were recorded in a different physical environment and dubbed in; it clearly sounds like two different recording environments. That's barely noticeable on the the v4 and stark on the v6. After an hour or so I had to set a few of my Trifield parameters slightly differently (width down by .1, center channel volume up by .5db) because the imaging was coming across differently with the v6.
Second, there is greater dynamics with less harshness. I am struggling to find the right language. This is most noticeable on pianos, where you hear more of the "clanginess" of that instrument without it being strident or harsh. (This is similar to what I sometimes hear with high efficiency speakers with compression drivers, without the harshness.)
Third, the bass is much stronger. There is more "there there." Upright bass, kettle drums, etc all have more definition and slam. Everything measures exactly the same on my measurement rig (I use Room EQ Wizzard), but it sounds different. In the end I ended up reducing the volume on my subs by 1.5 db.
It reminds me of when I changed from an Audio Research Ref1 to a Ref 3. The Ref1 and Ref3 are sonically of the same family, but, leagues apart in their presentation of music.
All in terrific sonics.
post #10 of 48 Old 03-22-2010, 12:21 PM
Soccerdude's Avatar
Quoted: 36 Post(s)
What's the cost for the V6?.. It's good to have "money" to burn.
Soccerdude is offline
post #11 of 48 Old 03-22-2010, 12:27 PM
Quoted: 64 Post(s)
Liked: 111
"Price talk" is verboten on this thread ... PM and I'll give you the MSRP.
CEDIA Chairman
post #12 of 48 Old 03-23-2010, 05:05 AM
isb
isb's Avatar
I believe that the RS232 cable is also known as a null modem cable and that they shipped with 861v4's. Here's an old thread from when I was looking for one for my G68:
http://www.meridianunplugged.com/ubb...006c025920b137
The port can also be used to control the 861.
Cheers, Ian
isb is offline
post #13 of 48 Old 03-23-2010, 06:39 AM - Thread Starter
sepehr's Avatar
Hi Ian,
Thank you.
Sepehr
sepehr is offline
post #14 of 48 Old 03-23-2010, 07:15 AM
Liked: 29
Congratulations & thanks for sharing your thoughts... makes me want one!
post #15 of 48 Old 03-30-2010, 12:08 AM
gulliBELL's Avatar
Quoted: 86 Post(s)
Surely MSRP is not verboten from mention publicly?
"My interest in home theater is not only that it annoys the wife, but if it was, then that would be enough"
gulliBELL is offline
post #16 of 48 Old 03-30-2010, 05:59 AM
Chris1971's Avatar
Quoted: 12 Post(s)
MSRP is widely published and I had thought only street price was not discussed. A quick search on Google will reveal an MSRP of USD$25k for the Meridian 861 V6. A bargain at half the price, considering in Australia, it is priced closer to AUD$40k!!
Chris1971 is offline
post #17 of 48 Old 03-30-2010, 08:26 AM
sfisher64's Avatar
Can someone please summarize the difference between the v4 and the v6? Also, I know this is a silly point, but I really like bitstreaming Dolby TrueHD and DTS Master Audio to my receiver and having the receiver decode those formats. It's my understanding that Meridian will not do this. Can someone help me get over this?
sfisher64 is offline
post #18 of 48 Old 03-30-2010, 08:28 AM
Kal Rubinson's Avatar
Quoted: 805 Post(s)
Liked: 571
You are correct that the 861 will not do this but, otoh, most decent players will convert these formats to lossless high resolution PCM which the 861 will handle via the HD621. I've gotten over it.
Kal Rubinson
"Music in the Round"
Kal Rubinson is online now
post #19 of 48 Old 03-30-2010, 08:26 PM
Liked: 29
Me too, albeit with a G68!
post #20 of 48 Old 03-31-2010, 04:55 AM
isb
isb's Avatar
sfisher64 - the third post down by VirusKiller at http://www.meridianunplugged.com/ubb...rue#Post114264 provides a short summary. There's also upgrade pricing information in the thread. There are initial impressions in other threads, but all quite preliminary - Brucemck2 captures it nicely, I think.
isb is offline
post #21 of 48 Old 04-04-2010, 03:09 AM
jacovn's Avatar
Quoted: 127 Post(s)
Liked: 24
As far as i understoond it: Meridian's point of view is that if the player decodes the bitstream and optionally include profile 2.0 extra's into the sound stream, PCM is the only way to get this into the pre-amp.
The HD-621 will optimize this PCM stream and feeds it digitally to the pre-amp.
I do not mind the 2 unit approach. It made it possible to feed 6 streams of high quality PCM data into a 10 year old processor (v2 - v3 - v4 upgraded)
Also i got like 50% of current new price back while trading in for upgrade.
jacovn is offline
post #22 of 48 Old 04-21-2010, 11:35 AM
ca1ore's Avatar
My Meridian 861v6 is now fully installed and calibrated. A pretty nice piece and a notable upgrade over the v4. The most notable improvement for me comes in the form of greater detail and transparency. My initial reaction was that the v6 was a little harsh (it sounds quite different from the v4 that was very smooth sounding, perhaps too much so at times), but after some more extended listening, it is really just more detail and resolution.
As the prior post suggested, the v6 operates almost identically to the prior generations. Would have been nice to have a bluray button on the remote.
Certainty and conviction are a sure sign you don't know what you're talking about! The world is not black and white, rather shades of grey!
ca1ore is offline
post #23 of 48 Old 04-21-2010, 11:46 AM
ken6217's Avatar
Quoted: 66 Post(s)
Liked: 26
I have the same opinion with regards to detail and resolution with mine.
Ken
ken6217 is offline
post #24 of 48 Old 04-21-2010, 11:37 PM - Thread Starter
sepehr's Avatar
Thanks for the feedback guys.
Does either of you know how it will sound with turntable
I'm thinking of paring it with Clearaudio Innovation
Also, is it better to connect the turntable through XLR or RCA I will use Symphono + it has both
Sepehr
sepehr is offline
post #25 of 48 Old 04-22-2010, 03:13 PM
Quoted: 64 Post(s)
Liked: 111
yes, yes
CEDIA Chairman
post #26 of 48 Old 04-23-2010, 12:22 PM
ca1ore's Avatar
Sepehr
Remember, the 861 redigitizes analog inputs. Would imaging LPs would sound great though.
Also, too lazy to google 'symphono +', but the 861 only has RCA analog inputs (no XLR).
ca1ore is offline
post #27 of 48 Old 04-24-2010, 01:06 AM - Thread Starter
sepehr's Avatar
But I think 861 has one XLR input.
Spehr
sepehr is offline
post #28 of 48 Old 04-24-2010, 03:42 AM
Quoted: 64 Post(s)
Liked: 111
Six analog stereo inputs are standard.
CEDIA Chairman
post #29 of 48 Old 04-25-2010, 02:55 AM - Thread Starter
sepehr's Avatar
Yes, but it has only one XLR input
Sepehr
sepehr is offline
post #30 of 48 Old 04-25-2010, 07:28 AM
ca1ore's Avatar
Sepehr
The 861v6 does not have any XLR inputs. There was/is a board for v4 with XLR input (IA10B), but it does not work in the v6. As far as I know, the only optional board available for the v6 that does not come with the trade-in models is a Sooloos card (plus RCA outout cards in place of the XLR ones). Perhaps this will change over time, but for now no XLR input.
ca1ore is offline
