How well do "you" see color. - Page 6 - AVS Forum | Home Theater Discussions And Reviews
post #151 of 218 Old 05-10-2011, 12:46 PM
goatwuss's Avatar
That was easy....
Your score: 0
Gender: Male
Age range: 20-29
Best score for your gender and age range: 0
Highest score for your gender and age range: 1520
goatwuss is offline
post #152 of 218 Old 05-12-2011, 09:25 AM
aidoroboo's Avatar
Score: 0
Sex: male
aidoroboo is offline
post #153 of 218 Old 06-08-2011, 10:59 PM
laststop311's Avatar
Of course scored a 0. Blue green was probably the most difficult section. Im legally blind in 1 eye but i still got a perfect score on the first try.
Online ColorIQ Challenge Results
You have perfect color vision!
FM Hue Test Results
A lower score is better, with ZERO being the perfect score. The bars above show the regions of the color spectrum where hue discrimination is low.
Probably helps having the 30" dell IPS lcd screen which is used in color critical applications
Based on your information, below is how your score compares to those of others with similar demographic information.
Your score: 0
Gender: Male
Age range: 20-29
laststop311 is offline
post #154 of 218 Old 07-13-2011, 12:28 AM
sebberry's Avatar
Quoted: 27 Post(s)
Liked: 30
Your score: 0
Gender: Male
Age range: 20-29
Of course that was only after I got half way through it and realized I needed to use compatibility mode in IE to make the boxes line up properly
sebberry is offline
post #155 of 218 Old 07-24-2011, 01:29 AM
rsmash's Avatar
0 @ 30.
I'm sure my old EyeOne LT would have failed miserably.
rsmash is offline
post #156 of 218 Old 09-05-2011, 06:19 PM
trinidex's Avatar
Score: 3
Interesting test - impressed myself
trinidex is offline
post #157 of 218 Old 09-06-2011, 06:52 PM
Kriilin's Avatar
Quoted: 48 Post(s)
27 with a 5 yr old cheap Hanns-G LCD monitor. I used to do color matching for a living, so I think that helped.
I see dead pixels.......
Kriilin is offline
post #158 of 218 Old 09-09-2011, 01:14 PM
UGAd13's Avatar
Quoted: 100 Post(s)
Liked: 121
12 but rushed through it...
30 yr old
My living room budget build: Samsung PN51E530 / Denon AVR1613 / DefTech PC1000 / DefTech PM60 / DefTech ProSub 60 / Dayton Sub1200
UGAd13 is offline
post #159 of 218 Old 09-13-2011, 10:04 AM
Infoe's Avatar
Your score: 4
Gender: Male
Age range: 30-39
0 ( Perfect Color Acuity )99 ( Low Color Acuity )
Infoe is offline
post #160 of 218 Old 11-13-2011, 08:55 PM
blekk's Avatar
Your score: 4
Gender: Male
Age range: 20-29
PSN: blekk
blekk is offline
post #161 of 218 Old 11-16-2011, 08:08 AM
Gellidius's Avatar
Your score: 3
Gender: Male
Age range: over 70
Gellidius is offline
post #162 of 218 Old 12-10-2011, 06:52 PM
coolhandlukee's Avatar
0@21
coolhandlukee is offline
post #163 of 218 Old 12-11-2011, 07:28 AM
CruelInventions's Avatar
Quoted: 607 Post(s)
Liked: 746
Finished the top row, grew impatient, grabbed my results.
I'm just gonna go ahead and claim eventual zeros across the board.
CruelInventions is offline
post #164 of 218 Old 12-20-2011, 10:52 AM
ebolasmurf's Avatar
Your score: 0
Gender: Male
Age range: 30-39
Yeej
ebolasmurf is offline
post #165 of 218 Old 12-21-2011, 07:55 AM
bluesjunior's Avatar
I am 62 and chuffed that I got the following result, although I failed miserably on the hearing test one.
Your score: 0
Gender: Male
Age range: 60-69
bluesjunior is offline
post #166 of 218 Old 12-21-2011, 08:21 AM
Shunopoli's Avatar
Your score: 0
Gender: Male
Age range: 30-39
Shunopoli is offline
post #167 of 218 Old 12-21-2011, 12:36 PM
Rubicon_Joey's Avatar
Scored a 15, but I grew tired of messing with it rather quick and didn't put too much effort into it. Done this on my 16" LCD/LED back-lit laptop...Forgot to copy the score page, but I'm a 24yo male....
Rubicon_Joey is offline
post #168 of 218 Old 01-03-2012, 06:12 PM
tonsofpcs's Avatar
This was on my EeePC 900A and I saw some out-of-order on the last row (and some I wasn't sure of on an earlier row) but I didn't want to bother tweaking any more. Grouping of 3 in the 'darker' greens (that's how they show on this display), 8 mid-blues/indigos (some stacked).
tonsofpcs is offline
post #169 of 218 Old 01-12-2012, 05:17 AM
Bigus's Avatar
Quoted: 397 Post(s)
Liked: 384
Scored 0, took about two minutes, was able to line them up nearly perfect with only a few swaps in each row before moving on.
This on a $10k 5MP medical imaging display in a dark room, so it "should" have been easy.
Bigus is offline
post #170 of 218 Old 01-13-2012, 08:57 PM
Ageclipsegt's Avatar
Wow, I am terrible at this.
Your score: 79
Gender: Male
Age range: 20-29
Looks like a 17-18 LCD monitor here at work, Dell brand, Windows XP, bright lighting in the office. I know my eyesight isn't the best, but 79 seems quite poor.
Ageclipsegt is offline
post #171 of 218 Old 02-09-2012, 11:08 AM
EvanC's Avatar
I have perfect color vision
27 year old male
oh and the monitor I'm on is a regular dell 17 inch. I'm pretty sure the monitor has to be really bad to impact this test though.
EvanC is offline
post #172 of 218 Old 02-15-2012, 02:24 PM
wyen78's Avatar
39....took probably 1-2 minutes. 33 yrs old. Took it on uncalibrated Dell monitor at work.
In a way, I'm kind of happy that my color discrimination sucks. I can buy cheaper stuff and have it look okay to me.
wyen78 is offline
post #173 of 218 Old 02-15-2012, 11:15 PM
Mr.D's Avatar
Your eyes are still significantly more precise than even a high end display let alone a consumer level one. Don't worry you'll still reap the benefits of a better display
digital film janitor
Mr.D is offline
post #174 of 218 Old 03-04-2012, 01:37 AM
pkarmouche's Avatar
I did it rather quickly and scored 41. Then I read all of the responses and just had to go take it again.
The second time I turned up my Macbook Air's brightness, and when I "thought" I was done I tilted the monitor up and down a bit, which revealed some areas that could use "touching up". It took about 10 minutes but I acheived a score of 8.
Paul
pkarmouche is offline
post #175 of 218 Old 03-20-2012, 07:51 AM
Mike Garrett's Avatar
Quoted: 6602 Post(s)
Liked: 4289
Did not spend a lot of time on it.
Your score: 8
Gender: Male
Age range: 50-59
mjgarrett100@gmail.com
Mike Garrett is online now
post #176 of 218 Old 04-01-2012, 06:37 AM
Andy Lammer's Avatar
Score: 0
And I have always professed that I don't give a crap about accurate colours on my PJ, only that they look OK-enough.
- Andy
Andy Lammer is offline
post #177 of 218 Old 04-16-2012, 07:47 PM
HandsomeHubby's Avatar
This test is kinda crap, as many monitors display colors very differently...
I feel this must be much harder on a good monitor.
(Score of 15 after 3 minutes, but the pinks didn't make any sense! they should not have been on a line! I'm a professional colorist damn it!)
HandsomeHubby is offline
post #178 of 218 Old 04-17-2012, 03:24 PM
newirishman's Avatar
Liked: 31
Right. About 10 minutes to click through it, on a 13" macbook pro
But the missus always tells me that I am colorblind...
Your score: 0
Gender: Male
Age range: 39
newirishman is offline
post #179 of 218 Old 04-17-2012, 04:35 PM
Seegs108's Avatar
Quoted: 4961 Post(s)
Liked: 2478
Your Score: 0
Good to know I'm not color blind. The test only took a few minutes. If it matters I did the test on an uncalibrated Dell 3007WFP.
Seegs108 is offline
post #180 of 218 Old 04-18-2012, 03:04 PM
swarm87's Avatar
Quoted: 133 Post(s)
Liked: 99
i scored 171 but my eye doctor already told me i had trouble with red and green so whatever
pcm=potato
bitstream=patato
swarm87 is offline
