Any one see the Lexicon MC-12HD replacement at CES? - Page 28 - AVS Forum | Home Theater Discussions And Reviews
Old 05-10-2012, 11:54 AM
filecat13's Avatar
Quoted: 34 Post(s)
Liked: 101
Originally Posted by dsmith901 View Post
Now, if I may be so bold, can we get back to discussing what Lexicon has in mind as a replacement for the MC-12HD now that the MC-20 is dead? Come on all you insiders, don't be shy. Inquiring minds want to know!
Referring back to your JBL AV1 comment (I have an SDP-5, essentially the same product), Harman's last "new' Lexicon was the MV-5 (JBL AV2, of which I have two) which introduced HDMI, 7.1 analog inputs, USB, and, okay, The Bridge.
I really wanted 7.1 analog in, which the SDP-5 didn't have, and neither did the SDP-40. That alone was enough for me to move from the SDP-5 to the AV2.
Since the HDMI was stuck at 1.1 in the AV2 and limited to 1080i output, that wasn't too compelling for video. I prefer HDMI straight to the PJ anyhow.
The fact that it accepted HDMI audio in but could not decode HD audio was kind of defeating, too, though obviously any decent Bluray player could do that.
The USB is potentially cool, unless you're a Mac owner. So, hey, no cigar there either.
I like sticking my iPod in The Bridge and controlling it from afar, but the UI is weak, and as I recall you can't get the digital stream from it, only the analog one.
There's also a mic and unnamed auto set up, but I took a different calibration route.
I do like the way the unit "sounds."
All of that is to say, since the MC-20 is dead, what are the odds that a retreat to MV-5/AV2 territory could yield a path forward for Lexicon. I know the units were derided for being Chinese and HK AVRs without amps, but I find the unit pretty satisfying, given its several shortcomings. Eliminate the unneeded video stuff, beef up the audio section, fix the freaking USB and iPod stuff, offer a balanced model, figure out if the customers that will actually buy it want auto-EQ or will want a calibrator anyway, put a nice billet face on it...
This is why I'm a consumer and not a designer or an engineer.
What I can afford, when I can afford it...
filecat13 is offline
Old 05-12-2012, 01:17 PM
Bulldogger's Avatar
Quoted: 204 Post(s)
Liked: 46
No news? Things are awefully quite??
Never become so involved with something that it blinds you.
Bulldogger is offline
Old 05-12-2012, 10:37 PM
filecat13's Avatar
Quoted: 34 Post(s)
Liked: 101
Maybe my stupid comment killed the thread, though in the end it's no stupider than speculating about what Lexicon might do since we don't have a frickin' clue.
We do have our dreams, however...
Old 05-13-2012, 06:36 AM
sfogg's Avatar
"I really wanted 7.1 analog in, which the SDP-5 didn't have, and neither did the SDP-40. That alone was enough for me to move from the SDP-5 to the AV2."
I can fix that.
Shawn
sfogg is offline
Old 05-13-2012, 04:13 PM
Peter Nielsen's Avatar
I can fix that.
Shawn, that's very interesting! Sounds like you have an 8ch input mod for the SDP-40 (MC-12)?
Peter Nielsen is offline
Old 05-13-2012, 05:56 PM
sfogg's Avatar
Peter,
Yes, on the MC-12 it is for when analog bypass is on. When you are applying processing to the multichannel input that remains a 6 channel input.
Shawn
sfogg is offline
Old 05-25-2012, 02:50 PM
dsmith901's Avatar
I mean no offense, but it is generally known among Lexicon owners that the only true Lexicon designed pre/pro with HDMI switching is the MC-12HD or it's JBL Synthesis equivalent, the SDP-40HD. The MV-5 and AV2 are asian sourced models built for Lexicon that use preamp sections based on Harman Kardon receivers, which are good but that definitely are not Lexicon level quality. If you enjoy these models then all is good and no apologies are needed, but just be aware that they are not considered full-fledged Lexicon products.
"The truth is out there!"
dsmith901 is offline
Old 05-25-2012, 10:46 PM
filecat13's Avatar
Quoted: 34 Post(s)
Liked: 101
Hence my comment "derided for being Chinese and HK AVRs without amps."
No offense taken.
Old 05-31-2012, 07:10 PM
G-Rex's Avatar
Quoted: 436 Post(s)
Liked: 268
Well, I was once again getting the itch to replace my Lexicon MC12B. I have been hearing dealers say Lexicon's processor days are over. It was a bit unsettling. So I figured I would call a contact at Harmon to get some info. New info would be the only way I would continue to hold out. I got some info that is a bit encouraging (if accurate). The good news is the new processor is being vigorously worked on. As we know, no video processing, but otherwise similar to the now defunct MP20. He said it will likely be shown at Cedia 2012 in Sept, with a projected release date of late 4th quarter 2012 or 1st quarter 2013. I was also starting to think the MC12 was Lexicon's last processor, but now it does't look that way. Anyone with new info please post as it makes the wait more tolerable.
G-Rex is offline
Old 05-31-2012, 07:51 PM
audioguy's Avatar
Quoted: 1916 Post(s)
Liked: 1240
If it has the audio processing that was demoed at last years CEDIA, it will be worth the wait and a huge home run. If it does not, then it has a chance of just being yet another good SSP -- and that would be a huge disappointment.
audioguy is offline
Old 05-31-2012, 07:59 PM
sdurani's Avatar
Quoted: 4479 Post(s)
Liked: 2901
I've always thought it was a matter of when, not if (as the dealers you've spoken to would suggest). Harman has invested lots of time, effort and money into developing new surround processing and room correction (both of which were demonstrated at CEDIA last year). After expending all those resources, I doubt they would simply give up and toss all that research on the shelf indefinitely. They're a business, first and foremost. So, even if just for business reasons, it is a matter of time before those technolgies are available to consumers for purchase in the form of pre-pros and receivers; if for no other reason then to recoup the cost of that research.
Sanjay
sdurani is offline
Old 06-01-2012, 01:42 AM
Bulldogger's Avatar
Quoted: 204 Post(s)
Liked: 46
I have another source that confirms G-Rex. Very credible source.
Old 06-01-2012, 02:46 AM
Sakuma's Avatar
So you guys have heard the next Lexicon, Do you think it is well worth the wait?
Sakuma is offline
Old 06-01-2012, 03:22 AM
Bulldogger's Avatar
Quoted: 204 Post(s)
Liked: 46
It's still 6-9 months from delivery.
Old 06-01-2012, 08:06 AM
dsmith901's Avatar
I for one can easily live without video processing, which never made a lot of sense to me in an audio processor. Switching is okay, but I don't even need that. Hopefully the new model will knock a few thousand off the MSRP mentioned for the MP-20, which would certainly improve it's marketability. I will start saving my pennies now.
Old 06-01-2012, 08:32 AM
Bulldogger's Avatar
Quoted: 204 Post(s)
Liked: 46
I have no idea about a price reduction. My first of three different sources is a dealer. He made the point that removing video actually increased R&D cost.
Old 06-01-2012, 08:43 AM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 1059 Post(s)
Liked: 987
That doesn't make much (if any) sense to me. I suppose there was some redesign needed to remove video capability from the MP-20 platform, but that doesn't sound like a cost that should be passed along to the consumer but rather something that should be handled as an internal loss. You can't reasonably remove functionality from something and keep the cost the same...
gsr is online now
Old 06-01-2012, 09:26 AM
sdurani's Avatar
Liked: 2901
No one has. The room correction and surround processing demonstrated at CEDIA was not in a completed unit or prototype.
Depends on whether you are interested in the proprietary technologies in the Lexicon pre-pro. If you're satisfied with licensed surround processing (Dolby PLIIz, DTS Neo:X) and licensed room correction (Audyssey, Trinnov, Dirac), then no need to wait since good solutions are available right now. However, if you're interested in something unique, with capabilities not available in current surround processing and room correction, then it would be worth the wait to hear the proprietary technolgies from Lexicon before deciding.
Sanjay
sdurani is offline
Old 06-01-2012, 11:38 AM
It does make sense. Removing the functionality may result in a projection of fewer units sold. In effect, the projected per-unit development cost goes up.
Who pays for "internal losses" ? The internal loss fairy?
Old 06-01-2012, 06:37 PM
gsr
Oppo Beta Group
gsr's Avatar
Liked: 987
Internal losses equate to lower profits at the end of the year (which translates to things like lower raises and smaller bonuses for the employees). But when you F-up on a product release, you can't just "double" (yes, I'm obviously exaggerating) the price of the product to make up for it. And yes, things like lower volume can move the price up.
But if you're designing 2 otherwise identical products from the ground up - one with video processing and one without video processing, it should (obviously, I think ) cost less to design the one without video processing.
gsr is online now
Old 06-01-2012, 11:21 PM
filecat13's Avatar
Quoted: 34 Post(s)
Liked: 101
Plus, if you've jeopardized your reputation with your customer base by missing an important, announced product, you don't increase the risk to that loyalty by essentially telling your customer base:
1. We can't deliver what we promised.
2. We can do something else and it will be better than our current product, but it will take longer and do less than what we originally promised.
3. You will have to be patient with us and wait until we finish, and we can't say for certain when that will be.
4. We will charge you more for being loyal, waiting, and overlooking our failure.
Old 06-02-2012, 12:51 PM
jonathan56's Avatar
Quoted: 31 Post(s)
how much better performance will the new MC 12 HD over my current up to date model?
jonathan56 is offline
Old 06-02-2012, 01:06 PM
G-Rex's Avatar
Quoted: 436 Post(s)
Liked: 268
Will likely have improved sound quality plus a very advanced QLS sound field processing. This creates a 5 channel sound field above your 5.1 or 7.1 system. To use QLS you will need 5 more smallish speakers with 5 channels of additional amplification. It will have a more advanced room correction...hopefully arcos.
G-Rex is offline
Old 06-02-2012, 01:33 PM
jonathan56's Avatar
Quoted: 31 Post(s)
I have Aerial 20T Version 2, matching center, sides and rears in-wall B&W's, 2 velodyne subs (15 and 18), three mark levinson 436's monoblocks for LRC, and two Proceed HPA 2 for sides, and rears. 3 chip runco DLP projector with cinewide lens and curved auto masked stewart screen. Also, QSC unit sound procedding attached to my lexicon MC-12 HD. My room is state of the art, tuned with sound panels all around, absorptive in front, front third, and diffusion sides and rear, combination on ceiling.
Ill still need more smallish speakers and more amplification for that application?
Jon
Old 06-02-2012, 02:09 PM
G-Rex's Avatar
Quoted: 436 Post(s)
Liked: 268
"Need" no...but if you have QLS in a future Lexicon processor you may want it. If your theater room is large (which mine is) then QLS is very tempting.
G-Rex is offline
Old 06-02-2012, 02:28 PM
jonathan56's Avatar
Quoted: 31 Post(s)
I'm sorry if my questions are a bit novice , but what is QLC? Also, you mean, I will add more speakers to my LRC, rears and sides? How does that work?
thanks,
Jon
Old 06-02-2012, 03:46 PM
G-Rex's Avatar
Quoted: 436 Post(s)
Liked: 268
Yes, 5 new height speakers. The MP20 is now vaporware, but this link discusses QLS.
http://www.audioimages-hifi.com/page...4170698-8.html
G-Rex is offline
Old 06-02-2012, 09:30 PM
sdurani's Avatar
Liked: 2901
Just confirmed this today at T.H.E. Show in Newport Beach. For those not doing the math, nine months takes us past CES 2013.
Sanjay
sdurani is offline
Old 06-02-2012, 09:50 PM
filecat13's Avatar
Quoted: 34 Post(s)
Liked: 101
Yes, and six months takes us to before Xmas. (I still had to use two hands to do the math.)
We should set up a pool on the actual delivery date.
Old 06-02-2012, 10:53 PM
HomeTheaterGuy74's Avatar
Let's hope that Harman doesn't run Lexicon into the ground now like they did Infinity...
What a loss...
They also discontinued the Mark Levinson Nº502 with nothing new in its place...
HomeTheaterGuy74 is offline
