The official Theta Owners Thread - Page 240 - AVS Forum | Home Theater Discussions And Reviews
 345Likes
post #7171 of 11436 Old 07-06-2014, 07:29 AM
Bulldogger's Avatar
Quoted: 205 Post(s)
Liked: 49
Originally Posted by Kal Rubinson View Post
If you really want a laugh, take a look at what Krell is providing as the mic for its calibration system.
I am not sure he would laugh at the quality of the mic. Is this a new development for use with the new Krell products or has this been the case even with the 707?
Never become so involved with something that it blinds you.
Bulldogger is offline
post #7172 of 11436 Old 07-06-2014, 08:00 AM
Bulldogger's Avatar
Quoted: 205 Post(s)
Liked: 49
Originally Posted by edorr View Post
When in doubt, I always err on the side of spending more money. Now that the seeds of doubt have been planted in my brain, I have no option but to buy the expensive mic for peace of mind. I'm also cheap and in no hurry (I already have a good mic), so I'll probably wait until one show up for cheap and scoop it up, compare calibrations with the two mics, and resell the earthworks with a profit if I can't hear a difference between calibrations.
This is the most logical path.Earthworks preowned stuff seems to have increased in price in the last year or so. You have to do a RMA type of form to get the calibration file if the mic was not supplied with one,usually the case for mic made before 2012. If memory serves the cost is $50, so try to buy one already with a calibration file.
Earthworks mic are not manufactured in China and individual measurements are done. "Each microphone’s capsule is hand tested and matched to its circuitry to provide the most accurate responses." I think is sort of a myth that the state of electronics is such that they match the published specs with no variance. If you have ever calibrated a projector, for example of the same brand and model, or have seen the results of others, you will notice that even brand new, the setting from one will not directly transfer to the other because of this variance. I would not expect better from cheap mics. Cost is a factor because more time is spent measuring each individual mic so you are paying more for that.
I spoke with Earthworks a few years back and my recollection of the conversation is that there is not much difference between the electronics of the M50 and M30. I believe the capsule is changed to allow higher frequency measurements.What I really wanted to know was whether there was an advantage to the M50, such as it being more linear but that is not the case. I also believe that Dirac does not generate filers above 20Khz so you may consider the M23 as well? The M30 seems to be the sweet spot however for used sales and I was able to purchase one cheaper than I could find the M23 used.
Use your ears to see if it matters. What is without doubt is that Earthworks provides more rigorous testing of each individual mic.
Perhaps, it's just my background in experimentation, but I consider it simplistic that some only consider the microphones and do not consider that the USB preamp used, either built in or external could be a factor. Because the Earthworks mics require an external preamp, you would likely never be just comparing just mic to mic but also the quality of the USB preamplifier, perhaps Sound Devices USBPRE 2 and the analog to digital conversion vs the "built in" electronics of some mics.
post #7173 of 11436 Old 07-06-2014, 09:07 AM
Kal Rubinson's Avatar
Quoted: 706 Post(s)
Liked: 482
Not with the 707 but with the Foundation: "The microphone's packaging identifies it as a MIC48 Multimedia Microphone, which can be found on the Internet for as little as $3.98—or, in bulk quantities from alibaba.com, for between 55¢ and 80¢!"
Kal Rubinson
"Music in the Round"
Kal Rubinson is online now
post #7174 of 11436 Old 07-06-2014, 09:24 AM
Bulldogger's Avatar
Quoted: 205 Post(s)
Liked: 49
Originally Posted by kal rubinson View Post
not with the 707 but with the foundation: "the microphone's packaging identifies it as a mic48 multimedia microphone, which can be found on the internet for as little as $3.98—or, in bulk quantities from alibaba.com, for between 55¢ and 80¢!"
Wow!
post #7175 of 11436 Old 07-06-2014, 12:04 PM
rhale64L7's Avatar
Quoted: 844 Post(s)
Liked: 335
Wow!
Yes wow is an understatement. What would it take for Krell to change that thing? It is obviously screwing up ares results. I made mine much beefier by wrapping black tape around the whole darn thing to prevent ringing in the housing. This seemed to work pretty well. But you shouldn't have to do that with a 6500.00 processor.
And sorry for the hijack. Carry on folks.
JVC RS4810 projector Stewart Cima 115" 2.35 screen, ATI 523 and 528 amps
7 mirror imaged 2 way DIY monitors. All matched to within 1db. All parts matched, 1 SVS SB16 ultra subwoofer
Emotiva XMC-1 processor Marantz UD5007 Bluray player
Furman sequencer ran off of a double 50amp breaker,Furman power conditioner
All in a dedicated 15x22x8 foot dedicated home theater.
rhale64L7 is offline
post #7176 of 11436 Old 07-06-2014, 01:04 PM
Glimmie's Avatar
Quoted: 756 Post(s)
Liked: 624
What many need to be doing is investing in room treatments first and then investing in microphones.If you ask Dirac, the response will be swift and that will be that room correction does not negate the need for room treatments.10k in cables and not a single room treatment in sight in typical.
I couldn't agree more. When I went from a family room HT in a great room floor plan with an open kitchen to a dedicated HT room with proper sound treatment, the difference really was "huge". The improvement was amazing.
And if you look at my EQ graphs there is not much being applied above 100hz. As with most rooms my problems are in the deep bass and even those are well within correction range.
Let me throw this out to the group: If your room is acoustically controlled and tuned requiring only minimal EQ tweaking, do you even need Dirac style room correction?
I am waiting for the multi channel MiniDSP product. But I am questioning if I really do need it?
Glimmie is offline
post #7177 of 11436 Old 07-06-2014, 01:32 PM
Glimmie's Avatar
Quoted: 756 Post(s)
Liked: 624
What measurements in typical modern audio electronic do you think result in differences in perceived sound quality? Are not most measurements supposedly well below the threshold of human perception?
Yes they are. I just don't see how there can be any perceived sound quality differences between a SPDIF and balanced AES connection, provided of course both are within proper operating parameters.
Choosing between 75ohm coaxial and 110ohm balanced AES is a well practiced decision in broadcast and professional AV systems engineering. The current trend is towards 75ohm BNC. The primary factor is of course cost. 75ohm coax is cheaper per installed foot than low capacitance data cable. That includes the 4:1 cost difference between XLR and BNC connectors not to mention assembly time. An XLR takes 5x longer to install and costs 4x as much as a BNC connector.
In the technical performance side, coax again is superior. It can run 48K AES well over a thousand feet. Twisted pair is limited to a few hundred feet. The reason is that AES does require a true transmission line due to the frequencies involved. It's much more difficult to maintain that on long distances with twisted pair. Twisted pair only has the advantage of noise rejection over unbalanced coax. And with digital signal transmission, unlike analog audio, that is rarely a problem. The signal is immune to hum and noise until it is more than 50% of the signal amplitude. That's the Godsend of digital signal transmission.
And then you need to look at your equipment. If the bulk of it uses XLR, then it makes sense to install a balanced system. If the bulk is BNC, than a 75ohm system makes more sense. A $50 transformer easily converts between the two formats with no loss of audio fidelity whatsoever.
There have been thousands of pages of text written on this subject in AES, SMPTE, SBE. But never did I ever read about a difference in perceived audio quality between the two interfaces. And consider these are large quantities and long lengths of cable installations. Surly such phenomenon would be much more severe in these installations versus a simple home interconnect from a CD transport to a DAC.
The only place I ever read about a perceived difference in sound quality between 75ohm SPDIF and 110ohm AES was right here at AVS forum.
So we are rather weak on the credibility side with this one.
Glimmie is offline
post #7178 of 11436 Old 07-06-2014, 02:36 PM
stevekale's Avatar
Quoted: 370 Post(s)
Liked: 45
Yes. There's only so far you can go before you've got to resort to liberal cake icing. The problem is that many think it is a panacea for bad baking. As I have said many times here before, go as far as practical with acoustic treatment and then resort to filters. As far as practical will be different for different folk. Filtering can't do anything to help combing or poor decay, for example.
The biggest change I recently implemented in my system? Shifting my Rel Stentor II to fit right up against my listening couch. (Tucked in behind.) when I watched Lone Survivor there was one part when I nearly leaped off the couch!
Demand greater honesty and transparency in high-end audio
With Theta, Egglestonworks and Krell since 1998!
stevekale is offline
post #7179 of 11436 Old 07-06-2014, 02:42 PM
stevekale's Avatar
Quoted: 370 Post(s)
Liked: 45
AES EBU in consumer gear is one of those cases that Morris alluded to in articles discussed here earlier. It is sold as being better (without context) and soon enough people simply demand it without even understanding the differences between the two.
Perhaps like a linear psu in a class D amp....? Dunno. Still exploring that one. It would be interesting to blind test the Prometheus against the Mola Mola.
post #7180 of 11436 Old 07-07-2014, 06:36 AM
dancjodanc's Avatar
Quoted: 130 Post(s)
Does anyone know if the Toslink imput on the Casa IV goes as high as 24/192?
I know most Toslink is limited to 24/96, but looking at a music player that claims
it's Toslink can outupt 24/192, and wanted to make sure the Casa's imput toslink did the same?
dancjodanc is offline
post #7181 of 11436 Old 07-07-2014, 06:39 AM
stevekale's Avatar
Quoted: 370 Post(s)
Liked: 45
Email John at Theta. I'm sure he will be back to you in the flashest of flashes...
post #7182 of 11436 Old 07-07-2014, 08:24 AM
Steve Bruzonsky's Avatar
Quoted: 453 Post(s)
Liked: 110
My understanding is that toslink is technically/objectively limited to 24-96. No doubt Glimmie can tell us for sure.
You mean you don't remember me? Back 1999 - 2003, I started and moderated the AVS Tweaks forum and also the AVS Special Guests forum.
My home theater at:
http://www.avsforum.com/avs-vb/showthread.php?t=1158431
Steve Bruzonsky is offline
post #7183 of 11436 Old 07-07-2014, 08:29 AM
stevekale's Avatar
Quoted: 370 Post(s)
Liked: 45
Toslink can be made to handle up to 125Mbps.
post #7184 of 11436 Old 07-07-2014, 11:17 AM
Glimmie's Avatar
Quoted: 756 Post(s)
Liked: 624
I don't know but if it is in fact 125mbs, that should easily carry 196k which requires roughly 12mbs. But lets also distinguish the difference between TosLink and copper based SPDIF. Copper based SPDIF (RCA connector on consumer gear) can carry anything balanced AES can. In fact coaxial SPDIF is mostly compatable with 75ohm AES3 which uses a BNC connector. There are some very rare implementations that get confused by the mishandling of the obsolete copy protection bit which is different with consumer SPDIF. AES3 has none but uses that data area for channel mapping info. Most consumer gear just ignores that.
And TosLink does impart more jitter than copper. It does provide electrical isolation which may help break ground loops in other areas of your system. but as i siad above, ground hum on digital audio signals is rarely a problem.
I try to avoid TosLink where ever possible as my system is all copper SPDIF and AES based anyway. To that end I have gone in and modified my Dish* box for SPDIF with a BNC output. I prefer that to those mechanically flaky optical to electrical conversion boxes.
*No it's not leased. I always buy my satellite boxes.
Glimmie is offline
post #7185 of 11436 Old 07-07-2014, 11:32 AM
Glimmie's Avatar
Quoted: 756 Post(s)
Liked: 624
Yeah, I can see that. Balanced AES is "professional" and therefore must be better! Yet as I said above, most of the industry is going to 75ohm BNC systems. But hey, then the high end consumer manufactures can switch to a BNC connector just like the pros use!
Once you start to look at actual schematic implementations of AES transmitter and receiver circuits, it's easy to see there is virtually no difference. A lot of broadcast interfacing gear is made as a plug in card with a plugin backplane. This way you buy either a BNC or balanced backplane depending on what you need. The only difference is whether the input transformer is terminated with 110 or 75ohms. The processing card is the same for either version.
I can almost gaurentee any gear with both an RCA SPDIF and XLR AES input options uses nothing more than a mechanical switch or relay to select the desired jack. That's all it takes. There are no magic circuits in the path making one jack better than the other. The only change is in the grounding and termination resistor - easily done with a switch or relay.
Glimmie is offline
post #7186 of 11436 Old 07-08-2014, 12:37 AM
stevekale's Avatar
Quoted: 370 Post(s)
Liked: 45
Or even more basic. Take the Bryston BDP player. The Juli@ card they use has SPDIF output on it which normally goes to a breakout cable which is RCA terminated. Bryston merely interrupt the signal at the Hanrun transformer (as anyone can) and add a simple impedance conversion to i.e 110 Ohms and a balanced AES EBU connector. I'm not even sure they bump up the voltage levels of the pulses although it is easy enough to do. Job done. No increase in quality but "gives it that real professional look, ya' know what I mean gov'."
post #7187 of 11436 Old 07-08-2014, 11:58 AM
stevekale's Avatar
Quoted: 370 Post(s)
Liked: 45
Anyone else having problems with this forum? I get notifications of some posts that I can't see and often no notifications for new posts. Seems very screwed up.
post #7188 of 11436 Old 07-10-2014, 07:44 PM
phunge's Avatar
finally got my CBIV
Well, after getting tired of waiting for the supernova I contacted Craig and ordered the Casablanca. Craig was great to work with, and after sorting out some software issues (my Casablanca has two superior II DACs and they had some issues apparently getting things working with only 6 channels installed) my unit finally arrived last week.
I did an initial calibration, including DIRAC measurements, and so far I am very impressed. Fantastic unit. I am also impressed with how easy and flexible the software is. I was easily able to setup two inputs, one with DIRAC and one without so I can easily toggle back forth to compare.
One issue I am having is that it will not drive my projector at 1080p with my bluejeans 45 foot HDMI. My blu ray will drive it (but only at 24fps, not 60) but the Casablanca HDMI will only work at 720p max. Looking into some active HDMI solutions recommended by Craig.
Also, for some reason the AIX DTS Master Audio test will not play. It recognizes DTS and switches the mode to DTS Master Audio, but no sound. Not too worried as movies with DTS Master Audio tracks play fine.
I did run into some issues with the DIRAC software not detecting the Theta, and also crashing, as others have reported. It needs some QA, as it appears to be a bit flakey, but I was able to eventually get through it.. Learned to hard reset the theta to enable the software to connect, and save often to avoid having to redo measurements after software crashes. Others have reported it, and I'm hopeful for an eventual fix, though once the calibration is done the software wont see much use unless I change things in my system / room. Seeing the response in my room makes me want to add some room treatments to improve the pre correction response.
Also, I have identical speakers / amps front and rear (full range) but could not tune the bass response to go as low in the rears as the fronts.
I'm a bit disappointed that the manual is still for CBIIIhd with only an added supplement for CBIV. a lot of the old crossover options are gone, as has been discussed here, and the menus don't always match. I realize doco is the last thing that gets worked on, and I'm sure it will be improved over time.
Overall I am extremely satisfied and impressed. This is going to be a good product for theta/ATI
Michael Osadciw likes this.
phunge is offline
post #7189 of 11436 Old 07-11-2014, 10:25 AM
Eleanor D's Avatar
The hard reset of the Theta seems to be the key to establishing a handshake with the Dirac software. I know that John Baloff is revising the installation guide and will be making this clearer.
Here is a tip for those with well treated rooms so that the effect of Dirac is subtle, and are wondering, after all the setup problems, if Dirac is actually active. I created a bogus filter that was all lows and no highs (this is self-explanatory within Dirac.) I loaded this filter and, sure enough, my system was producing all lows and no highs. I then loaded my correct filter and sat back to enjoy. Time this weekend to create a new filter so that the microphone does not cover such a wide range of seating positions. Has anyone compared a narrow versus wide range of mike positions?
Eleanor D is offline
post #7190 of 11436 Old 07-11-2014, 10:58 AM
RUR
Innocent Bystander
RUR's Avatar
Quoted: 382 Post(s)
Liked: 265
I would strongly encourage those new to the concept of tailorable target curves to experiment. Don't assume that the supplied curve(s) is the one which will subjectively please you best. Change the slope of the curve.....and listen. Increase and decrease the bass region. Ditto high frequencies. Experiment, experiment, experiment.
Only by experimentation and observation will you fully exploit, to your benefit, this invaluable feature.
RUR is offline
post #7191 of 11436 Old 07-11-2014, 06:25 PM
Roger Dressler's Avatar
Quoted: 1540 Post(s)
Liked: 731
If you have a 5.1 speaker setup and you try to play the 7.1 DTS-HD MA tracks on the AIX disc, they are designed to go "silent" to inform you that you are not hearing the full 7.1 track. The 5.1 tracks should play fine.
Deadwood Atmos theater [HTOM]
AV7702 Atmos 7.4.4, SSP-800 PLIIx 7.4
Aerial Acoustics 7B/CC3B fronts, B&W CWM8180 surrounds, Tannoy Di6 DC heights, Hsu ULS-15 subs
Roger Dressler is offline
post #7192 of 11436 Old 07-13-2014, 01:14 PM
Quoted: 453 Post(s)
Liked: 110
Interesting. Over at What's Best Forum, several high end stereo users, including Bruce who does the digital transfers for HDTracks, say they have tried their own subjective curves and always comes back to the house curve which they say sounds best in their systems.
Well, I've got everything done for my changed out theater components now, including 15" high ACS Subtraps under the two JL Audio f212s. Why haven't I done DIRAC yet? Because I was optimizing my system to sound as good as it can before using DIRAC. Now I am ready to use DIRAC. But my total hip replacement surgery is tomorrow - so I first my get past that, then get home, rehab, etc, and then using DIRAC is the next tweak on my plate.
Though I must confess, having had two months with the CB4, it is an amazing sounding SSP even without DIRAC, much better than the CB3 HD to me because now I even without using DIRAC I am using the CB4 (with Gen VIII Series III DAC for front left and right) (with 80-24 crossover on everything including music) and easily whatever music I play sounds best this way. No more using only the Gen VIII DAC for two channel without subs and that did sound better than only using the CB3 HD with Gen VIII for front left and right.
My home theater at:
post #7193 of 11436 Old 07-13-2014, 02:03 PM
RUR
Innocent Bystander
RUR's Avatar
Quoted: 382 Post(s)
Liked: 265
Do you have a link to the discussion, Steve? What RC were they using for this i.e. Dirac or ???, what "House Curve", and how much effort was put into developing their own curve(s)?
I've been using custom curves in a high end stereo for going on six years, now, and I've spent many, many hours exploring and developing "my" ideal curve. Aside from the general guidelines that most prefer a relatively linear response with extended bass and downward slope from 20-20kHz, there's plenty of room for personal preference in the tilt of the curve - 5dB down, 8dB down etc. - the relative levels in the bass region, high frequency rolloff characteristics, etc. etc. etc.
Users have nothing to lose and potentially much to gain simply by spending some time in experimentation.
RUR is offline
post #7194 of 11436 Old 07-13-2014, 02:19 PM
Quoted: 108 Post(s)
Liked: 70
Krell Amps- new tech Vs the mid 1990's gear
Speaking about Krell......has anyone heard the newer Evolution Stereo amps Vs the older FPBc series?
I'd like to know how much better they sound....should I unload my FPB-300c for the EVO's?
Cheers,
Brian
Deckard97 is offline
post #7195 of 11436 Old 07-13-2014, 02:49 PM
sdurani's Avatar
Quoted: 4685 Post(s)
Liked: 3092
I mentioned a couple years back in this thread that Dirac had chosen wisely with their default target curve. Doesn't mean that experimenting won't allow you to find something you like better. But the fact that they didn't default to a measured-flat response should help it sound good to most users right out of the box.
Sanjay
sdurani is online now
post #7196 of 11436 Old 07-14-2014, 07:11 AM
rcohen's Avatar
Quoted: 1323 Post(s)
Liked: 575
There are a blend of issues that could take you away from the default curve:
1) Psychoacoustic issues with the room.
2) Microphone differences.
3) Personal taste.
4) Avoiding overcorrection beyond driver limits. Try limiting the correction frequency range on the top and bottom, and following the speaker's natural curve to see if it sounds better or worse.
I also found that experimentation was essential for getting the best sound in my room. It's actually pretty fun.
rcohen is offline
post #7197 of 11436 Old 07-14-2014, 05:05 PM
cannga's Avatar
Quoted: 1176 Post(s)
Liked: 859
Cheers,
Brian
OT - as soon as I see this I thought I must answer right away. This is the one you have? http://www.soundstage.com/revequip/krell_fpb300c.htm IMHO: Do not switch unless there is some very convincing evidence with your own actual long term listening test that the Evolution Stereo amp sounds better!
I have had several Krell's in my systems over the years. My experience has been that new Krell amp does not necessarily sound better than old Krell amp - a matter of personal preference. For example the MDA 300 monoblocks I used to have are "better" to my ears than my current one, the FPB 600. MDA 300 has limitless soundstage width, deep, deep bass the seems to emerge from 10000 ft under the sea :-); it was old and one exploded on me so I traded to the newer FPB. By the time I realized how different they sound, it was too late.
FPB to Evolution to me is a downward move (IMHO). Your FPB 300c is an incredibly beautiful amp with sound to match. Keep it for life! The only move I would consider is to the 600, and only if you have incredibly current hungry, low impedance speakers. Hope this helps.
Further Off Topic: BTW, as obvious I am fairly passionate about Krell, but Krell without D'Agostino, definitely not the same, and will it survive? Seems to be nature of the beast that US high end companies depend so much on the vision and ingenuity of one person. Thiel without Jim Thiel is a similar story; I do not know whether it will survive.
Theta is one of the few exceptions - it surprisingly has not only survived, but actually thrived with new owner. Theta with ATI backing has hit the sweet spot. I think the key is that Theta was lucky/clever enough to land that exceptional engineer, David Reich. All Theta owners should really hope that ATI will continue to do well - this is the key to the continued development of Casablanca.
Regards, Can
My System & Theta Casablanca CBIII HD Mini-Review Uncontrolled obsession with music, and sound.
Interesting Audio Diagrams :-) & High-End Speaker Reviews
JTR Subwoofer Thread I don't always listen to subwoofers, but when I do, it's JTR :-).
cannga is online now
post #7198 of 11436 Old 07-14-2014, 05:36 PM
Quoted: 108 Post(s)
Liked: 70
I have had several Krell's in my systems over the years. My experience has been that new Krell amp does not necessarily sound better than old Krell amp - a matter of personal preference. For example the MDA 300 monoblocks I used to have was "better" to my ears than my current one the FPB 600. MDA 300 has limitless soundstage width, deep, deep bass the seems to emerge from 10000 ft under the sea :-); it was old and one exploded on me so I traded to the newer FPB. By the time I realized how different they sound, it was too late.
Theta is one of the few exceptions - it surprisingly has not only survived, but actually thrived with new owner. Theta with ATI backing truly hit the sweet spot. I think the key is that Theta was lucky/clever enough to land that exceptional engineer, David Reich.
I was hoping to hear that answer! Yes, that's the exact amp.
I've decided to hold on to the Krell.....I can always get it fixed at the factory ( 40 miles away ).
( my cousin just got his FPB refurbished for a fair price )
I'd love to step up to the 400c, but it will have to wait until my next speaker upgrade.....300 watts per channel of Krell power is enough to feed my PBN Montana EPS2's.
If I someday step up to their new speakers ( The Compact Reference ) it will strongly encourage me to go for more power....
Of course the 600c would be perfect, but it's too massive for my living room.
post #7199 of 11436 Old 07-15-2014, 10:31 AM
Lex22's Avatar
Hope surgery went well.
Lex22 is offline
post #7200 of 11436 Old 07-16-2014, 01:19 PM
DiscCollector's Avatar
I have an original Theta Dreadnaught I for sale in the classifieds, if anyone is interested. It is the more rare original Dreadnaught (that a lot of people favor) - in silver, with 5 x 200W modules - and has the beautiful optional machined aluminum top.
It is absolutely mint condition, in original box, with all accessories. It is also the last Dreadnaught I that Theta made (or so they told me).
I can ship just about anywhere, and can ship to Canada (from within Canada) or the US (from within the US).
DiscCollector is offline
