The official "Theta" thread - Page 259 - AVS | Home Theater Discussions And Reviews
 30Likes
post #7741 of 7745 Old 01-29-2015, 04:52 AM
jjwinterberg's Avatar
Quoted: 20 Post(s)
Originally Posted by Glimmie View Post
In this context, it's not possible. You will hear about passive gain associated with antennas, but it's not really passive gain either. You are simply tuning the antenna to a narrow band of frequencies at the expense of others.
Thanks for your reply, I was pretty sure that "passive" was not what Steve ment. The term that I have seen used for the concept Steve was referring to is "buffer" amplification and is also used for impedance control of the pre-amp output stage.
BTW, most antennas have some directivity. Even dipole antennas, prefer horizontal incidence,
jjwinterberg is offline
post #7742 of 7745 Old 01-30-2015, 05:20 PM
Bulldogger's Avatar
Quoted: 54 Post(s)
Liked: 29
Originally Posted by stevekale View Post
I think you should read more about gain structure. The article I linked to above would be a good start. You can also start from the other end. Choose a listening peak SPL level, number of speakers, listening distance, speaker sensitivity, voltage gain of the amplifier of your choice and derive the voltage level fed to that amplifier to achieve your starting point.
These are "straw man," arguments. I think you should just admit that active preamps add gain and stop trying to refute points I did not make. I will not even entertain this one.
Never become so involved with something that it blinds you.
Bulldogger is offline
post #7743 of 7745 Old 01-30-2015, 05:22 PM
Bulldogger's Avatar
Quoted: 54 Post(s)
Liked: 29
I am the only one that noticed Larry Greenhill's equipment list includes Theta Prometheus amps in the last Stereophile? I am guessing this means that he is the one that is reviewing the Theta amps.
post #7744 of 7745 Unread Yesterday, 10:41 PM
Stereojeff's Avatar
Quoted: 22 Post(s)
Yes. March, 2015 issue.
Jeff
Stereojeff is online now
post #7745 of 7745 Unread Today, 12:06 AM
rhale64L7's Avatar
Quoted: 260 Post(s)
Liked: 66
Great. Can't wait to read it.
rhale64L7 is online now
