Need help with ADA Mach IV! - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 45 Old 06-06-2011, 03:10 PM
PabloReiter's Avatar
Originally Posted by Deepsky4565 View Post
Sorry for the spotty replies, end of semester. Yes, I tried Itai's recommended settings. Are there a different set of rs232 commands? I thought that's what you were using. Maybe if you can give me all your settings, I could try to duplicate it. Thanks so much for helping me out.
i had the same problem and finally figured it out. You have to replace the last three digits by 255 on the gateway configuration. so if your ip address of the rhapsody is 192.168.1.199 then in the gateway you need to say 192.168.1.255. Problem solved for me. i think irules needs this to indicate udp port vs tcp/ip port.
PabloReiter is offline
post #32 of 45 Old 06-06-2011, 07:28 PM - Thread Starter
Deepsky4565's Avatar
Thanks, I'll give that a try. I've spent another 6 hours changing out routers, reinstalling all software, etc with no go.
Deepsky4565 is offline
post #33 of 45 Old 06-07-2011, 05:54 AM - Thread Starter
well, I tried it, and irule seems to like it as in it connects to gateways, but the commands do nothing. Any ideas?
post #34 of 45 Old 06-07-2011, 07:26 AM
thebland's Avatar
Quoted: 1664 Post(s)
Liked: 1003
Give us a screen shot of how you entered a command in irule. Showing the command on the left side.
Goodbye to a great audio and video genius and writer... JOHN GANNON. I enjoyed your friendship, wit and a nice long run we took around Indianapolis at CEDIA years back... and for buying my Runco 980 Ultra years back... you saved my ass! Rest in peace.
thebland is online now
post #35 of 45 Old 06-07-2011, 08:17 AM
Do you see green arrows on the bottom left hand side every time you hit a button on irules? if they are red, or nothing, then you are still not connecting or you are not sending the right command, but if they are green then you are transmitting correctly. On the bottom right hand side, there should be a green icon for the gateway. it it is yellow, then it did not connect to some of your gateways. if it is red, then it connected to none.
make sure you are sending the right command on the button you are sending. Once I got a green connection to the gateway, the Mach iv started responding right away. It did take a reboot of the mach iv though...
is your HD Suite software talking to the Mach IV with total feedback too?
I had to change my mask to 255.255.255.255 (on iso-e) to make this work with the same settings you have.
post #36 of 45 Old 06-07-2011, 08:10 PM - Thread Starter
Thanks for the suggestions, guys. I am getting green on both gateways, and transmitting of commands. I'll try changing the mask settings this morning when I get home, and rebooting the MachIV. I'll let you know how it goes. I am very appreciative of your help.
post #37 of 45 Old 06-08-2011, 06:06 AM - Thread Starter
Success! Setting the address last 3 digits to 255 and the mask to all 255s did the trick. Thanks so much for all the help!!!
post #38 of 45 Old 06-08-2011, 12:57 PM
Rock on!
post #39 of 45 Old 06-08-2011, 01:18 PM
thebland's Avatar
Liked: 1003
Finally!!!
post #40 of 45 Old 12-02-2012, 11:26 AM
NaTT's Avatar
ah the power of search. this thread just helped me to connect via iRule. So thanks guys!
Now to get feedback set up and to get the SuiteHD software to work again (it can't connect after changing my Suite 7.1 HD's IP settings with the ISO tool rolleyes.gif
NaTT is offline
post #41 of 45 Old 12-06-2012, 10:33 AM
Larry Ng's Avatar
NaTT , glad to hear your problem solved , that prompts me to solve mine and I need help from members here .
I have a Suite HD 7.1 1.4 for almost 8 months and despite how hard I tried - despite all that I read from forum on this same subject - I still cannot speak to my Suite - I am not that proficient on this subject . I installed all necessary ADA software on XP - Service pack 2 and installation is successful but whenever I try to open the software , it indicates "ADA Ethernet - WSAIoct1 failed 0 " and I cannot even speak to my Suite . I set my Suite from the front and control my Suite through Harmony 1000 . I have given up as it costs me a lot of time by trial & error .
I wish to ask for help as following ; I now want to turn on TEQ but that can only be done from PC , so I wish I can solve this problem with helps from members .
And if that is beyond my capability to work through , I would like to know ;
I have WiFi running 24 hours , I can connect a Lan cable from my Suite to the TP - Link router , I have iPads that is WiFi connected , not yet ordered i-Rule , I need to know if it is possible for me to control my Suite only with this availability - no PC talking to my Suite .
I only need a better remote than my Harmony 1000 , iPad is ideal to me .
Helps and advice appreciated .
Larry
Larry Ng is offline
post #42 of 45 Old 12-07-2012, 10:06 AM
magicj1's Avatar
Quoted: 67 Post(s)
so what are you saying Natt, can you not connect to the ADA via the PC suite program since using the ISO tool?
magicj1 is offline
post #43 of 45 Old 12-09-2012, 06:20 AM
Brucemck2's Avatar
Quoted: 70 Post(s)
Liked: 36
I too am struggling to connect via ISO-e program on a hardwired network. When I run that program, with both my laptop and the ADA on the exact same hub, and find devices it returns:
Internal Ethernet card is 192.168.1.244 with subnet of 255.255.255.0
Found ADA of 255.255.0.0 with address of 169.254.255.255
When I use ISO-e to reprogram the ADA I give it a subnet mask of 255.255.255.0 and an address of 192.168.1.254. I know from my router's devices table that 254 is empty/available.
(ps -- I can connect directly using a cross connect cable, but not via my ethernet network)
The ADA never shows up on my network, even after a reboot. I tried both Windows 7 64 bit and XP on two different laptops.
What's odd is that after using ISO-e, if I use a cross connect cable again, the ADA shows the original address, indicating the new address never got written.
Any suggestions?
Brucemck2 is offline
post #44 of 45 Old 12-11-2012, 02:21 PM
magicj1's Avatar
Quoted: 67 Post(s)
Any suggestions?
I too struggled. Read from post 1781, it may help? http://www.avsforum.com/t/1196455/ada-mach-4-wow/1770#post_22347891
magicj1 is offline
post #45 of 45 Old 12-12-2012, 05:15 AM
Larry Ng's Avatar
It seems that everyone are/were having problems in setting up their ADA to talk to PC , I too struggled with no success and I have given up . Reading threads does help to understand what could be wrong but to those just with general knowledge , it is still not easy . ADA's software could be made more user friendly , why not an built in VNC like MC ? Just do not understand why ADA do not work to improve on this , it shouldn't be difficult for ADA .
MC is also intended for professional installation but an novice like me can still got it installed within several hours with satisfactory result and no reason why ADA couldn't achieve the same !
Larry
Larry Ng is offline
